Beiträge von Jojoelt
    "interval" : 10,
    "platform" : "BraviaOSPlatform",
    "tvs" : [
    "apps" : [
    "Netflix",
    "YouTube"
    "cecInputs" : true,
    "channelInputs" : false,
    "customSpeaker" : true,
    "extraInputs" : false,
    "ip" : "192.168.xxx.xx",
    "mac" : "10:4F:xx:xx:xx:xx",
    "name" : "Sony TV",
    "port" : 80,
    "psk" : "xxxx",
    "speakerType" : "speaker",
    "wol" : false
    Danke s hin für die Hilfe. Trotzdem erscheint die Fehlermeldung. Ich hab sie nochmal angehängt. Immerhin erscheint jetzt ein Lautsprecher in der Home App. Dieser lässt such aber in kleinster Weise ansprechen.
    Gruß Jojo
    die habe ich auch 😬
    "accessories" : [
    "bridge" : {
    "name" : "Homebridge",
    "pin" : "xxxxx",
    "port" : 51826,
    "username" : "xxxxx"
    "description" : "Home Smart Home",
    "platforms" : [
    "name" : "Licht",
    "platform" : "cmdSwitch2",
    "switches" : [
    "manufacturer" : "Wonderlabs",
    "model" : "SwitchBot",
    "name" : "Tiefgarage",
    "off_cmd" : "gatttool -t random -b D2:DA:D5:D3:B6:E8 --char-write-req -a 0x0016 -n 570102",
    "on_cmd" : "gatttool -t random -b D2:DA:D5:D3:B6:E8 --char-write-req -a 0x0016 -n 570101",
    "serial" : "xxxxx",
    "timeout" : 2000
    "auth" : "form",
    "log" : {
    "command" : "journalctl -o cat -n 500 -f -u homebridge",
    "method" : "custom"
    "name" : "Config",
    "platform" : "config",
    "port" : 8080,
    "restart" : "sudo -n systemctl restart homebridge",
    "sudo" : true,
    "temp" : "/sys/class/thermal/thermal_zone0/temp",
    "theme" : "green"
    "interval" : 10,
    "tvs" : [
    "ip" : "xxxxx",
    "name" : "TV",
    "port" : 80,
    "psk" : "xxxxx"
    ich versuche bisher vergeblich mein Bravia TV in Meine Raspi basierte hombridge zu integrieren.
    Folgender Fehler wird mir angezeigt:
    [2/12/2020, 14:24:35] [BraviaOSPlatform] [INFO] Adding new accessory: TV
    [2/12/2020, 14:24:35] [BraviaOSPlatform] [INFO] TV: Initalizing Bravia API with PSK
    [2/12/2020, 14:24:35] [BraviaOSPlatform] [INFO] TV: Cheking authentication...
    [2/12/2020, 14:24:35] Homebridge is running on port 51826.
    [2/12/2020, 14:24:35] [BraviaOSPlatform] [INFO] TV: Authenticated!
    [2/12/2020, 14:24:35] [BraviaOSPlatform] [WARN] TV: TV currently offline, trying to connect (this can take up to 5 minutes) ...
    [2/12/2020, 14:24:42] [Config] Homebridge Config UI X v4.10.1 is listening on :: port 8080
    [2/12/2020, 14:24:45] [BraviaOSPlatform] [INFO] TV: Connection established!
    [2/12/2020, 14:24:45] [BraviaOSPlatform] [ERROR] TV: An error occured while handling accessories!
    [2/12/2020, 14:24:45] [BraviaOSPlatform] [ERROR] {
    "status": 404,
    "message": "Not Found",
    "config": {
    "transformRequest": {},
    "transformResponse": {},
    "timeout": 0,
    "xsrfCookieName": "XSRF-TOKEN",
    "xsrfHeaderName": "X-XSRF-TOKEN",
    "maxContentLength": -1,
    "headers": {
    "Accept": "application/json, text/plain, */*",
    "Content-Type": "application/json",
    "X-Auth-PSK": "xxxx",
    "User-Agent": "axios/0.18.1",
    "Content-Length": 78
    "method": "post",
    "url": "http://IPadresse:80/sony/avContent",
    "data": "{\"id\":1,\"method\":\"getCurrentExternalInputsStatus\",\"version\":\"1.0\",\"params\":[]}"
    "data": {
    "error": [
    404,
    "Not Found"
    Kann mir jemand mit meinem Problem helfen? Danke schon mal vorab.
    Gruß Jojo
