Moin,
ich bin gerade zufällig auf diesen Post gestoßen. Würde das gerne bei mir auch einrichten und habe nun die config.json dahingehend editiert.
Leider funktioniert es bei mir nich
So sieht meine Config nun aus.
"bridge": {
"name": "Homebridge",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration fil$
"platforms": [{
"platform": "HomeMatic",
"name": "HomeMatic CCU2",
"ccu_ip": "192.168.170.28",
"filter_device": [],
"filter_channel": [],
"outlets": [],
"doors": [],
"programs": [],
"accessories": [],
"subsection": "Homekit"
"platforms": [
"platform": "VorwerkVacuumRobot",
"email": "meineemail",
"password": "meinpassword",
"refresh": "120",
"disabled": ["dock", "eco"]
Beim Starten von Homebridge kommt dann folgendes
pi@raspberrypi:~ $ homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[10/28/2017, 6:44:37 PM] Loaded plugin: homebridge-homematic
[10/28/2017, 6:44:37 PM] Registering platform 'homebridge-homematic.HomeMatic'
[10/28/2017, 6:44:37 PM] ---
[10/28/2017, 6:44:38 PM] Loaded plugin: homebridge-vorwerk
[10/28/2017, 6:44:38 PM] Registering platform 'homebridge-vorwerk.VorwerkVacuumRobot'
[10/28/2017, 6:44:38 PM] ---
[10/28/2017, 6:44:38 PM] There was a problem reading your config.json file.
[10/28/2017, 6:44:38 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/lib/node_modules/homebridge/lib/server.js:197
throw err;
SyntaxError: Unexpected string in JSON at position 551
at Object.parse (native)
at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:191:19)
at new Server (/usr/lib/node_modules/homebridge/lib/server.js:52:38)
at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:570:32)
at Object.Module._extensions..js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3)
Wer kann mir sagen was ich falsch mache
Danke
