Klappt immmer noch nicht , es erscheint folgendes nach Installation des Plugin
-- Logs begin at Thu 2016-11-03 18:16:42 CET. --
Sep 12 12:46:41 hbridge2 homebridge[1319]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at Module._compile (module.js:635:30)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at Object.Module._extensions..js (module.js:646:10)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at Module.load (module.js:554:32)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at tryModuleLoad (module.js:497:12)
Sep 12 12:46:41 hbridge2 homebridge[1319]: at Function.Module._load (module.js:489:3)
Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Unit entered failed state.
Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Sep 12 12:46:51 hbridge2 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Sep 12 12:46:51 hbridge2 systemd[1]: Stopped Node.js HomeKit Server.
Sep 12 12:46:51 hbridge2 systemd[1]: Started Node.js HomeKit Server.
Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:53] ====================
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] ERROR LOADING PLUGIN homebridge-fritz:
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Error: Plugin /usr/local/lib/node_modules/homebridge-fritz requires a HomeBridge version of ^0.4.38 which does not satisfy the current HomeBridge version of 0.4.33. You may need to upgrade your installation of HomeBridge.
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:56:11)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:142:14)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Array.forEach (<anonymous>)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:138:22)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:24)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module._compile (module.js:635:30)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.Module._extensions..js (module.js:646:10)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module.load (module.js:554:32)
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] ====================
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] No plugins found. See the README for information on installing plugins.
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Loaded config.json with 0 accessories and 1 platforms.
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] ---
Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Loading 1 platforms...
Sep 12 12:46:54 hbridge2 homebridge[1356]: /usr/local/lib/node_modules/homebridge/lib/api.js:122
Sep 12 12:46:54 hbridge2 homebridge[1356]: throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Sep 12 12:46:54 hbridge2 homebridge[1356]: ^
Sep 12 12:46:54 hbridge2 homebridge[1356]: Error: The requested platform 'Fritz!Box' was not registered by any plugin.
Sep 12 12:46:54 hbridge2 homebridge[1356]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:294:45)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:85:36)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at tryModuleLoad (module.js:497:12)
Sep 12 12:46:54 hbridge2 homebridge[1356]: at Function.Module._load (module.js:489:3)
Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Unit entered failed state.
Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Sep 12 12:47:04 hbridge2 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Sep 12 12:47:04 hbridge2 systemd[1]: Stopped Node.js HomeKit Server.
Sep 12 12:47:04 hbridge2 systemd[1]: Started Node.js HomeKit Server.
^YSep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
^XSep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ====================
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ERROR LOADING PLUGIN homebridge-fritz:
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Error: Plugin /usr/local/lib/node_modules/homebridge-fritz requires a HomeBridge version of ^0.4.38 which does not satisfy the current HomeBridge version of 0.4.33. You may need to upgrade your installation of HomeBridge.
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:56:11)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:142:14)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Array.forEach (<anonymous>)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:138:22)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:24)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module._compile (module.js:635:30)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.Module._extensions..js (module.js:646:10)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module.load (module.js:554:32)
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] No plugins found. See the README for information on installing plugins.
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Loaded config.json with 0 accessories and 1 platforms.
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ---
Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Loading 1 platforms...
Sep 12 12:47:06 hbridge2 homebridge[1381]: /usr/local/lib/node_modules/homebridge/lib/api.js:122
Sep 12 12:47:06 hbridge2 homebridge[1381]: throw new Error("The requested platform '" + name + "' was not registered by any plugin.");
Sep 12 12:47:06 hbridge2 homebridge[1381]: ^
Sep 12 12:47:06 hbridge2 homebridge[1381]: Error: The requested platform 'Fritz!Box' was not registered by any plugin.
Sep 12 12:47:06 hbridge2 homebridge[1381]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:294:45)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:85:36)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at tryModuleLoad (module.js:497:12)
Sep 12 12:47:06 hbridge2 homebridge[1381]: at Function.Module._load (module.js:489:3)
Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Unit entered failed state.
Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Keiner eine Idee?
