Log reiche ich nach, komme da gerade nicht dran.
"bridge": {
"name": "Homebridge BB58",
"username": "0E:A4:71:8B:BB:58",
"port": 51129,
"pin": "471-11-941"
"accessories": [
"name": "Esszimmer ",
"room": "Esszimmer",
"groupCacheLifetime": 15,
"deviceCacheLifetime": 3600,
"accessory": "Sonos"
"platforms": [
"name": "Config",
"port": 8581,
"platform": "config"
"name": "eveatmo platform",
"ttl": 540,
"extra_co2_sensor": false,
"co2_alert_threshold": 1000,
"auth": {
"client_id": "Xxxxxxxxxx",
"client_secret": "Xxxxx",
"username": "Xxxxx",
"password": "xxxx"
"platform": "eveatmo"
"refreshToken": "eyJhbGciOiJIUzUxMiIsImprdSI6Ii9vYXV0aC9pbnRlcm5hbC9qd2tzIiwia2lkIjoiZGVmYXVsdCIsInR5cCI6IkpXVCJ9.Xxxxxxxxxxxxxx.ixWFxIvmwteQbl-WjgagRkeoDRqko63bTAneJyWdUhSurs_wrEFYyj510gWtBrHnpS4Ye-qjO39x6RKQrxMqBQ",
"platform": "Ring"
[9/14/2020, 11:17:40] [Config] Homebridge Config UI X v4.27.1 is listening on :: port 8581
[9/14/2020, 11:17:39] Loaded plugin: [email protected]
[9/14/2020, 11:17:39] Registering platform 'homebridge-ring.Ring'
[9/14/2020, 11:17:39] ---
[9/14/2020, 11:17:40] Loaded plugin: [email protected]
[9/14/2020, 11:17:40] Registering accessory 'homebridge-sonos.Sonos'
[9/14/2020, 11:17:40] ---
[9/14/2020, 11:17:40] Loading 3 platforms...
[9/14/2020, 11:17:40] [Config] Initializing config platform...
[9/14/2020, 11:17:40] [Config] Running in Service Mode
[9/14/2020, 11:17:40] [eveatmo platform] Initializing eveatmo platform...
[9/14/2020, 11:17:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 11:17:43] [Ring] Initializing Ring platform...
[9/14/2020, 11:17:43] Loading 1 accessories...
[9/14/2020, 11:17:43] [Esszimmer ] Initializing Sonos accessory...
[9/14/2020, 11:17:43] [Ring] Configuring cached accessory a9c6526b--4a9a-8fcd-dc7374dee763 Haustür
[9/14/2020, 11:17:43] [Ring] Configuring cached accessory ccc9224c--4fb9-82a6-ec6d702ea082 Gartenkamera
[9/14/2020, 11:17:43] [Ring] Configuring cached accessory 773ceab2--4438-8a0a-b2540d44bf74 Dong
[9/14/2020, 11:17:43] [Ring] Configuring cached accessory 3ef5317a--417f-ae6c-a369742c6fc2 Bornheim Mode
[9/14/2020, 11:17:43] [Esszimmer ] Found a playable device at 192.168.20.28 for room 'Esszimmer'
HAP Warning: Characteristic 00000093-0000--8000-0026BB765291 not in required or optional characteristics for service 0000008D-0000-1000-8000-0026BB765291. Adding anyway.
HAP Warning: Characteristic 00000093--1000-8000-0026BB765291 not in required or optional characteristics for service 0000008D-0000-1000-8000-0026BB765291. Adding anyway.
HAP Warning: Characteristic 00000093-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 0000008D-0000-1000-8000-0026BB765291. Adding anyway.
[9/14/2020, 11:17:44] Initializing platform accessory 'Home Innenmodul'...
[9/14/2020, 11:17:44] Initializing platform accessory 'Home Aussenmodul'...
[9/14/2020, 11:17:44] Initializing platform accessory 'Home Regenmesser'...
[9/14/2020, 11:17:44] Initializing platform accessory 'Home Schlafzimmer'...
[9/14/2020, 11:17:44] Initializing platform accessory 'Home Kinderzimmer'...
Setup Payload:
X-HM://00248ZBWB9XXX
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 471-11-941 │
[9/14/2020, 11:17:44] Homebridge is running on port 51129.
[9/14/2020, 11:17:47] [Ring] Configuring 2 cameras and 4 devices for location "BN" - locationId: 55feaa8f-2a40-4a44-53a1-
[9/14/2020, 11:26:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 11:35:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 11:44:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 11:53:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:02:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:11:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:20:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:29:43] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:33:56] [Esszimmer ] Current volume: 28
[9/14/2020, 12:33:56] [Esszimmer ] Current state for Sonos: playing
[9/14/2020, 12:34:00] [Esszimmer ] Current volume: 28
[9/14/2020, 12:34:00] [Esszimmer ] Current state for Sonos: playing
[9/14/2020, 12:35:29] [Config] Rebooting linux server with command: "sudo -n shutdown -r now"
[9/14/2020, 12:35:29] [HB Supervisor] Stopping services...
[9/14/2020, 12:35:29] Got SIGTERM, shutting down Homebridge...
[9/14/2020, 12:35:34] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[9/14/2020, 12:35:51] [HB Supervisor] OS: Linux 5.4.51-v7+ arm
[9/14/2020, 12:35:51] [HB Supervisor] Node.js v12.18.3 /usr/local/bin/node
[9/14/2020, 12:35:51] [HB Supervisor] Homebridge Path: /usr/local/lib/node_modules/homebridge/bin/homebridge
[9/14/2020, 12:35:51] [HB Supervisor] UI Path: /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
[9/14/2020, 12:35:51] [HB Supervisor] Starting Homebridge with extra flags: -I
[9/14/2020, 12:35:51] [HB Supervisor] Started Homebridge v1.1.6 with PID: 683
[9/14/2020, 12:35:53] Loaded config.json with 1 accessories and 3 platforms.
[9/14/2020, 12:35:53] ---
[9/14/2020, 12:35:56] Loaded plugin: [email protected]
[9/14/2020, 12:35:56] Registering platform 'homebridge-config-ui-x.config'
[9/14/2020, 12:35:56] ---
[9/14/2020, 12:35:57] Loaded plugin: [email protected]
[9/14/2020, 12:35:57] Registering platform 'homebridge-eveatmo.eveatmo'
[9/14/2020, 12:35:57] ---
[9/14/2020, 12:36:00] [Config] Homebridge Config UI X v4.27.1 is listening on :: port 8581
[9/14/2020, 12:36:00] Loaded plugin: [email protected]
[9/14/2020, 12:36:00] Registering platform 'homebridge-ring.Ring'
[9/14/2020, 12:36:00] ---
[9/14/2020, 12:36:00] Registering accessory 'homebridge-sonos.Sonos'
[9/14/2020, 12:36:00] Loading 3 platforms...
[9/14/2020, 12:36:00] [Config] Initializing config platform...
[9/14/2020, 12:36:00] [Config] Running in Service Mode
[9/14/2020, 12:36:00] [eveatmo platform] Initializing eveatmo platform...
[9/14/2020, 12:36:05] [eveatmo platform] Loading new data from API for: weatherstation
[9/14/2020, 12:36:05] [Ring] Initializing Ring platform...
[9/14/2020, 12:36:05] Loading 1 accessories...
[9/14/2020, 12:36:05] [Esszimmer ] Initializing Sonos accessory...
[9/14/2020, 12:36:05] [Ring] Configuring cached accessory a9c6526b--4a9a-8fcd-dc7374dee763 Haustür
[9/14/2020, 12:36:05] [Ring] Configuring cached accessory ccc9224c--4fb9-82a6-ec6d702ea082 Gartenkamera
[9/14/2020, 12:36:05] [Ring] Configuring cached accessory 773ceab2--4438-8a0a-b2540d44bf74 Dong
[9/14/2020, 12:36:05] [Ring] Configuring cached accessory 3ef5317a--417f-ae6c-a369742c6fc2 Bornheim Mode
[9/14/2020, 12:36:05] [Ring] Request for machine id timed out. Falling back to random session id
[9/14/2020, 12:36:05] [Esszimmer ] Found a playable device at 192.168.20.28 for room 'Esszimmer'
[9/14/2020, 12:36:07] Initializing platform accessory 'Home Innenmodul'...
[9/14/2020, 12:36:07] Initializing platform accessory 'Home Aussenmodul'...
[9/14/2020, 12:36:07] Initializing platform accessory 'Home Regenmesser'...
[9/14/2020, 12:36:07] Initializing platform accessory 'Home Schlafzimmer'...
[9/14/2020, 12:36:07] Initializing platform accessory 'Home Kinderzimmer'...
Setup Payload:
│ 471-11-941 │
[9/14/2020, 12:36:07] Homebridge is running on port 51129.
[9/14/2020, 12:36:10] [Ring] 404 from endpoint https://api.ring.com/clients_api/ring_devices
[9/14/2020, 12:36:10] [Ring] Session hardware_id not found. Creating a new session and trying again.
[9/14/2020, 12:36:11] [Ring] Configuring 2 cameras and 4 devices for location "Bornheim" - locationId: 55feaa8f-2a40-4a44-53a1-00c3d8390e73
[9/14/2020, 12:36:23] [Esszimmer ] Current volume: 28
[9/14/2020, 12:36:23] [Esszimmer ] Current state for Sonos: playing
[9/14/2020, 12:36:27] [Esszimmer ] Current state for Sonos: playing
[9/14/2020, 12:36:27] [Esszimmer ] Current volume: 28
[9/14/2020, 12:45:16] [eveatmo platform] Loading new data from API for: weatherstation
