Als Tipp, schau doch mal im Log von Homebridge nach wenn du die Temperatur änderst bzw den Max!Link Button in Homekit aktivierst. Eventuell gibts da ja einen Fehler.
Error codes
The plugin will report errors from the Max! Cube library to HomeKit but they are only visible in certain HomeKit apps. The code is a bit field, the single bits are as follows:
1device error (generated by Max!) -
2link error (generated by Max!) -
4error sending data to thermostat (generated by plugin)
