Beiträge von rebellionFlAsH
    Danke erstmal für den Support,
    ich habe in die Zeile "cache_directory" den Eintrag ersetzt.
    Der Fehler wurde leider durch einen neuen ersetzt ?(
    Jul 23 20:31:36 raspberrypi homebridge[815]: [7/23/2019, 8:31:36 PM] [HttpWebHooks] Initializing HttpWebHooks platform...
    Jul 23 20:31:36 raspberrypi homebridge[815]: [7/23/2019, 8:31:36 PM] Error: [PARSE-ERROR] /var/homebridge/persist/AccessoryInfo.CC223DE3CE30.json does not look like a valid storage file!
    Jul 23 20:31:36 raspberrypi homebridge[815]: at LocalStorage.parseFileSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/local-storage.js:647:19)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/local-storage.js:596:26)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/local-storage.js:141:14)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/node-persist.js:37:32)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at new HttpWebHooksPlatform (/usr/local/lib/node_modules/homebridge-http-webhooks/index.js:48:16)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:337:32)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Module._compile (internal/modules/cjs/loader.js:776:30)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at Function.Module.runMain (internal/modules/cjs/loader.js:829:12)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at startup (internal/bootstrap/node.js:283:19)
    Jul 23 20:31:36 raspberrypi homebridge[815]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    Jul 23 20:31:36 raspberrypi homebridge[815]: [7/23/2019, 8:31:36 PM] Got SIGTERM, shutting down Homebridge...
    Schönen guten Tag,
    ich habe leider ein Berechtigungsproblem mit meiner Homebridge, das ich ums verrecken nicht gelöst bekomme und hoffe Ihr könnt mitr helfen.
    Ich habe eine Homebridge nach Anleitung von dieser HP erstellt.
    User "Homebridge" ist angelegt und für die Homebridge zuständig.
    Nach installieren des Plugins "homebridge-http-webhooks" habe ich die config.json angepasst und Neugestartet:
    Leider bricht die Homebridge mit folgenden Fehler ab:
    Jul 22 17:07:42 raspberrypi homebridge[4175]: [7/22/2019, 5:07:42 PM] [HttpWebHooks] Initializing HttpWebHooks platform...
    Jul 22 17:07:42 raspberrypi homebridge[4175]: [7/22/2019, 5:07:42 PM] Error: EACCES: permission denied, mkdir '/.node-persist'
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Object.mkdirSync (fs.js:774:3)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at sync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/mkdirp/index.js:71:13)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Function.sync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/mkdirp/index.js:77:24)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/local-storage.js:600:20)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/local-storage.js:141:14)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-http-webhooks/node_modules/node-persist/src/node-persist.js:37:32)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at new HttpWebHooksPlatform (/usr/local/lib/node_modules/homebridge-http-webhooks/index.js:48:16)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:337:32)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Module._compile (internal/modules/cjs/loader.js:721:30)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:732:10)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Module.load (internal/modules/cjs/loader.js:620:32)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at tryModuleLoad (internal/modules/cjs/loader.js:560:12)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Function.Module._load (internal/modules/cjs/loader.js:552:3)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at Function.Module.runMain (internal/modules/cjs/loader.js:774:12)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at executeUserCode (internal/bootstrap/node.js:499:15)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: at startMainThreadExecution (internal/bootstrap/node.js:436:3)
    Jul 22 17:07:42 raspberrypi homebridge[4175]: [7/22/2019, 5:07:42 PM] Got SIGTERM, shutting down Homebridge...
    Auszug config.json
    "platform": "HttpWebHooks",
    "webhook_port": "51828",
    "cache_directory": "./.node-persist/storage",
    "lockmechanisms": [
    "id": "wohnung_schloss",
    "name": "Haustürschloss",
    "open_url": "xxxx",
    "open_method": "GET",
    "close_url": "xxxx",
    "close_method": "GET"
