Hallo Forum,
aktuell versuche ich ein zwave Plugin - homebridge-zwave - zu installieren und erhalte folgende Fehlermeldung.
[email protected] install /home/homebridge/node_modules/openzwave-shared
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/homebridge/node_modules/openzwave-shared/.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/home/homebridge/node_modules/openzwave-shared/.node-gyp'
gyp ERR! System Linux 4.19.42-v7+
gyp ERR! cwd /home/homebridge/node_modules/openzwave-shared
gyp ERR! node -v v10.16.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open '/home/homebridge/package.json'
npm WARN homebridge No description
npm WARN homebridge No repository field.
npm WARN homebridge No README data
npm WARN homebridge No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
Hat jemand eine Idee?
Gruß Thorsten
