Beiträge von ribs_23
Ich dachte zwar, dass ich über
./hbridge_new.sh install
Homebridge bereits installiert habe, aber ich habe es mit deinem Befehl ein Weiteres mal getan.
Nun steht folgendes im syslog
Apr 16 21:35:31 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 16 21:35:31 raspberrypi homebridge[1353]: module.js:540
Apr 16 21:35:31 raspberrypi homebridge[1353]: throw err;
Apr 16 21:35:31 raspberrypi homebridge[1353]: ^
Apr 16 21:35:31 raspberrypi homebridge[1353]: Error: Cannot find module '../build/Release/dns_sd_bindings'
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._resolveFilename (module.js:538:15)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._load (module.js:468:25)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module.require (module.js:587:17)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at require (internal/module.js:11:18)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:32:22)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module._compile (module.js:643:30)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Object.Module._extensions..js (module.js:654:10)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module.load (module.js:556:32)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at tryModuleLoad (module.js:499:12)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._load (module.js:491:3)
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 16 21:35:41 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Apr 16 21:35:41 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Apr 16 05:34:24 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 16 05:34:24 raspberrypi systemd[6782]: homebridge.service: Failed at step EXEC spawning /usr/local/bin/homebridge: No such file or directory
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=203/EXEC
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 16 05:34:34 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Apr 16 05:34:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
ich habe alles neu aufgesetzt und dein Tool benutzt.
Leider klappt es noch immer nicht. Ich erhalte folgende Fehlermeldung.
Apr 16 00:23:54 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Apr 16 00:23:54 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 16 00:23:54 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=203/EXEC
Apr 16 00:23:54 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Apr 16 00:23:54 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 16 00:24:04 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Vielen Dank für die Unterstützung
über Kabel.
Wenn ich ein "frisches" RASPBIAN STRETCH WITH DESKTOP image aufspiele, bekomme ich eine IP
Hallo det
ich versuche seit 1ner Woche auf meinem neuen Pi 3 Model B+ Homebridge als Service laufen zu lassen, aber irgendwie bekomme ich es nicht auf die Reihe.
Meine bisherigen Erfolge waren
1) Homebridge (ohne Service) inkl. Plugins laufen lassen (bringt aber leider nicht viel, da es keine Nacht durch läuft)
2) Homebridge als Service laufen lassen, wobei keine keine Plugins funktioniert haben (bzw. der Service z.B. beim people Plugin garnicht gestartet ist)
Jetzt mein verzweifelter Versuch es über deine Images zu probieren, aber leider scheitere ich schon zu Beginn.
Der Raspberry erscheint nicht im LAN (bzw. ich finde keine IP) obwohl DHCP aktiviert ist.
Kann das vielleicht daran liegen, dass ich einen Pi 3 Model B+ besitze und die images für eine ältere Version erstellt wurden?
Vielen Dank vorab
