Beiträge von Mikha
    Habe gerade versucht node.js der Anleitung nach upzudaten, doch bei sudo npm rebuild --unsafe-perm. kriege ich Fehlermeldungen. Wohl keine Schreibrechte...
    Bei mir läuft HOOBS.
    Kann jmd. helfen?
    hoobs@hoobs:~ $ cd /usr/local/lib/node_modules/
    hoobs@hoobs:/usr/local/lib/node_modules $ sudo npm rebuild --unsafe-perm.
    > @nestjs/[email protected] postinstall /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@nestjs/core
    > opencollective || exit 0
    Thanks for installing nest ?
                                Please consider donating to our open collective
    to help us maintain this package.
    Number of contributors: 103
    Number of backers: 210
    Annual budget: $68,829
    Current balance: $7,201
    ? Become a partner: https://opencollective.com/nest/donate
    > [email protected] install /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/node-pty-prebuilt-multiarch
    > prebuild-install || node scripts/install.js
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp ERR! clean error
    gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
    gyp ERR! System Linux 4.19.58-v7+
    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/node-pty-prebuilt-multiarch
    gyp ERR! node -v v10.16.1
    gyp ERR! node-gyp -v v5.0.3
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! [email protected] install: `prebuild-install || node scripts/install.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the [email protected] install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! /root/.npm/_logs/2019-08-06T19_44_08_844Z-debug.log
    hoobs@hoobs:/usr/local/lib/node_modules $ cd
    hoobs@hoobs:~ $ Homebridge -I
    -bash: Homebridge: command not found
    hoobs@hoobs:~ $ sudo systemctl restart homebridge
    hoobs@hoobs:~ $ packet_write_wait: Connection to 192.168.1.108 port 22: Broken pipe
