Beiträge von Mxas88
    Ja, ich glaube ich habe das Problem gefunden.
    Es lief zweimal Homebridge
    einmal: homebridge
    und einmal: sudo Homebridge
    Wie kann ich das denn ändern? Ich hab das wohl zweimal installiert
    Die Lampen werden ganz normal über die Original Hue App in der HomeKit App angezeigt.
    Hab jetzt mal die Sensoren auf True gestellt.
    [3/22/2017, 6:37:06 PM] Loaded plugin: homebridge-fritz
    [3/22/2017, 6:37:07 PM] Registering platform 'homebridge-fritz.Fritz!Box'
    [3/22/2017, 6:37:07 PM] ---
    [3/22/2017, 6:37:08 PM] Loaded plugin: homebridge-fritzbox
    [3/22/2017, 6:37:08 PM] Registering platform 'homebridge-fritzbox.FRITZ!Box'
    [3/22/2017, 6:37:08 PM] ---
    [3/22/2017, 6:37:09 PM] Loaded plugin: homebridge-hue
    [3/22/2017, 6:37:09 PM] Registering platform 'homebridge-hue.Hue'
    [3/22/2017, 6:37:09 PM] ---
    [3/22/2017, 6:37:09 PM] Loaded plugin: homebridge-tado
    [3/22/2017, 6:37:09 PM] Registering accessory 'homebridge-tado.TADO'
    [3/22/2017, 6:37:09 PM] Loaded config.json with 1 accessories and 2 platforms.
    [3/22/2017, 6:37:09 PM] Loading 2 platforms...
    [3/22/2017, 6:37:09 PM] [My FritzBox] Initializing Fritz!Box platform...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing Hue platform...
    [3/22/2017, 6:37:09 PM] [Hue] homebridge-hue v0.3.11, node v4.3.2, homebridge api v2.1
    [3/22/2017, 6:37:09 PM] Loading 1 accessories...
    [3/22/2017, 6:37:09 PM] [Tado] Initializing TADO accessory...
    [3/22/2017, 6:37:09 PM] [Hue] Wohnung Coburg: BSB002 bridge, api v1.17.0
    [3/22/2017, 6:37:09 PM] [Hue] Wohnung Coburg: 18 accessories
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Wohnung Coburg'...
    [3/22/2017, 6:37:09 PM] [Hue] Wohnung Coburg: 2 services
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Daylight'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Schlafzimmer'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Wohnzimmer'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Dimmer Switch 4 SceneCycle'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'iPhone 7 ms'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'HomeAway'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Katharina'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'Hue temperature sensor 1'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'MotionSensor 14.Companion'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'XFDani[1]sn:state'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'XFDani[1][1]sn:step'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'XFDHueDim4Btn1001State'...
    [3/22/2017, 6:37:09 PM] [Hue] Initializing platform accessory 'XFDHueDim2Btn1000State'...
    [3/22/2017, 6:37:10 PM] [My FritzBox] Fritz!Box platform login successful
    [3/22/2017, 6:37:10 PM] [My FritzBox] Discovering accessories
    [3/22/2017, 6:37:11 PM] [My FritzBox] Outlets found:
    [3/22/2017, 6:37:12 PM] [My FritzBox] Thermostats found:
    [3/22/2017, 6:37:12 PM] [My FritzBox] Sensors found:
    [3/22/2017, 6:37:12 PM] [My FritzBox] Initializing platform accessory 'Guest WLAN'...
    Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    ? 031-45-154 ?
    events.js:141
    Error: listen EADDRINUSE :::51826
    at Object.exports._errnoException (util.js:870:11)
    at exports._exceptionWithHostPort (util.js:893:20)
    at Server._listen2 (net.js:1236:14)
    at listen (net.js:1272:10)
    at Server.listen (net.js:1368:5)
    at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
    at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
    at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
    at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:114:16)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:372:14)
    at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
    at /usr/local/lib/node_modules/homebridge-fritz/index.js:125:25
    at tryCatcher (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/util.js:16:23)
    at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:512:31)
    at Promise._settlePromise (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:569:18)
    at Promise._fulfillPromises (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:668:14)
    Jetzt kommen die obigen Fehler.
    "bridge":{
    "name":"Homebridge",
    "username":"CC:22:3D:E3:CE:30",
    "port":51826,
    "pin":"031-45-154"
    "accessories":[
    "accessory": "TADO",
    "name": "Tado",
    "homeID": "58817",
    "username": "xxxxxxxx",
    "password": "xxxxxxx"
    "platforms":[
    "platform":"Fritz!Box",
    "name":"My FritzBox",
    "username":"xxxxxx",
    "password":"xxxxxxxx",
    "url":"http://fritz.box",
    "interval":60,
    "options":{
    "strictSSL":false
    "platform":"Hue",
    "name":"Hue",
    "host":"192.168.178.39",
    "users":{
    "001788FFFE2B4540": "2vDQgVaxG6M1tbt98-SJ5JBjDxicrLrncoMhgR1o"
    "sensors":false,
    "excludeSensorTypes":[
    "CLIP",
    "Geofence",
    "Daylight"
    "lowBattery":25,
    "lights":false,
    "philipsLights":false,
    "ct":false,
    "groups":false,
    "group0":false,
    "rooms":false,
    "schedules":false,
    "rules":false,
    "heartrate":5,
    "waitTimeUpdate":20,
    "timeout":5,
    "parallelRequests":10,
    "waitTimeResend":300
    Hallo.
    Ich habe auf meinem Raspberry Homekit mit 3 Plugins installiert.
    Das Fritz Box Plug in funktioniert einwandfrei und wird angezeigt in Apple Homekit.
    Dann habe ich noch ein Plugin für Hue installiert und eines für Tado. Weder Tado noch Hue wird in der Homekit App angezeigt.
    Es wird kein Fehler ausgegeben, funktioniert aber trotzdem nicht.
    Folgendes wird angezeigt beim Starten von Homebridge:
    [3/21/2017, 7:01:36 PM] Registering platform 'homebridge-fritz.Fritz!Box'
    [3/21/2017, 7:01:36 PM] ---
    [3/21/2017, 7:01:38 PM] Loaded plugin: homebridge-fritzbox
    [3/21/2017, 7:01:38 PM] Registering platform 'homebridge-fritzbox.FRITZ!Box'
    [3/21/2017, 7:01:38 PM] ---
    [3/21/2017, 7:01:39 PM] Loaded plugin: homebridge-hue
    [3/21/2017, 7:01:39 PM] Registering platform 'homebridge-hue.Hue'
    [3/21/2017, 7:01:39 PM] ---
    [3/21/2017, 7:01:39 PM] Loaded plugin: homebridge-tado
    [3/21/2017, 7:01:39 PM] Registering accessory 'homebridge-tado.TADO'
    [3/21/2017, 7:01:39 PM] Loaded config.json with 1 accessories and 2 platforms.
    [3/21/2017, 7:01:39 PM] Loading 2 platforms...
    [3/21/2017, 7:01:39 PM] [My FritzBox] Initializing Fritz!Box platform...
    [3/21/2017, 7:01:39 PM] [Hue] Initializing Hue platform...
    [3/21/2017, 7:01:39 PM] [Hue] homebridge-hue v0.3.11, node v4.3.2, homebridge api v2.1
    [3/21/2017, 7:01:39 PM] Loading 1 accessories...
    [3/21/2017, 7:01:39 PM] [Tado] Initializing TADO accessory...
    [3/21/2017, 7:01:39 PM] [Hue] Wohnung Coburg: BSB002 bridge, api v1.17.0
    [3/21/2017, 7:01:39 PM] [Hue] Wohnung Coburg: 1 accessories
    [3/21/2017, 7:01:39 PM] [Hue] Initializing platform accessory 'Wohnung Coburg'...
    [3/21/2017, 7:01:39 PM] [Hue] Wohnung Coburg: 2 services
    [3/21/2017, 7:01:42 PM] [My FritzBox] Fritz!Box platform login successful
    [3/21/2017, 7:01:42 PM] [My FritzBox] Discovering accessories
    [3/21/2017, 7:01:43 PM] [My FritzBox] Outlets found:
    [3/21/2017, 7:01:44 PM] [My FritzBox] Thermostats found:
    [3/21/2017, 7:01:44 PM] [My FritzBox] Sensors found:
    [3/21/2017, 7:01:44 PM] [My FritzBox] Initializing platform accessory 'Guest WLAN'...
