Hallo Community.
Ich habe heute den Raspberry mit Homebridge installiert. Als Plugin habe ich die Homebridge Fritz Platform genutzt. Leider kann ich keinerlei Daten von der Fritzbox sehen.
Benutzer und Passwort habe ich im Plugin eingetragen als wenn ich mich lokal auf die FritzBox einlogge. Auch die IP habe ich korrekt eingetragen.
Hier der Log:
[3/5/2021, 18:50:03] [Homebridge UI] Homebridge restart request received
[3/5/2021, 18:50:03] [Homebridge UI] UI / Bridge settings have not changed; only restarting Homebridge process
[3/5/2021, 18:50:03] [Homebridge UI] Sending SIGTERM to Homebridge
[3/5/2021, 18:50:03] Got SIGTERM, shutting down Homebridge...
[3/5/2021, 18:50:03] Got SIGTERM, shutting down child bridge process...
[3/5/2021, 18:50:08] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[3/5/2021, 18:50:13] [HB Supervisor] Restarting Homebridge...
[3/5/2021, 18:50:13] [HB Supervisor] Starting Homebridge with extra flags: -I
[3/5/2021, 18:50:13] [HB Supervisor] Started Homebridge v1.3.2 with PID: 3311
Initializing HAP-NodeJS v0.9.2...
[3/5/2021, 18:50:14] Loaded config.json with 0 accessories and 2 platforms.
[3/5/2021, 18:50:15] Loaded 0 cached accessories from cachedAccessories.
[3/5/2021, 18:50:15] ---
[3/5/2021, 18:50:16] Loaded plugin: [email protected]
[3/5/2021, 18:50:16] Registering platform 'homebridge-config-ui-x.config'
[3/5/2021, 18:50:16] ---
[3/5/2021, 18:50:18] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[3/5/2021, 18:50:18] ---
[3/5/2021, 18:50:18] Loading 2 platforms...
[3/5/2021, 18:50:18] [Config] Initializing config platform...
[3/5/2021, 18:50:18] [Config] Running in Service Mode
[3/5/2021, 18:50:18] [FritzPlatform] Initializing FritzPlatform platform...
[3/5/2021, 18:50:18] [FritzPlatform] Initializing child bridge xx:xx:xx:xx:xx:xx
Preparing Advertiser for 'Homebridge xxxx xxxx' using bonjour-hap backend!
Setup Payload:
X-HM://xxxxxxxxxxxxxxxx
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ xxxxxxxxxxxxx │
Starting to advertise 'Homebridge 1DE7 EA53' using bonjour-hap backend!
[3/5/2021, 18:50:18] Homebridge v1.3.2 (Homebridge 1DE7) is running on port 51509.
[3/5/2021, 18:50:20] [FritzPlatform] Launched child bridge with PID 3337
[3/5/2021, 18:50:22] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[3/5/2021, 18:50:22] [FritzPlatform] Loaded homebridge-fritz-platform v5.0.25 child bridge successfully
[3/5/2021, 18:50:22] Loaded 5 cached accessories from cachedAccessories.0EE9CD5F1872.
[3/5/2021, 18:50:25] [FritzPlatform] One of the user has no name configured. This user will be skipped.
[3/5/2021, 18:50:25] [FritzPlatform] No or wrong accessory type setted up for this user. Setting it to "occupancy".
[3/5/2021, 18:50:25] [FritzPlatform] Callmonitor is not or not correctly set up. Skip.
[3/5/2021, 18:50:25] [FritzPlatform] Telegram is not or not correctly set up. Skip.
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box: Configuring accessory...
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box Wifi 2ghz: Configuring accessory...
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box Wifi 5ghz: Configuring accessory...
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box Wifi guest: Configuring accessory...
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box Deflection: Configuring accessory...
Preparing Advertiser for 'FritzPlatform 32AB' using bonjour-hap backend!
Starting to advertise 'FritzPlatform 32AB' using bonjour-hap backend!
[3/5/2021, 18:50:25] Homebridge v1.3.2 (FritzPlatform) is running on port 36729.
[3/5/2021, 18:50:25] [FritzPlatform] Fritz Box: Polling state (router)...
[3/5/2021, 18:50:27] [FritzPlatform] Fritz Box: Could not process the request during polling state (router)
[3/5/2021, 18:50:27] [FritzPlatform] Fritz Box Wifi 2ghz: Polling state (wifi_2ghz)...
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Wifi 2ghz: Could not process the request during polling state (wifi_2ghz)
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Wifi 5ghz: Polling state (wifi_5ghz)...
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Wifi 5ghz: Could not process the request during polling state (wifi_5ghz)
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Wifi guest: Polling state (wifi_guest)...
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Wifi guest: Could not process the request during polling state (wifi_guest)
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Deflection: Polling state (deflection)...
[3/5/2021, 18:50:28] [FritzPlatform] Fritz Box Deflection: Could not process the request during polling state (deflection)
Hat jemand eine Idee?
Muss ich vielleicht als Adresse die Adresse der Fritzbox aus dem Internet eintragen?
Problem gelöst. Ich Dussel habe keinen separaten Benutzer in der FritzBox angelegt. Manchmal ist es so einfach
Danke SeydX für das tolle Plugin! Sowas unterstütze ich dann gerne!
