Ist schon tricky wenn die Homebridge nicht startet wenn ein Plugin nicht korrekt konfiguriert ist. :-o
Beiträge von oli
Merci für die Hilfe - mein Fehler.
Jetzt aber richtig - stop und start
pi@raspberrypi:~ $ sudo /etc/init.d/homebridge stop
Stopping homebridge...
Stopped
pi@raspberrypi:~ $ sudo homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
[2018-2-13 15:34:09] Loaded plugin: homebridge-fritz
[2018-2-13 15:34:09] Registering platform 'homebridge-fritz.Fritz!Box'
[2018-2-13 15:34:09] ---
[2018-2-13 15:34:09] Loaded plugin: homebridge-people
[2018-2-13 15:34:09] Registering accessory 'homebridge-people.people'
[2018-2-13 15:34:09] Loaded plugin: homebridge-raspberrypi-temperature
[2018-2-13 15:34:09] Registering accessory 'homebridge-raspberrypi-temperature.RaspberryPiTemperature'
[2018-2-13 15:34:10] Loaded plugin: homebridge-synology
[2018-2-13 15:34:10] Registering accessory 'homebridge-synology.Synology'
[2018-2-13 15:34:10] ---
[2018-2-13 15:34:10] Loaded plugin: homebridge-wol
[2018-2-13 15:34:10] Registering accessory 'homebridge-wol.NetworkDevice'
[2018-2-13 15:34:10] Loaded config.json with 3 accessories and 1 platforms.
[2018-2-13 15:34:10] Loading 1 platforms...
[2018-2-13 15:34:10] [Fritz!Box] Initializing Fritz!Box platform...
[2018-2-13 15:34:10] Loading 3 accessories...
[2018-2-13 15:34:10] [Example PC] Initializing NetworkDevice accessory...
[2018-2-13 15:34:10] [Pi Temp] Initializing RaspberryPiTemperature accessory...
[2018-2-13 15:34:10] [Synology] Initializing Synology accessory...
[2018-2-13 15:34:10] [Synology] s
[2018-2-13 15:34:10] [Synology] start polling...
[2018-2-13 15:34:10] [Synology] do poll...
[2018-2-13 15:34:11] [Example PC] NetworkDevice "Example PC" (192.168.178.1) went from status "Offline" to "Online"
[2018-2-13 15:34:11] [Fritz!Box] Fritz!Box platform login failed
[2018-2-13 15:34:11] [Synology] current power state is: false
[2018-2-13 15:34:11] [Synology] poll end, state: false
Aber in der Home App bleibt es bei "Keine Antwort"
Einfach ist das nicht.
Accessories Ordner gelöscht und Homebridge via Console gestartet.
Dann dan 2D Barcode scannen - voila. Kurz jedenfalls.
Auf der Consolte gab es jede Menge Fehler:
events.js:183
Error: listen EADDRINUSE :::51826
at Object._errnoException (util.js:1022:11)
at _exceptionWithHostPort (util.js:1044:20)
at Server.setupListenHandle [as _listen2] (net.js:1351:14)
at listenInCluster (net.js:1392:12)
at Server.listen (net.js:1476:7)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:607:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:126:16)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:96:10)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
at Module._compile (module.js:643:30)
at Object.Module._extensions..js (module.js:654:10)
at Module.load (module.js:556:32)
at tryModuleLoad (module.js:499:12)
Die Home App hat "kurz" funktioniert, jetzt ist alles offline.
Hallo, ich fange gerade an mit der Heimautomatisierung.
Ich bin nun hier auf die Homebridge aufmerksam geworden - juhu! Endlich eine Verwendung für den RasPi.
Die Installation auf dem RasPi war easy, die iOS App ist soweit okay.
Aktuell scheitere ich daran meinen RasPi und meinen Apple TV-4K miteinander zu verknüpfen.
Ich kann in der "Home" App über manuelles Hinzufügen (Gerät Hinzufügen -> Code fehlt -> Code eingeben... -> Code eingeben -> warten.....nix passiert)
Mein AppleTV steht im EG und ist per LAN verbunden.
Der RasPi steht im UG und ist auch per LAN verbunden.
Was mache ich hier falsch? Wo kann ich nachsehen was falsch sein könnte? Die Logs in /var/log geben jetzt nicht viel her.
Danke & vg, oli
