Hallo Zusammen,
hätte da ein Problem und komme beim installieren des plugins nicht weiter.
Hoffe ihr könnt mir helfen.
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli '/usr/local/bin/npm',
1 verbose cli 'install',
1 verbose cli '-g',
1 verbose cli 'homebridge-webos-tv' ]
2 info using [email protected]
3 info using [email protected]
4 verbose npm-session 076c6f27008d053f
5 silly install loadCurrentTree
6 silly install readGlobalPackageData
7 http fetch GET 304 https://registry.npmjs.org/homebridge-webos-tv 409ms (from cache)
8 silly pacote tag manifest for homebridge-webos-tv@latest fetched in 456ms
9 timing stage:loadCurrentTree Completed in 554ms
10 silly install loadIdealTree
11 silly install cloneCurrentTreeToIdealTree
12 timing stage:loadIdealTree:cloneCurrentTree Completed in 1ms
13 silly install loadShrinkwrap
14 timing stage:loadIdealTree:loadShrinkwrap Completed in 6ms
15 silly install loadAllDepsIntoIdealTree
16 silly resolveWithNewModule [email protected] checking installable status
17 http fetch GET 304 https://registry.npmjs.org/wake_on_lan 239ms (from cache)
18 silly pacote range manifest for wake_on_lan@^0.0.4 fetched in 250ms
19 silly resolveWithNewModule [email protected] checking installable status
20 http fetch GET 304 https://registry.npmjs.org/mkdirp 241ms (from cache)
21 silly pacote range manifest for mkdirp@^0.5.1 fetched in 248ms
22 silly resolveWithNewModule [email protected] checking installable status
23 http fetch GET 304 https://registry.npmjs.org/tcp-ping 935ms (from cache)
24 silly pacote range manifest for tcp-ping@^0.1.1 fetched in 942ms
25 silly resolveWithNewModule [email protected] checking installable status
26 http fetch GET 304 https://registry.npmjs.org/persist-path 929ms (from cache)
27 silly pacote range manifest for persist-path@^1.0.2 fetched in 937ms
28 silly resolveWithNewModule [email protected] checking installable status
29 http fetch GET 304 https://registry.npmjs.org/lgtv2 1155ms (from cache)
30 silly pacote range manifest for lgtv2@^1.4.1 fetched in 1163ms
31 silly resolveWithNewModule [email protected] checking installable status
32 http fetch GET 304 https://registry.npmjs.org/websocket 69ms (from cache)
33 silly pacote range manifest for websocket@^1.0.24 fetched in 87ms
34 silly resolveWithNewModule [email protected] checking installable status
35 http fetch GET 304 https://registry.npmjs.org/minimist 101ms (from cache)
36 silly pacote version manifest for [email protected] fetched in 114ms
37 silly resolveWithNewModule [email protected] checking installable status
38 http fetch GET 304 https://registry.npmjs.org/typedarray-to-buffer 166ms (from cache)
39 silly fetchPackageMetaData error for typedarray-to-buffer@^3.1.5 ENOTDIR: not a directory, open '/root/.npm/_cacache/index-v5/75/81/a53962ded4784c698585ef1042ac3c2667bbcfe30ca1380f0bc8f1200828'
40 http fetch GET 304 https://registry.npmjs.org/yaeti 181ms (from cache)
41 silly pacote range manifest for yaeti@^0.0.6 fetched in 190ms
42 silly resolveWithNewModule [email protected] checking installable status
43 http fetch GET 304 https://registry.npmjs.org/debug 203ms (from cache)
44 silly pacote range manifest for debug@^2.2.0 fetched in 215ms
45 silly resolveWithNewModule [email protected] checking installable status
46 http fetch GET 304 https://registry.npmjs.org/nan 215ms (from cache)
47 silly pacote range manifest for nan@^2.11.0 fetched in 227ms
48 silly resolveWithNewModule [email protected] checking installable status
49 timing stage:rollbackFailedOptional Completed in 3ms
50 timing stage:runTopLevelLifecycles Completed in 2253ms
51 verbose stack Error: ENOTDIR: not a directory, open '/root/.npm/_cacache/index-v5/75/81/a53962ded4784c698585ef1042ac3c2667bbcfe30ca1380f0bc8f1200828'
52 verbose cwd /root/.npm/_logs
53 verbose Linux 4.19.42-v7+
54 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "homebridge-webos-tv"
55 verbose node v11.12.0
56 verbose npm v6.7.0
57 error path /root/.npm/_cacache/index-v5/75/81/a53962ded4784c698585ef1042ac3c2667bbcfe30ca1380f0bc8f1200828
58 error code ENOTDIR
59 error errno -20
60 error syscall open
61 error ENOTDIR: not a directory, open '/root/.npm/_cacache/index-v5/75/81/a53962ded4784c698585ef1042ac3c2667bbcfe30ca1380f0bc8f1200828'
62 verbose exit [ -20, true ]
