Ich habe das homebridge-fritz Plugin auf die Version 0.9.2 geupdatet und finde im Logfile nun folgende Fehlermeldung vor:
Jan 25 12:22:42 raspberrypi homebridge[22382]: [2020-1-25 12:22:42] [FritzBox 7590] Updating temperature sensor 087610940222
Jan 25 12:22:42 raspberrypi homebridge[22382]: Unhandled rejection ReferenceError: self is not defined
Jan 25 12:22:42 raspberrypi homebridge[22382]: at /usr/local/lib/node_modules/homebridge-fritz/lib/accessories/alarmsensor.js:58:9
Jan 25 12:22:42 raspberrypi homebridge[22382]: at tryCatcher (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/util.js:16:23)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:547:31)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Promise._settlePromise (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:604:18)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Promise._fulfillPromises (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:704:14)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Promise._settlePromises (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/promise.js:730:18)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at _drainQueueStep (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/async.js:93:12)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at _drainQueue (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/async.js:86:9)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Async._drainQueues (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/async.js:102:5)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at Immediate.Async.drainQueues [as _onImmediate] (/usr/local/lib/node_modules/homebridge-fritz/node_modules/bluebird/js/release/async.js:15:14)
Jan 25 12:22:42 raspberrypi homebridge[22382]: at processImmediate (internal/timers.js:439:21)
Hat jemand eine Idee?
