Beiträge von sebastian325
    Habe das Plugin aus der Anleitung probiert und dann immer mal welche die hier im Thread genannt wurden, "sämtliche" ist natürlich schwer greifbar.
    Im Moment läuft das aus der 1. Anleitung -> Version aus dem Link von dir.
    Der Log von HB:
    Jul 29 20:52:48 raspberrypi homebridge[4548]: [7/29/2019, 8:52:48 PM] [Config] Homebridge restart request received
    Jul 29 20:52:48 raspberrypi homebridge[4548]: [7/29/2019, 8:52:48 PM] [Config] Executing restart command: sudo -n systemctl restart homebridge
    Jul 29 20:52:48 raspberrypi sudo[4669]: homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart homebridge
    Jul 29 20:52:48 raspberrypi sudo[4669]: pam_unix(sudo:session): session opened for user root by (uid=0)
    Jul 29 20:52:48 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
    Jul 29 20:52:48 raspberrypi homebridge[4548]: [7/29/2019, 8:52:48 PM] Got SIGTERM, shutting down Homebridge...
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Jul 29 20:52:53 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Found left-over process 4572 (homebridge-conf) in control group while starting unit. Ignoring.
    Jul 29 20:52:53 raspberrypi systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Found left-over process 4668 (sh) in control group while starting unit. Ignoring.
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Found left-over process 4669 (sudo) in control group while starting unit. Ignoring.
    Jul 29 20:52:53 raspberrypi systemd[1]: homebridge.service: Found left-over process 4674 (systemctl) in control group while starting unit. Ignoring.
    Jul 29 20:52:53 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Jul 29 20:52:53 raspberrypi sudo[4669]: pam_unix(sudo:session): session closed for user root
    Jul 29 20:52:55 raspberrypi homebridge[4675]: [7/29/2019, 8:52:55 PM] Loaded config.json with 1 accessories and 3 platforms.
    Jul 29 20:52:55 raspberrypi homebridge[4675]: [7/29/2019, 8:52:55 PM] ---
    Jul 29 20:52:55 raspberrypi homebridge[4675]: [7/29/2019, 8:52:55 PM] Loaded plugin: homebridge-config-ui-x
    Jul 29 20:52:55 raspberrypi homebridge[4675]: [7/29/2019, 8:52:55 PM] Registering platform 'homebridge-config-ui-x.config'
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Loaded plugin: homebridge-mi-aqara
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Registering platform 'homebridge-mi-aqara.MiAqaraPlatform'
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] ---
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Loaded plugin: homebridge-tado-ac
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Registering platform 'homebridge-tado-ac.TadoAC'
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Loaded plugin: homebridge-weather
    Jul 29 20:52:56 raspberrypi homebridge[4675]: [7/29/2019, 8:52:56 PM] Registering accessory 'homebridge-weather.Weather'
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] Loading 3 platforms...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [Config] Initializing config platform...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [Config] Spawning homebridge-config-ui-x with PID 4698
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [TadoAC] Initializing TadoAC platform...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] Initializing MiAqaraPlatform platform...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO]**************************************************************
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO] MiAqaraPlatform v0.8.0 By YinHang
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO] GitHub: https://github.com/YinHangCode/homebridge-mi-aqara
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO] QQ Group: 107927710
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO]start success...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO]config gateways: 7811DCB250E1
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO]binding to the default interface
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] Loading 1 accessories...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [OpenWeatherMap Temperature] Initializing Weather accessory...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [MiAqaraPlatform] [INFO]Aqara LAN protocol server is listening on port: 9898
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [TadoAC] Found new Zone: Schlafzimmer (3) ...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: [7/29/2019, 8:52:57 PM] [TadoAC] Initializing platform accessory 'Schlafzimmer Tado'...
    Jul 29 20:52:57 raspberrypi homebridge[4675]: HAP Warning: Characteristic 00000025-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 0000004A-0000-1000-8000-0026BB765291. Adding anyway.
    Jul 29 20:52:58 raspberrypi homebridge[4675]: Setup Payload:
    Jul 29 20:52:58 raspberrypi homebridge[4675]: X-HM://0023ISYWY1813
    Jul 29 20:52:58 raspberrypi homebridge[4675]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
    Jul 29 20:52:58 raspberrypi homebridge[4675]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    Jul 29 20:52:58 raspberrypi homebridge[4675]: ??????????????
    Jul 29 20:52:58 raspberrypi homebridge[4675]: ? 031-45-154 ?
    Jul 29 20:52:58 raspberrypi homebridge[4675]: [7/29/2019, 8:52:58 PM] Homebridge is running on port 51826.
    Jul 29 20:53:01 raspberrypi homebridge[4675]: [7/29/2019, 8:53:01 PM] [Config] Console v4.5.1 is listening on :: port 8080
    config.json
    "bridge": {
    "name": "Homebridge",
    "port": 51826,
    "pin": "031-45-154"
    "platforms": [
    "platform": "config",
    "name": "Config",
    "port": 8080,
    "auth": "form",
    "theme": "red",
    "sudo": true,
    "log": {
    "method": "custom",
    "platform": "TadoAC",
    "username": "xxxx",
    "password": "xxxx"
    "platform": "MiAqaraPlatform",
    "gateways": {
    "xxxx": "xxxx"
    "accessories": [
    "accessory": "Weather",
    "apikey": "xxxx",
    "location": "xxxx",
    "name": "OpenWeatherMap Temperature"
    Hat jemand schon ne Ahnung was es sein könnte?
    Hallo Zusammen,
    bin seit gestern am Versuchen das Tado AC Plugin zum Laufen zu bringen.
    Installieren lässt sich alles einwandfrei, wenn jedoch die Konfigurationsdaten eingegeben werden hängt sich die Homebridge komplett auf.
    Versucht habe ich bereits die Easyconfig, Advancedconfig sowie eine aus einer alten Version.
    Anderen Plugins funktionieren einwandfrei nur eben die Tado AC Smart Control nicht.
    Gibts noch andere mit diesem Problem?
    Habe mein Problem selbst lösen könne, war ein Fehler von meiner Seite.
    Ich hatte das Gerät als Accessorie und nicht als Plattform definiert
