Ok, habe es nochmal versucht, ohne die klammern und das Samsung TV gelöscht. Jetzt läuft die Homebridge.
Vielen Dank für eure Hilfe.
[2019-12-30 17:24:59] [Config] Homebridge Config UI X v4.6.7 is listening on :: port 8080
homebridge.service: Main process exited, code=exited, status=143/n/a
homebridge.service: Failed with result 'exit-code'.
homebridge.service: Service RestartSec=10s expired, scheduling restart.
homebridge.service: Scheduled restart job, restart counter is at 17.
Stopped Node.js HomeKit Server.
Started Node.js HomeKit Server.
[2019-12-30 17:25:12] Loaded config.json with 2 accessories and 3 platforms.
[2019-12-30 17:25:12] ---
[2019-12-30 17:25:12] Loaded plugin: homebridge-config-ui-x
[2019-12-30 17:25:12] Registering platform 'homebridge-config-ui-x.config'
[2019-12-30 17:25:12] Loaded plugin: homebridge-fakebulb
[2019-12-30 17:25:12] Registering accessory 'homebridge-fakebulb.FakeBulb'
[2019-12-30 17:25:13] Loaded plugin: homebridge-sonos-multiroom
[2019-12-30 17:25:13] Registering platform 'homebridge-sonos-multiroom.SonosMultiroomPlatform'
[2019-12-30 17:25:13] ---
[2019-12-30 17:25:13] Loaded plugin: homebridge-zway
[2019-12-30 17:25:13] Registering accessory 'homebridge-zway.ZWayServer'
[2019-12-30 17:25:13] Registering platform 'homebridge-zway.ZWayServer'
[2019-12-30 17:25:13] Loading 3 platforms...
[2019-12-30 17:25:13] [Config] Initializing config platform...
[2019-12-30 17:25:13] [Config] Spawning homebridge-config-ui-x with PID 7622
[2019-12-30 17:25:13] [SonosMultiroomPlatform] Initializing SonosMultiroomPlatform platform...
[2019-12-30 17:25:13] [SonosMultiroomPlatform] Homebridge API available.
[2019-12-30 17:25:13] [ZWayServer] Initializing ZWayServer platform...
[2019-12-30 17:25:13] Loading 2 accessories...
[2019-12-30 17:25:13] [Test lamp] Initializing FakeBulb accessory...
[2019-12-30 17:25:13] [Test lamp] Starting a fake bulb device with name 'Lamp1'...
[2019-12-30 17:25:13] Error: The requested accessory 'SamsungTV' was not registered by any plugin.
at API.accessory (/usr/local/lib/node_modules/homebridge/lib/api.js:64:13)
at Server._loadAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:297:42)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:91:38)
at Module._compile (internal/modules/cjs/loader.js:959:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:995:10)
at Module.load (internal/modules/cjs/loader.js:815:32)
at Function.Module._load (internal/modules/cjs/loader.js:727:14)
at Function.Module.runMain (internal/modules/cjs/loader.js:1047:10)
[2019-12-30 17:25:13] Got SIGTERM, shutting down Homebridge...
[2019-12-30 17:25:16] [Config] Homebridge Config UI X v4.6.7 is listening on :: port 8080
Websocket failed to connect. Is the server running?
Ja die Werte habe ich angepasst. Bin mir aber nicht sicher ob bei Login und Password die [ ] beibehalten werden müssen?
Nach https://smartapfel.de/homebridge/plugins-installieren/ Schritt 1-3, danach für Z-Wave http://simply-smarthome.de/homekit-rollaeden.
Wie kann ich den Log auslesen?
Jsonlint.com erkennt keine Fehler.
"bridge": {
"name": "Homebridge",
"port": 51826,
"pin": "031-45-154"
"platforms": [{
"platform": "config",
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "red",
"sudo": true,
"log": {
"method": "custom",
"platform": "SonosMultiroomPlatform",
"discoveryTimeout": 5000,
"zones": [{
"name": "Fernsehzimmer",
"isNightModeEnabled": true,
"isSpeechEnhancementEnabled": true,
"priorities": [
"Fernsehzimmer",
"Bathroom"
"isApiEnabled": false,
"apiPort": 40809,
"apiToken": "<YOUR-TOKEN>"
"platform": "ZWayServer",
"url": "http://your.ip.goes.here:8083/",
"login": "[admin]",
"password": "[password]"
"accessories": [{
"accessory": "FakeBulb",
"name": "Test lamp",
"bulb_name": "Lamp1"
Hallo, ich habe das als Neuling versucht, alles hat geklappt, sobald aber die Config.json angepasst habe, startet die Homebridge nicht mehr.
"platforms": [
"login": "[admin]",
Kann mir da jemand weiter helfen? Vielen dank.
