Beiträge von marvin14
Leider kommt nun diese Fehlermeldung.
Alles anzeigenmake: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1 make: Verzeichnis „/usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll/build“ wird verlassen gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23) gyp ERR! stack at ChildProcess.emit (events.js:189:13) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12) gyp ERR! System Linux 4.14.98-v7+ gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll gyp ERR! node -v v11.5.0 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! [email protected] install: `node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the [email protected] install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2019-04-07T14_54_32_221Z-debug.log -
Hallo
Ich bekomme folgende Fehlermeldung beim installieren des Plugins
Alles anzeigensudo npm i -g homebridge-gpio-motion-sensor > [email protected] install /usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll > node-gyp rebuild gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/11.5.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll/.node-gyp" gyp WARN install got an error, rolling back install gyp WARN install got an error, rolling back install gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll/.node-gyp' gyp ERR! System Linux 4.14.98-v7+ gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /usr/local/lib/node_modules/homebridge-gpio-motion-sensor/node_modules/epoll gyp ERR! node -v v11.5.0 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! [email protected] install: `node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the [email protected] install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2019-04-06T14_40_42_668Z-debug.logMeine node version ist: 11.5.0
Meine npm version ist: 6.9.0
Meine Homebridge Version ist: 0.4.48
Bisher hat die Installation von Plugins immer problemlos funktioniert.
Kann jemand helfen?
