May 02 17:13:08 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
May 02 17:13:08 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
May 02 17:13:08 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
May 02 17:13:18 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
May 02 17:13:18 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
May 02 17:13:18 raspberrypi systemd[1]: Started Node.js HomeKit Server.
May 02 17:13:18 raspberrypi homebridge[15965]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
May 02 17:13:18 raspberrypi homebridge[15965]: *** WARNING *** Please fix your application to use the native API of Avahi!
May 02 17:13:18 raspberrypi homebridge[15965]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
May 02 17:13:18 raspberrypi homebridge[15965]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May 02 17:13:18 raspberrypi homebridge[15965]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
May 02 17:13:18 raspberrypi node[15965]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
May 02 17:13:18 raspberrypi node[15965]: *** WARNING *** Please fix your application to use the native API of Avahi!
May 02 17:13:18 raspberrypi node[15965]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
May 02 17:13:18 raspberrypi node[15965]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May 02 17:13:18 raspberrypi node[15965]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
May 02 17:13:20 raspberrypi homebridge[15965]: ????????????????????????????????????????????????????????????????
May 02 17:13:20 raspberrypi homebridge[15965]: ? npm update check failed ?
May 02 17:13:20 raspberrypi homebridge[15965]: ? Try running with sudo or get access ?
May 02 17:13:20 raspberrypi homebridge[15965]: ? to the local update config store via ?
May 02 17:13:20 raspberrypi homebridge[15965]: ? sudo chown -R $USER:$(id -gn $USER) /home/homebridge/.config ?
May 02 17:13:21 raspberrypi homebridge[15965]: [2018-5-2 17:13:21] Loaded plugin: homebridge-hue
May 02 17:13:21 raspberrypi homebridge[15965]: [2018-5-2 17:13:21] Registering platform 'homebridge-hue.Hue'
May 02 17:13:21 raspberrypi homebridge[15965]: [2018-5-2 17:13:21] ---
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] Loaded plugin: homebridge-netatmo
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] Registering platform 'homebridge-netatmo.netatmo'
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] ---
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] Loaded config.json with 1 accessories and 2 platforms.
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] Loading 2 platforms...
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] [Hue] Initializing Hue platform...
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] [Hue] config.json: warning: philipsLights: ignoring unknown key
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] [Hue] homebridge-hue v0.9.2, node v8.11.1, homebridge v0.4.38
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] [netatmo platform] Initializing netatmo platform...
May 02 17:13:22 raspberrypi homebridge[15965]: [2018-5-2 17:13:22] Loading 1 accessories...
May 02 17:13:22 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
May 02 17:13:22 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
May 02 17:13:22 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
