Beiträge von FranzL
    Ok, ich bin am Ende ?(
    Alles noch mal von vorne durchgeführt. Leider ohne Erfolg.
    Der QR Code wird nur halb dargestellt.
    Dazu diese Informationen.
    pi@raspberrypi:~ $ sudo nano /var/homebridge/config.json
    pi@raspberrypi:~ $ sudo systemctl start homebridge
    pi@raspberrypi:~ $ sudo systemctl restart homebridge
    pi@raspberrypi:~ $ sudo journalctl -fau homebridge
    -- Logs begin at Mon 2019-04-08 12:25:34 CEST. --
    Jun 16 19:48:41 raspberrypi homebridge[5066]:
    Jun 16 19:48:41 raspberrypi homebridge[5066]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    Jun 16 19:48:41 raspberrypi homebridge[5066]: ??????????????
    Jun 16 19:48:41 raspberrypi homebridge[5066]: ? 031-45-154 ?
    Jun 16 19:48:41 raspberrypi homebridge[5066]: [6/16/2019, 7:48:41 PM] Homebridge is running on port 51826.
    Jun 16 19:48:45 raspberrypi homebridge[5066]: [6/16/2019, 7:48:45 PM] [Config] Console v4.5.1 is listening on :: port 8080
    ^[^[sudo systemctl start homebridge
    Start Homebridge geht auch nicht.
    Wo finde ich weitere Hilfen?
    Danke,
    habe ich dann hinbekommen.
    Sah soweit gut aus.
    Jun 16 16:23:37 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
    Jun 16 16:23:37 raspberrypi homebridge[17695]: [6/16/2019, 4:23:37 PM] Got SIGTERM, shutting down Homebridge...
    Jun 16 16:23:42 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
    Jun 16 16:23:42 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
    Jun 16 16:23:42 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
    Jun 16 16:23:42 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Jun 16 16:23:42 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] Loaded config.json with 0 accessories and 0 platforms.
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] ---
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] No plugins found. See the README for information on installing plugins.
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] Loading 0 platforms...
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] Loading 0 accessories...
    Jun 16 16:23:44 raspberrypi homebridge[17733]: Setup Payload:
    Jun 16 16:23:44 raspberrypi homebridge[17733]: X-HM://0023ISYWY23NM
    Jun 16 16:23:44 raspberrypi homebridge[17733]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
    Jun 16 16:23:44 raspberrypi homebridge[17733]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    Jun 16 16:23:44 raspberrypi homebridge[17733]: ??????????????
    Jun 16 16:23:44 raspberrypi homebridge[17733]: ? 031-45-154 ?
    Jun 16 16:23:44 raspberrypi homebridge[17733]: [6/16/2019, 4:23:44 PM] Homebridge is running on port 51826.
    Aber bei NeuStart und Passworteingabe scheitert es dann!
    Uwes-iMac-Lan:~ lammers$ sudo systemctl start homebridge
    Password:
    sudo: systemctl: command not found
    Wo liegt der haken?
    Muss ich noch mal von vorne beginnen?
    Moin,
    ich bin die Installationsanleitung für Homebridge Punkt für Punkt durchgegangen. Bis zur Installation von Node hat alles bestens funktioniert.
    Nun soll der Befehl: wget https://nodejs.org/dist/latest-v10.x/node-v10.15.3-linux-armv7l.tar.gz
    eingegeben werden.
    Daraufhin bekomme ich die Fehlermeldung:
    pi@raspberrypi:~ $ wget https://nodejs.org/dist/latest….15.3-linux-armv7l.tar.gz
    --2019-06-16 15:35:13-- https://nodejs.org/dist/latest….15.3-linux-armv7l.tar.gz
    Resolving nodejs.org (nodejs.org)... 104.20.23.46, 104.20.22.46, 2606:4700:10::6814:162e, ...
    Connecting to nodejs.org (nodejs.org)|104.20.23.46|:443... connected.
    HTTP request sent, awaiting response... 404 Not Found
    2019-06-16 15:35:14 ERROR 404: Not Found.
    Ich habe einen Pi 3 B,+ armv7l
    Finde dazu hier keine weiteren Beiträge.
    Kann mir jemand weiterhelfen?
