Hi
ich habe es mal so reinkopiert, wie von pootersfield angeben. Funzt auch nicht.
Daher hier mal die komplette config.json
Beim Speichern nach dem Reinkopieren setzt das Plugin auch die Zeile "platform":"calendar" nach unten.....
Schon jetzt mal vielen Dank fürs darüber schauen
"bridge": {
"name": "Homebridge 26AC",
"username": "0E:73:51:EB:26:AC",
"port": 51095,
"pin": "798-23-598"
"accessories": [],
"platforms": [
"name": "Config",
"port": 8581,
"auth": "form",
"theme": "dark-mode-red",
"tempUnits": "c",
"lang": "de",
"platform": "config"
"name": "Shelly Wagner",
"username": "m.wagner@XXXXXXXX",
"password": "XXXXXXX",
"admin": {
"enabled": true
"platform": "Shelly"
"statePollingInterval": 30,
"debug": false,
"receivers": [
"name": "Yamaha Reciever RX A 2080",
"ip": "192.168.178.18",
"minVolume": -80,
"maxVolume": 55,
"zone2MinVolume": -80,
"zone2MaxVolume": -10,
"zone3MinVolume": -80,
"zone3MaxVolume": -10,
"zone4MinVolume": -80,
"zone4MaxVolume": -10
"platform": "YamahaReceiver",
"_bridge": {
"username": "0E:43:64:54:C5:BD",
"port": 46965
"bridge": {},
"platforms": [
"platform": "Calendar",
"calendars": [
"name": "Abfallkalender",
"url": "webcal://p42-caldav.icloud.com/published/2.................",
"pollingInterval": 5,
"offset": "-16h",
"sensors": [
"Biomüll",
"Gelber Sack",
"Hasumüll"
Hier mal noch die Fehlerangabe
[20/04/2023, 15:39:24] AssertionError [ERR_ASSERTION]: Cannot generate setupURI on an accessory that isn't published yet!
at Bridge.Accessory.setupURI (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:994:11)
at Server.setServerStatus (/usr/local/lib/node_modules/homebridge/src/server.ts:155:45)
at Server.teardown (/usr/local/lib/node_modules/homebridge/src/server.ts:199:10)
at signalHandler (/usr/local/lib/node_modules/homebridge/src/cli.ts:93:12)
at process.emit (events.js:400:28)
at process.emit (/usr/local/lib/node_modules/homebridge/node_modules/source-map-support/source-map-support.js:516:21)
