wie doof von mir, aber ich habe nicht mehr daran gedacht, dass in der Anleitung auch eine Befehlssammlung ist. Ich habe die letzten Monate eigentlich immer auf die Sammlung von Nastra genutzt.
Hier nun mein log:
Logs begin at Thu 2016-11-03 18:16:42 CET. --
Jan 16 19:41:03 raspberrypi homebridge[351]: [1/16/2020, 7:41:03 PM] [Hue] Schlafzimmer: set homekit status fault from 1 to 0
Jan 16 19:41:58 raspberrypi homebridge[351]: [1/16/2020, 7:41:58 PM] [Hue] Licht Mirko: set homekit status fault from 0 to 1
Jan 16 19:42:03 raspberrypi homebridge[351]: [1/16/2020, 7:42:03 PM] [Hue] Schlafzimmer: set homekit status fault from 0 to 1
Jan 16 20:06:40 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Jan 16 20:06:40 raspberrypi homebridge[351]: [1/16/2020, 8:06:40 PM] Got SIGTERM, shutting down Homebridge...
Jan 16 20:06:45 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 16 20:06:45 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 16 20:06:45 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Jan 16 20:06:45 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 16 20:06:45 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded config.json with 3 accessories and 5 platforms.
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] ---
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Plugin /usr/local/lib/node_modules/homebridge-lib package.json does not contain the keyword 'homebridge-plugin'.
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded plugin: homebridge-cmdswitch2
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Registering platform 'homebridge-cmdswitch2.cmdSwitch2'
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded plugin: homebridge-cmdtrigger
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Registering accessory 'homebridge-cmdtrigger.CmdTrigger'
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded plugin: homebridge-config-ui-x
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Registering platform 'homebridge-config-ui-x.config'
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded plugin: homebridge-dummy
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Registering accessory 'homebridge-dummy.DummySwitch'
Jan 16 20:06:47 raspberrypi homebridge[16842]: [1/16/2020, 8:06:47 PM] Loaded plugin: homebridge-fritz
Jan 16 20:06:48 raspberrypi homebridge[16842]: [1/16/2020, 8:06:48 PM] Registering platform 'homebridge-fritz.Fritz!Box'
Jan 16 20:06:48 raspberrypi homebridge[16842]: [1/16/2020, 8:06:48 PM] ---
Jan 16 20:06:48 raspberrypi homebridge[16842]: [1/16/2020, 8:06:48 PM] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^12.14.0 which does not satisfy the current Node version of v10.16.0. You may need to upgrade your installation of Node.
Jan 16 20:06:51 raspberrypi homebridge[16842]: [1/16/2020, 8:06:51 PM] Loaded plugin: homebridge-hue
Jan 16 20:06:51 raspberrypi homebridge[16842]: [1/16/2020, 8:06:51 PM] Registering platform 'homebridge-hue.Hue'
Jan 16 20:06:51 raspberrypi homebridge[16842]: [1/16/2020, 8:06:51 PM] ---
Jan 16 20:06:52 raspberrypi homebridge[16842]: [1/16/2020, 8:06:52 PM] Loaded plugin: homebridge-mi-flower-care
Jan 16 20:06:53 raspberrypi homebridge[16842]: [1/16/2020, 8:06:53 PM] Registering accessory 'homebridge-mi-flower-care.mi-flower-care'
Jan 16 20:06:53 raspberrypi homebridge[16842]: [1/16/2020, 8:06:53 PM] ---
Jan 16 20:06:53 raspberrypi homebridge[16842]: [1/16/2020, 8:06:53 PM] Loaded plugin: homebridge-mi-hygrothermograph
Jan 16 20:06:55 raspberrypi homebridge[16842]: [1/16/2020, 8:06:55 PM] Registering accessory 'homebridge-mi-hygrothermograph.Hygrotermograph'
Jan 16 20:06:55 raspberrypi homebridge[16842]: [1/16/2020, 8:06:55 PM] ---
Jan 16 20:06:55 raspberrypi homebridge[16842]: [1/16/2020, 8:06:55 PM] Loaded plugin: homebridge-server
Jan 16 20:06:55 raspberrypi homebridge[16842]: [1/16/2020, 8:06:55 PM] Registering platform 'homebridge-server.Server'
Jan 16 20:06:56 raspberrypi homebridge[16842]: [1/16/2020, 8:06:56 PM] Loaded plugin: homebridge-weather-plus
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] Registering platform 'homebridge-weather-plus.WeatherPlus'
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] ---
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] Loading 5 platforms...
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Config] Initializing config platform...
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Config] Spawning homebridge-config-ui-x with PID 16873
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Homebridge Server] Initializing Server platform...
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Hue] Initializing Hue platform...
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Hue] homebridge-hue v0.11.45, node v10.16.0, homebridge v0.4.50
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [Hue] warning: not using recommended node version v12.14.0 LTS
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [My FritzBox] Initializing Fritz!Box platform...
Jan 16 20:06:58 raspberrypi homebridge[16842]: [1/16/2020, 8:06:58 PM] [WeatherPlus] Initializing WeatherPlus platform...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [WeatherPlus] Adding station with weather service Dark Sky named 'Außentemp.'
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [WeatherPlus] Initializing platform accessory 'Außentemp.'...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [WeatherPlus] Initializing platform accessory 'Vorhersage In 1 Day'...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [WeatherPlus] Initializing platform accessory 'Vorhersage In 2 Days'...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] Loading 3 accessories...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [30 Sec. Schalter] Initializing DummySwitch accessory...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [Vorheizen] Initializing CmdTrigger accessory...
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [Kaffee läuft] Initializing CmdTrigger accessory...
Jan 16 20:06:59 raspberrypi homebridge[16842]: Load homebridge-cmdswitch2.cmdSwitch2
Jan 16 20:06:59 raspberrypi homebridge[16842]: Failed to find plugin to handle accessory harmonyhub-TV
Jan 16 20:06:59 raspberrypi homebridge[16842]: Failed to find plugin to handle accessory harmonyhub-Fernsehen
Jan 16 20:06:59 raspberrypi homebridge[16842]: Failed to find plugin to handle accessory harmonyhub-Raspi 3 wiedergabe
Jan 16 20:06:59 raspberrypi homebridge[16842]: Failed to find plugin to handle accessory harmonyhub-Switch
Jan 16 20:06:59 raspberrypi homebridge[16842]: Failed to find plugin to handle accessory harmonyhub-Apple TV wiedergabe
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [Homebridge Server] is listening on: http://192.168.178.40:8765
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [Homebridge Server] is listening on: http://192.168.178.41:8765
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [Hue] warning: latest version: homebridge-hue v0.11.47
Jan 16 20:06:59 raspberrypi homebridge[16842]: [1/16/2020, 8:06:59 PM] [My FritzBox] Initializing Fritz!Box platform accessories failed - wrong user credentials?
Jan 16 20:07:04 raspberrypi homebridge[16842]: [1/16/2020, 8:07:04 PM] [Hue] Philips hue: Philips BSB002 bridge v1935144040, api v1.35.0
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Philips hue: 6 accessories
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Philips hue'...
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Philips hue: 2 services
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Wagenfeld Leuchte'...
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Stehleuchte'...
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Licht Mirko'...
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Schlafzimmer'...
Jan 16 20:07:05 raspberrypi homebridge[16842]: [1/16/2020, 8:07:05 PM] [Hue] Initializing platform accessory 'Vitrine'...
Jan 16 20:07:06 raspberrypi homebridge[16842]: [1/16/2020, 8:07:06 PM] [Config] Homebridge Config UI X v4.6.6 is listening on :: port 8080
lg
