Beiträge von Schmeckis
Alles anzeigenpi@hbridge2:~ $ sudo tail -f /var/log/syslog Apr 23 22:58:15 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:15 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:15 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:15 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:26 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart. Apr 23 22:58:26 hbridge2 systemd[1]: Stopping Node.js HomeKit Server... Apr 23 22:58:26 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:26 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:26 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:26 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:36 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart. Apr 23 22:58:36 hbridge2 systemd[1]: Stopping Node.js HomeKit Server... Apr 23 22:58:36 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:36 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:36 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:36 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:46 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart.das geht dann immer so weiter. Liegt es eventuell daran, dass es ein Pi 1 ist? Würde das 4.4 image vielleicht etwas ändern?
Moin,
ich habe auch versucht Homebridge mit dem "Jessie mit Kernel 4.9" und dem "Stretch (lite) mit Kernel: 4.9" Image auf einem Raspberry Pi Model B Revision 2.0 aufzusetzen und bekomme folgenden Fehler:
Codepi@hbridge2:~ $ sudo systemctl status homebridge ? homebridge.service - Node.js HomeKit Server Loaded: loaded (/etc/systemd/system/homebridge.service; enabled) Active: activating (auto-restart) (Result: signal) since So 2018-04-22 20:12:42 CEST; 9s ago Process: 778 ExecStart=/usr/local/bin/homebridge $HOMEBRIDGE_OPTS (code=killed, signal=SEGV) Main PID: 778 (code=killed, signal=SEGV) Apr 22 20:12:42 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 22 20:12:42 hbridge2 systemd[1]: Unit homebridge.service entered failed state.Der Fehler kommt bei beiden Images.
Weiß eventuell jemand was der Fehler bedeutet und wie ich ihn beheben kann?
