HI habe auch das update gemacht und nun startet sie auch nicht kann mir da einer weiter helfen .
[2020-4-27 12:36:30] Initializing platform accessory 'Abfall Kalender'...
Apr 27 12:36:30 raspberrypi homebridge[1270]: [2020-4-27 12:36:30] Error loading platform requested in your config.json at position 3
Apr 27 12:36:30 raspberrypi homebridge[1270]: [2020-4-27 12:36:30] Error: The requested platform 'Fritz!Box' was not registered by any plugin.
Apr 27 12:36:30 raspberrypi homebridge[1270]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:223:15)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at /usr/local/lib/node_modules/homebridge/src/server.ts:361:37
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Array.forEach (<anonymous>)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:348:27)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:151:29)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:74:10)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Module.load (internal/modules/cjs/loader.js:1000:32)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
Apr 27 12:36:30 raspberrypi homebridge[1270]: at internal/main/run_main_module.js:18:47
Apr 27 12:36:30 raspberrypi homebridge[1270]: [2020-4-27 12:36:30] Got SIGTERM, shutting down Homebridge...
Apr 27 12:36:30 raspberrypi homebridge[1270]: [2020-4-27 12:36:30] [HarmonyHub] INFO - shutdown
