Hallo Fritzbox Fans,
ich habe leider seit dem neuesten Fritz Plugin Update Probleme mit meinen Smarthome Aktoren.
Die Aktoren werden nicht mehr erkannt bzw. in der Homebridge Oberfläche angezeigt.
Anbei meine Konfig:
"bridge": {
"name": "Homebridge",
"port": 51826,
"pin": "031-45-154"
"accessories": [],
"platforms": [
"platform": "config",
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "red",
"sudo": true,
"log": {
"method": "systemd",
"service": "homebridge"
"platform": "FritzPlatform",
"devices": {
"ROUTER-HOME-PETER": {
"active": true,
"host": "192.168.150.1",
"port": 49000,
"username": "xxx",
"password": "xxx",
"type": "dsl",
"master": true,
"mesh": false,
"readOnly": false,
"options": {
"reconnect": false,
"wifi2": [
false,
false
"wifi5": [
false,
false
"wifiGuest": [
false,
false
"wps": [
false,
false
"aw": [
false,
false
"deflection": [
false,
false
"led": [
false,
false
"lock": [
false,
false
"AP-HOME-PETER": {
"active": false,
"host": "192.168.150.210",
"port": 49000,
"username": "",
"password": "",
"type": "",
"master": false,
"mesh": false,
"readOnly": false,
"options": false
"polling": 10,
"timeout": 10,
"clearCache": false,
"debug": true,
"disableAutoSearch": false,
"smarthome": {
"Markus Power": {
"ain": "xxx",
"type": "switch",
"tempSensor": true,
"unit": "celsius"
"Markus Heizung": {
"ain": "xxx",
"type": "thermo",
"unit": "celsius",
"heatValue": 5,
"coolValue": 5
"Helmut Heizung": {
"ain": "xxx",
"type": "thermo",
"unit": "celsius",
"heatValue": 5,
"coolValue": 5
"callmonitor": {
"active": false,
"ip": "0.0.0.0",
"port": 1012,
"country": "",
"incomingTo": [],
"outgoingFrom": []
"presence": {
"user": [
"active": false,
"name": "Test User",
"address": "0.0.0.0"
"anyone": false,
"offDelay": 90,
"onDelay": 15,
"ping": false
"wol": [
"active": false,
"name": "Test Device",
"address": "00:00:00:00:00:00"
"phoneBook": {
"active": false,
"blacklists": []
"alarm": {
"active": false,
"telNr": "",
"duration": 30
"wakeup": {
"active": false,
"internNr": "",
"duration": 30
"ringlock": {
"active": false,
"DECTphones": 1,
"start": "11:00",
"end": "22:00"
"broadband": {
"active": true,
"measureTime": 5
"extReboot": {
"active": false,
"cmdOn": "",
"cmdOff": ""
"telegram": {
"active": false,
"token": "",
"chatID": "",
"presence": {
"in": "",
"out": "",
"anyoneIn": "",
"anyoneOut": ""
"callmonitor": {
"incoming": "",
"disconnected": ""
"alarm": {
"activated": "",
"deactivated": ""
"extReboot": {
"start": "",
"finish": ""
"disableAutoConfig": false
"id": "config"
Ich habe bereits die Frizzbox und die Homebridge neu gestartet und sogar die Homebridge komplett neu aufgesetzt, leider erfolglos.
Anbei der Output meines Logs:
Jul 13 09:22:29 raspberrypi homebridge[5683]: [7/13/2019, 9:22:29 AM] [FritzPlatform] [INFO] Auto Device Search is enabled, searching for devices in network...
Jul 13 09:22:29 raspberrypi homebridge[5683]: [7/13/2019, 9:22:29 AM] Homebridge is running on port 51826.
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.598Z FritzPlatform Found following devices:
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.707Z FritzPlatform [ { name: 'AP-HOME-PETER',
Jul 13 09:22:34 raspberrypi homebridge[5683]: address: '192.168.150.210',
Jul 13 09:22:34 raspberrypi homebridge[5683]: port: '49000',
Jul 13 09:22:34 raspberrypi homebridge[5683]: location: 'http://192.168.150.210:49000/tr64desc.xml',
Jul 13 09:22:34 raspberrypi homebridge[5683]: serial: 'FB-xxxx' },
Jul 13 09:22:34 raspberrypi homebridge[5683]: { name: 'ROUTER-HOME-PETER',
Jul 13 09:22:34 raspberrypi homebridge[5683]: address: '192.168.150.1',
Jul 13 09:22:34 raspberrypi homebridge[5683]: location: 'http://192.168.150.1:49000/tr64desc.xml',
Jul 13 09:22:34 raspberrypi homebridge[5683]: serial: 'FB-xxxx' } ]
Jul 13 09:22:34 raspberrypi homebridge[5683]: [7/13/2019, 9:22:34 AM] [FritzPlatform] [INFO] Initializing config...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.787Z FritzPlatform Initializing extra accessories...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.807Z FritzPlatform Initializing extras...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.823Z FritzPlatform Initializing telegram...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.827Z FritzPlatform Initializing callmonitor...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.832Z FritzPlatform Generating config...
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.940Z FritzPlatform Config.json loaded!
Jul 13 09:22:34 raspberrypi homebridge[5683]: 2019-07-13T07:22:34.948Z FritzPlatform Writing new parameter into config.json...
Jul 13 09:22:35 raspberrypi homebridge[5683]: 2019-07-13T07:22:35.051Z FritzPlatform Config.json refreshed!
Jul 13 09:22:35 raspberrypi homebridge[5683]: 2019-07-13T07:22:35.054Z FritzPlatform {
Jul 13 09:22:35 raspberrypi homebridge[5683]: "platform": "config",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "name": "Config",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "port": 8080,
Jul 13 09:22:35 raspberrypi homebridge[5683]: "auth": "form",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "theme": "red",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "restart": "sudo -n systemctl restart homebridge",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "temp": "/sys/class/thermal/thermal_zone0/temp",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "sudo": true,
Jul 13 09:22:35 raspberrypi homebridge[5683]: "log": {
Jul 13 09:22:35 raspberrypi homebridge[5683]: "method": "systemd",
Jul 13 09:22:35 raspberrypi homebridge[5683]: "service": "homebridge"
Jul 13 09:22:35 raspberrypi homebridge[5683]: }
Jul 13 09:22:35 raspberrypi homebridge[5683]: [7/13/2019, 9:22:35 AM] [FritzPlatform] [INFO] Found 1 active devices...
Jul 13 09:22:35 raspberrypi homebridge[5683]: 2019-07-13T07:22:35.064Z FritzPlatform Checking master device...
Jul 13 09:22:45 raspberrypi homebridge[5683]: 2019-07-13T07:22:45.699Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: get /upnp/control/deviceinfo
Jul 13 09:22:45 raspberrypi homebridge[5683]: 2019-07-13T07:22:45.788Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: Ok (authenticated)
Jul 13 09:22:45 raspberrypi homebridge[5683]: 2019-07-13T07:22:45.802Z FritzPlatform Master device successfully confirmed
Jul 13 09:22:45 raspberrypi homebridge[5683]: 2019-07-13T07:22:45.808Z FritzPlatform Device initialization finished
Jul 13 09:22:46 raspberrypi homebridge[5683]: [7/13/2019, 9:22:46 AM] [FritzPlatform] [INFO] Configuring accessory from cache: ROUTER-HOME-PETER
Jul 13 09:22:46 raspberrypi homebridge[5683]: [7/13/2019, 9:22:46 AM] [FritzPlatform] [INFO] ROUTER-HOME-PETER: Successfully logged in!
Jul 13 09:22:46 raspberrypi homebridge[5683]: 2019-07-13T07:22:46.494Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: get /upnp/control/userif
Jul 13 09:22:47 raspberrypi homebridge[5683]: 2019-07-13T07:22:47.461Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: Ok (authenticated)
Jul 13 09:22:47 raspberrypi homebridge[5683]: 2019-07-13T07:22:47.514Z FritzPlatform ROUTER-HOME-PETER: Inspecting Characteristics and Services...
Jul 13 09:22:47 raspberrypi homebridge[5683]: 2019-07-13T07:22:47.552Z FritzPlatform ROUTER-HOME-PETER: Inspecting Characteristics and Services finished!
Jul 13 09:22:47 raspberrypi homebridge[5683]: 2019-07-13T07:22:47.559Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: get /upnp/control/wanpppconn1
Jul 13 09:22:48 raspberrypi homebridge[5683]: 2019-07-13T07:22:48.144Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: Ok (challenge)
Jul 13 09:22:48 raspberrypi homebridge[5683]: 2019-07-13T07:22:48.149Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: get /upnp/control/wanpppconn1
Jul 13 09:22:49 raspberrypi homebridge[5683]: 2019-07-13T07:22:49.338Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 1: Ok (authenticated)
Jul 13 09:22:58 raspberrypi homebridge[5683]: [7/13/2019, 9:22:58 AM] [Config] Console v4.5.1 is listening on :: port 8080
Jul 13 09:22:59 raspberrypi homebridge[5683]: 2019-07-13T07:22:59.355Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 2: get /upnp/control/wanpppconn1
Jul 13 09:23:00 raspberrypi homebridge[5683]: 2019-07-13T07:23:00.546Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 2: Ok (authenticated)
Jul 13 09:23:10 raspberrypi homebridge[5683]: 2019-07-13T07:23:10.555Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 3: get /upnp/control/wanpppconn1
Jul 13 09:23:11 raspberrypi homebridge[5683]: 2019-07-13T07:23:11.719Z FritzPlatformTR064 [TR064 Debug] ROUTER-HOME-PETER api request 3: Ok (authenticated)
Die api requests gehen hochzählend weiter....
Hat jemand von euch eine Idee?
