Moin Moin,
zunächst einmal sage ich vielen Dank für diese interessante Seite und das informative Forum! Als Apple-User hat mich sofort die Neugier gepackt, und ich habe mir einen Raspberry Pi besorgt. Die Installation der Homebridge war recht schnell erledigt, aber leider bleibe ich bei der Installation des Homebridge-Fritz-Plugin mit folgendem Fehler nicht weiter:
Started Node.js HomeKit Server.
[11/24/2019, 07:02:35] Loaded config.json with 0 accessories and 2 platforms.
[11/24/2019, 07:02:35] ---
[11/24/2019, 07:02:35] Loaded plugin: homebridge-config-ui-x
[11/24/2019, 07:02:35] Registering platform 'homebridge-config-ui-x.config'
[11/24/2019, 07:02:36] Loaded plugin: homebridge-fritz
[11/24/2019, 07:02:36] Registering platform 'homebridge-fritz.Fritz!Box'
[11/24/2019, 07:02:36] ---
[11/24/2019, 07:02:36] Loading 2 platforms...
[11/24/2019, 07:02:36] [Config] Initializing config platform...
[11/24/2019, 07:02:36] [Config] Spawning homebridge-config-ui-x with PID 454
[11/24/2019, 07:02:36] [gfmnet] Initializing Fritz!Box platform...
[11/24/2019, 07:02:36] Loading 0 accessories...
[11/24/2019, 07:02:36] [gfmnet] Initializing Fritz!Box platform accessories failed - wrong user credentials?
[11/24/2019, 07:02:40] [Config] Homebridge Config UI X v4.6.3 is listening on :: port 8080
[11/24/2019, 07:04:36] [Config] [HapClient] Cannot load accessories. No Homebridge instances have been discovered.
Meine config.json sieht folgendermaßen aus:
"bridge": {
"name": "homebridge",
"username": "CC:22:3D:E3:CE:32",
"port": 51826,
"pin": "031-45-156"
"platforms": [
"platform": "config",
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "red",
"sudo": true,
"log": {
"method": "custom",
"platform": "Fritz!Box",
"name": "gfmnet",
"username": "root",
"password": "passwort",
"url": "http://192.168.178.1",
"interval": 60,
"concurrent": false,
"devices": {
"wifi": {
"name": "Guest WLAN",
"display": true
"options": {
"strictSSL": false
"accessories": []
Es spielt keine Rolle, ob ich als Benutzer 'root' nehme oder ob ich einen Benutzer in der Fritzbox anlege und die Fritzbox-Anmeldung auf "Username und Passwort" umstelle. Trage ich diese Benutzerdaten dann in die config.json ein, habe ich den gleichen Fehler.
Gibt es sonst noch irgendwas, was diesen Fehler verursachen kann? Hat jemand vielleicht eine Idee?
