Probleme - Homebridge-Image mittels pishrink.sh verkleinern
  • Homebridge-Image mittels pishrink.sh verkleinern
    Hallo zusammen
    meine Homebridge auf dem RAspi 4 läuft mit einer 32GB SD-Karte.
    Nun wollte ich das Image mit pishrink verkleinern. Jedochj kriege ich Fehler
    gleich am Anfang der Procedure:
    root@Kodi:/media/root/DISK111# pishrink.sh
    pishrink.sh v0.1.2
    pishrink.sh: Gathering data ...
    Skipping autoexpanding process...
    pishrink.sh: Checking filesystem ...
    rootfs: recovering journal
    rootfs: Clearing orphaned inode 2053 (uid=33, gid=33, mode=0100666, size=0)
    rootfs: Inodes that were part of a corrupted orphan linked list found.
    rootfs: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
    (i.e., without -a or -p options)
    pishrink.sh: Filesystem error detected! ...
    pishrink.sh: Trying to recover corrupted filesystem ...
    e2fsck 1.46.2 (28-Feb-2021)
    rootfs contains a file system with errors, check forced.
    Pass 1: Checking inodes, blocks, and sizes
    Inodes that were part of a corrupted orphan linked list found. Fix? yes
    Inode 151646 was part of the orphaned inode list. FIXED.
    Pass 2: Checking directory structure
    Pass 3: Checking directory connectivity
    Pass 4: Checking reference counts
    Pass 5: Checking group summary information
    Free blocks count wrong (6545259, counted=6535428).
    Fix? yes
    Free inodes count wrong (1817877, counted=1817863).
    Fix? yes
    rootfs: ***** FILE SYSTEM WAS MODIFIED *****
    rootfs: 119225/1937088 files (0.2% non-contiguous), 1191292/7726720 blocks
    resize2fs 1.46.2 (28-Feb-2021)
    pishrink.sh: Shrinking filesystem ...
    Resizing the filesystem on /dev/loop0 to 1142670 (4k) blocks.
    Begin pass 2 (max = 490013)
    Relocating blocks XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Begin pass 3 (max = 236)
    Scanning inode table XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Begin pass 4 (max = 26454)
    Updating inode references XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    The filesystem on /dev/loop0 is now 1142670 (4k) blocks long.
    pishrink.sh: Shrinking image ...
    pishrink.sh: Shrunk 8GB.img from 30G to 4.7G ...
    Das Image wir erstellt nur kann ich es nicht verwenden. Kopiere ich das Image auf eine 8GB SD-Card so meckert
    der RASPI-Imager bei der Verifizierung nach dem copieren. Die SD-Karte läßt sich auch im Raspi nicht mehr lesen - d.h. der Bootvorgang
    findet nicht statt.
    Hat vielleicht jemand eine Idee ?
    Wie gesagt die 32GB SD-Karte läuft wunderbar im Raspi
    LG Roger
