v6.0.12 ist online und erlaubt nun eine "Polling Zeit" von unter 15 Sekunden (minimum: 1)
Funktioniert jetzt wieder wie vorher. Vielen Dank dafür!
Kannst du mal dein config.json posten bitte
Bitteschön:
"bridge": {
"name": "Homebridge 7936",
"username": "0E:44:84:0D:79:36",
"port": 53374,
"pin": "682-47-011",
"bind": [
"ovs_eth1"
"accessories": [
"name": "Bürotag",
"stateful": true,
"reverse": false,
"time": 1000,
"resettable": false,
"accessory": "DummySwitch"
"name": "Nachtruhe",
"stateful": true,
"reverse": false,
"time": 1000,
"name": "Homeoffice",
"stateful": true,
"reverse": false,
"time": 1000,
"name": "Steuerung Essbeleuchtung",
"stateful": false,
"reverse": false,
"time": 1200000,
"name": "Anwesenheit",
"stateful": true,
"reverse": false,
"time": 1000,
"name": "Sonnenuntergang",
"stateful": true,
"reverse": false,
"time": 1000,
"name": "Steuerung Heizung",
"stateful": false,
"reverse": false,
"time": 1000,
"name": "Heizzeit",
"stateful": true,
"reverse": false,
"time": 1000,
"platforms": [
"name": "Config",
"port": 8581,
"platform": "config"
"name": "FritzPlatform",
"debug": false,
"warn": true,
"error": true,
"extendedError": true,
"devices": [
"active": true,
"name": "Fritz Box",
"host": "192.168.178.1",
"username": "homebridge",
"password": "****",
"ssl": true,
"tr064": true,
"igd": false,
"wifiUnits": 2,
"master": true,
"hide": true,
"connection": "cable",
"options": {
"wifi_2ghz": "switch",
"wifi_5ghz": "switch",
"wps": "switch",
"led": "switch",
"lock": "switch"
"presence": [
"active": true,
"name": "iPhone",
"address": "****",
"accType": "occupancy",
"ping": false,
"onDelay": 0,
"offDelay": 0
"active": true,
"name": "NITD20627",
"address": "****",
"ping": false,
"threshold": 1,
"onDelay": 0,
"offDelay": 0
"smarthome": [
"active": true,
"name": "Wohnungstür",
"ain": "11934 0302256",
"battery": false,
"accType": "contact"
"active": true,
"name": "Schlafzimmertür",
"ain": "11934 0357178",
"active": true,
"name": "Schlafzimmerfenster",
"ain": "11934 0327025",
"active": true,
"name": "Balkontüre rechts",
"ain": "11934 0358137",
"active": true,
"name": "Heizung Wohnzimmer",
"ain": "09995 0695869",
"temperature": false,
"openWindow": false,
"battery": true,
"accType": "thermostat"
"active": true,
"name": "Heizung Badezimmer",
"ain": "09995 0726425",
"battery": true,
"active": true,
"name": "Temperatur Wohnbereich",
"ain": "09995 0617096",
"humidity": true,
"battery": true,
"accType": "temperature"
"active": true,
"name": "Temperatur Badezimmer",
"ain": "09995 0618993",
"humidity": true,
"battery": true,
"active": true,
"name": "Heizung Schlafzimmer",
"ain": "09995 0714769",
"window": false,
"battery": true,
"active": true,
"name": "Temperatur Schlafzimmer",
"ain": "09995 0619239",
"humidity": true,
"battery": true,
"active": true,
"name": "Badezimmerfenster",
"ain": "11324 0637644",
"active": true,
"name": "Badezimmertür",
"ain": "11934 0309963",
"active": true,
"name": "Balkontüre mitte",
"ain": "11934 0366932",
"active": true,
"name": "Balkontüre links",
"ain": "11934 0366973",
"active": true,
"name": "Wohnzimmerfenster",
"ain": "11934 0366930",
"callmonitor": {
"active": false,
"port": 1012
"extras": {
"alarm": {
"active": false
"wakeup": {
"active": false
"ringlock": {
"active": false
"phoneBook": {
"active": false
"options": {
"presence": {
"polling": {
"timer": 1,
"timerSmarthomeButtons": 1
"telegram": {
"active": false
"platform": "FritzPlatform"
seit dem letzten großen Update ist bei mir zu beobachten, dass die Kontaktsensoren der Telekom (sowohl optisch als auch magnetisch) länger benötigen bis die Statusänderung bei HomeKit ankommt. Ich verwende eine 6660 Cable als eigenes Gerät mit der Firmware 7.27.
Wenn ich eine Türe öffne dauert es teilweise bis zu 10 Sekunden bis die Reaktion in der Homeapp erfolgt. Dies führt aktuell bei mir dazu, dass einige Automationen nicht mehr funktionieren weil sich der Status beim öffnen und schließen der Türe nicht ändert.
Ich hatte dieses Problem ganz am Anfang bei der Einrichtung einmal und konnte es damals selbst lösen indem ich den polling Intervall auf 1 Sekunde gestellt habe. Seither wurde die Änderung auch sofort erkannt. Daran habe ich aber nichts verändert.
Vielleicht habt ihr ja eine Idee, was ich noch versuchen könnte.
Vielen Dank
