Beiträge von tripple
    Bei jedem Neustart der Homebridge muss ich in der Phoscon App den "App verbinden" Button drücken, ansonsten habe ich keine Zigbee Geräte in der Homebridge.
    Wie kann man das Problem umgehen, bzw. dauerhaft lösen?
    Hier der Auszug aus der Console:
    [22/02/2022, 20:26:21] [Hue] homebridge: request 4: POST / {"devicetype":"homebridge-hue#homebridge"}
    [22/02/2022, 20:26:21] [Hue] homebridge: request 4: api error 101: link button not pressed
    [22/02/2022, 20:26:21] [Hue] homebridge: unlock gateway to create a user - retrying in 15s
    [22/02/2022, 20:26:36] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://git.io/JtMGR for more info.
    [22/02/2022, 20:26:36] [Hue] homebridge: request 5: POST / {"devicetype":"homebridge-hue#homebridge"}
    [22/02/2022, 20:26:36] [Hue] homebridge: request 5: api error 101: link button not pressed
    [22/02/2022, 20:26:36] [Hue] homebridge: unlock gateway to create a user - retrying in 15s
    [22/02/2022, 20:26:37] [deCONZ] homebridge Button: Programmable Switch Event: Single Press
    [22/02/2022, 20:26:51] [Hue] homebridge: request 6: POST / {"devicetype":"homebridge-hue#homebridge"}
    [22/02/2022, 20:26:51] [Hue] homebridge: unlock gateway to create a user - retrying in 15s
    [22/02/2022, 20:26:51] [Hue] homebridge: request 6: api error 101: link button not pressed
    [22/02/2022, 20:26:56] [homebridge-hue] This plugin is taking long time to load and preventing Homebridge from starting. See https://git.io/JtMGR for more info.
    Hier wird dann der virtuelle Button in der Phoscon App gedrückt und ... et voila - geht :thumbup:
    [22/02/2022, 20:27:06] [Hue] homebridge: created user - please edit config.json and restart homebridge
    "platforms": [
    "platform": "Hue",
    "users": {
    "002xxxxxxxxxx6D": "Bxxxxxxxxxx1"
    [22/02/2022, 20:27:07] [Hue] homebridge: 40 accessories
    [22/02/2022, 20:27:07] [Hue] homebridge: websocket connected to ws://192.168.1.185:4531
    [22/02/2022, 20:27:07] [Hue] masked debug info dumped to /var/lib/homebridge/homebridge-hue.json.gz
    [22/02/2022, 20:27:07] Initializing platform accessory 'homebridge'...
    [22/02/2022, 20:27:07] [Hue] homebridge: 2 services
    [22/02/2022, 20:27:07] Initializing platform accessory 'Schreibtisch'...
    [22/02/2022, 20:27:07] Initializing platform accessory 'KB01-05'...
    [22/02/2022, 20:27:07] Initializing platform accessory 'KB02-05'...
    [22/02/2022, 20:27:07] Initializing platform accessory 'KB03-05'...
    [22/02/2022, 20:27:07] Initializing platform accessory 'KB04-05'...
    [22/02/2022, 20:27:07] Initializing platform accessory 'KB05-05'...
    usw...
    usw...
    usw...
    Eine weitere Auswirkung gibt es direkt auf Alexa und das Homekit:
    Die Zigbee Geräte sind alle weg.
    Sobald die Geräte wieder da sind müssen diese dann wieder in die Räume/Gruppen hinzugefügt werden.
    Super Ätzend!!!:cursing::cursing::cursing:
    Jemand eine Lösung oder Idee?
    Gruss
    Moin!
    Ich habe einen 2014/15 Sony Bravia TV. Dieser lässt sich per IP und MAC mit dem Plugin "Homebridge Bravia" pairen.
    Man erhält die PIN auf dem TV angezeigt, diesen gibt man dann auf der Website der hombridge:8999 ein und ... et voila!
    Einschalten per WOL, lauter/leiser, Quelle ändern :thumbup:
    Soweit so gut.
    Leider verliert das Plugin bzw. die Bridge häufiger die Bindung und man muss wieder die PIN eingeben.
    In der Console der Homebridge gibt es eine einzelne Meldung mit der ich aber nichts anfangen kann.
    [22/02/2022, 17:03:44] [BraviaPlatform] Error: Error: connect EHOSTUNREACH 192.168.1.85:80
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1157:16) {
    errno: -113,
    code: 'EHOSTUNREACH',
    syscall: 'connect',
    address: '192.168.1.85',
    port: 80
    Kennt sich jemand damit aus bzw. hat das Problem überwunden?
    Die Jason Konfig des Homebridge Bravia Plugin:
    Hi,
    das deCONZ Plugin verursacht bei mir jede Minute einen Switch Event: Single Press
    Habt ihr eine Idee was da passiert?
    [22/02/2022, 20:00:41] [deCONZ] homebridge Button: Programmable Switch Event: Single Press
    [22/02/2022, 20:01:41] [deCONZ] homebridge Button: Programmable Switch Event: Single Press
    [22/02/2022, 20:02:41] [deCONZ] homebridge Button: Programmable Switch Event: Single Press
    [22/02/2022, 20:03:41] [deCONZ] homebridge Button: Programmable Switch Event: Single Press
    [22/02/2022, 20:03:41] [deCONZ] homebridge Button: Programmable Switch Event: Double Press
    homebridge-deconz JASON Konfig
        "name": "deCONZ",
        "hosts": [
            "192.168.1.185:4530"
        "platform": "deCONZ"
    Ist nichts spektakuläres drin.
    Ich sollte noch anmerken das ich homebridge-hue am laufen habe.
    Zur Nachvollziehbarkeit mal meine gesamte Konfig:
