Wie genau soll ich das denn dann überprüfen?
Ich benutze Homebridge nur aufgrund des Harmony Plugin
System-Logs
X-HM://0023ISZC98BKA
Setup Payload:
Load homebridge-cmdswitch2.cmdSwitch2
[2018-6-4 20:02:13] [Pi Temp] Initializing RaspberryPiTemperature accessory...
[2018-6-4 20:02:12] [Example PC] Starting pinger at an interval of 15000 milli seconds
[2018-6-4 20:02:12] [Example PC] Stopping pinger
[2018-6-4 20:02:12] [Example PC] Initializing NetworkDevice accessory...
[2018-6-4 20:02:12] Loading 2 accessories...
[2018-6-4 20:02:12] [Harmony Hub] Initializing HarmonyHub platform...
[2018-6-4 20:02:12] Loading 1 platforms...
[2018-6-4 20:02:12] ---
[2018-6-4 20:02:12] Loaded config.json with 2 accessories and 1 platforms.
[2018-6-4 20:02:12] Registering accessory 'homebridge-wol.NetworkDevice'
[2018-6-4 20:02:12] Loaded plugin: homebridge-wol
[2018-6-4 20:02:12] Registering accessory 'homebridge-raspberrypi-temperature.RaspberryPiTemperature'
[2018-6-4 20:02:12] Loaded plugin: homebridge-raspberrypi-temperature
[2018-6-4 20:02:12] Registering accessory 'homebridge-people.people'
[2018-6-4 20:02:12] Loaded plugin: homebridge-people
[2018-6-4 20:02:12] Registering platform 'homebridge-harmonyhub.HarmonyHub'
[2018-6-4 20:02:09] Loaded plugin: homebridge-harmonyhub
[2018-6-4 20:02:09] ---
[2018-6-4 20:02:09] Registering platform 'homebridge-cmdswitch2.cmdSwitch2'
[2018-6-4 20:02:08] Loaded plugin: homebridge-cmdswitch2
[2018-6-4 20:01:44] Got SIGTERM, shutting down Homebridge...
Musik hören
PowerOff
Apple TV sehen
Ps4
[2018-6-4 17:10:10] [Harmony Hub] Found activities:
[2018-6-4 17:09:46] [Harmony Hub] Fetching Logitech Harmony activities...
[2018-6-4 17:09:45] Homebridge is running on port 51826.
? 031-45-705 ?
Error-Logs
Tue, 31 Jul 2018 19:57:00 GMT harmonyhubjs:discover:responsecollector received data chunk
Tue, 31 Jul 2018 19:57:00 GMT harmonyhubjs:discover:responsecollector handle new connection
Tue, 31 Jul 2018 19:57:00 GMT harmonyhubjs:discover:ping emit()
Tue, 31 Jul 2018 19:56:59 GMT harmonyhubjs:discover:responsecollector connection closed. emitting data.
Bin Leider Angänger was genau aus der Log-Datei braucht man denn zur Diagnose? Die System-Logs oder die Error-Logs?
Ich habe ein ähnliches Problem. Bei mir steht oft bei den über Hombridge zu HomeKit zugefügten Geräten „keine Antwort“ oder „Aktualisieren“. Ich habe auch noch Geräte im HomeKit die nicht über Homebridge laufen und diese funktionieren einwandfrei weiter während die Geräte der Homebridge nicht erreichbar sind. Das der Drucker das Problem verursacht haben soll versteh ich nicht, ich habe allerdings auch keinen Drucker der das Problem bei mir verursachen könnte.
