pi@hbridge2:~ $ homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
[2018-1-20 16:48:07] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^8.9.4 which does not satisfy the current Node version of v9.2.0. You may need to upgrade your installation of Node.
[2018-1-20 16:48:08] Loaded plugin: homebridge-hue
[2018-1-20 16:48:08] Registering platform 'homebridge-hue.Hue'
[2018-1-20 16:48:08] ---
[2018-1-20 16:48:08] Loaded config.json with 0 accessories and 1 platforms.
[2018-1-20 16:48:08] Loading 1 platforms...
[2018-1-20 16:48:08] [Hue] Initializing Hue platform...
[2018-1-20 16:48:08] [Hue] homebridge-hue v0.5.65, node v9.2.0, homebridge v0.4.36
[2018-1-20 16:48:08] [Hue] warning: not using recommended node version v8.9.4 LTS
[2018-1-20 16:48:08] Loading 0 accessories...
[2018-1-20 16:48:09] [Hue] dresden appspot ipv6: communication error ENETUNREACH on https://dresden-light.appspot.com/
[2018-1-20 16:48:14] [Hue] Philips hue: BSB002 bridge v1711151408, api v1.22.0
[2018-1-20 16:48:14] [Hue] Philips hue: 12 accessories
[2018-1-20 16:48:14] [Hue] masked debug info dumped to /home/pi/.homebridge/homebridge-hue.json.gz
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Philips hue'...
[2018-1-20 16:48:14] [Hue] Philips hue: 3 services
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Wohnzimmer klein 1'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Wohnzimmer klein 2'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Wohnzimmer klein 3'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Flur oben 1'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Flur oben 2'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Decke 1'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Decke 2'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Decke 3'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Decke 4'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Nachttisch 1'...
[2018-1-20 16:48:14] [Hue] Initializing platform accessory 'Schlafzimmer Nachttisch 2'...
Setup Payload:
X-HM://0023ISYWY4OP2
[QRCODE]
? 031-45-154 ?
events.js:136
Error: listen EADDRINUSE :::51826
at Object._errnoException (util.js:1031:13)
at _exceptionWithHostPort (util.js:1052:20)
at Server.setupListenHandle [as _listen2] (net.js:1367:14)
at listenInCluster (net.js:1408:12)
at Server.listen (net.js:1496:7)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:607:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:126:16)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:382:14)
