hab den fehler gerade gefunden
"ssl": true,
aus der config und schon gehts ka warum aber es geht
"ssl": true,
mhh evtl hat da noch jemand nen tipp für mich
EDIT:
Hier mal der Log wenn fhem beendet ist ![]()
pi@octopi:~ $ sudo /etc/init.d/fhem status
fhem is running
pi@octopi:~ $ sudo /etc/init.d/fhem stop
Stopping fhem...
pi@octopi:~ $ homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[11/19/2017, 3:36:04 PM] Loaded plugin: homebridge-fhem
homebridge API version: 2.2
this homebridge-fhem 0.3.7
[11/19/2017, 3:36:04 PM] Registering platform 'homebridge-fhem.FHEM'
[11/19/2017, 3:36:04 PM] ---
[11/19/2017, 3:36:04 PM] Loaded config.json with 0 accessories and 1 platforms.
[11/19/2017, 3:36:04 PM] Loading 1 platforms...
[11/19/2017, 3:36:04 PM] [FHEM] Initializing FHEM platform...
starting longpoll: https://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1511102166448
[11/19/2017, 3:36:06 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:06 PM] Loading 0 accessories...
Server listening on: http://<ip>:8282
longpoll error: Error: connect ECONNREFUSED 127.0.0.1:8083, retry in: 5000msec
[11/19/2017, 3:36:07 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:08 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:09 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:10 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:11 PM] [FHEM] Fetching FHEM devices...
starting longpoll: https://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1511102171738
longpoll error: Error: connect ECONNREFUSED 127.0.0.1:8083, retry in: 10000msec
[11/19/2017, 3:36:12 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:13 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:14 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:15 PM] [FHEM] Fetching FHEM devices...
[11/19/2017, 3:36:16 PM] [FHEM] Fetching FHEM devices...
^C[11/19/2017, 3:36:16 PM] Got SIGINT, shutting down Homebridge...
Guten Morgen
Es läuft dann immer weiter wie oben zu sehen !
Pin kommt leider nicht ![]()
Gruß
Servus jungs,
Da ich gerade mit Fhem Spiele würde mir Homebridge auch gut gefallen licht per Siri an und auszuschalten, oder Heizung aufdrehen (Max Cube vorhanden)
Also ich hab hier einen Raspi2 wo Octoprint drauf läuft (3D Drucker Server) dazu noch Fhem inkl 433mhz Sender
Jetzt hab ich Homebridge installiert es startet auch ohne fehler aber leider findet mein Iphone 7 mit neuster ios die Bridge nicht!
Habt ihr da ne idee?
Bin nicht der Linux Pro und Homebridge ist mir auch komplett neu!
Danke schon mal
Gruß![]()
Shh Start
[11/19/2017, 12:08:13 AM] Loaded plugin: homebridge-fhem
[11/19/2017, 12:08:13 AM] Registering platform 'homebridge-fhem.FHEM'
[11/19/2017, 12:08:13 AM] ---
[11/19/2017, 12:08:13 AM] Loaded config.json with 0 accessories and 1 platforms.
[11/19/2017, 12:08:13 AM] Loading 1 platforms...
[11/19/2017, 12:08:13 AM] [FHEM] Initializing FHEM platform...
starting longpoll: https://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1511046496399
[11/19/2017, 12:08:16 AM] [FHEM] Fetching FHEM devices...
[11/19/2017, 12:08:16 AM] Loading 0 accessories...
[11/19/2017, 12:08:17 AM] [FHEM] Fetching FHEM devices...
[11/19/2017, 12:08:18 AM] [FHEM] Fetching FHEM devices...
config.json
