Moin Moin,
ich wurschtel jetzt schon Tagelang rum um Raspbee in Homebridge einzubinden.
Raspbee und Homebridge läuft auf unterschiedlichen Raspberrys, Raspbee für sich einzeln Funktioniert auch Tadellos.
Beim Einbinden von Homebridge-hue kommt folgende Fehlermeldung
Jun 25 07:04:29 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jun 25 07:04:29 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Jun 25 07:04:29 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jun 25 07:04:39 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Jun 25 07:04:39 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jun 25 07:04:40 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jun 25 07:04:41 raspberrypi homebridge[2649]: [6/25/2019, 7:04:41 AM] Loaded config.json with 4 accessories and 2 platforms.
Jun 25 07:04:41 raspberrypi homebridge[2649]: [6/25/2019, 7:04:41 AM] ---
Jun 25 07:04:41 raspberrypi homebridge[2649]: [6/25/2019, 7:04:41 AM] Loaded plugin: homebridge-config-ui-x
Jun 25 07:04:41 raspberrypi homebridge[2649]: [6/25/2019, 7:04:41 AM] Registering platform 'homebridge-config-ui-x.config'
Jun 25 07:04:42 raspberrypi homebridge[2649]: [6/25/2019, 7:04:42 AM] Loaded plugin: homebridge-daikin-local
Jun 25 07:04:42 raspberrypi homebridge[2649]: [6/25/2019, 7:04:42 AM] Registering accessory 'homebridge-daikin-local.Daikin-Local'
Jun 25 07:04:42 raspberrypi homebridge[2649]: [6/25/2019, 7:04:42 AM] ---
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] ====================
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] ERROR LOADING PLUGIN homebridge-hue:
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] Error: Cannot find module 'homebridge-lib'
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Module.require (internal/modules/cjs/loader.js:690:17)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at require (internal/modules/cjs/helpers.js:25:18)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-hue/lib/HuePlatform.js:22:23)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Module._compile (internal/modules/cjs/loader.js:776:30)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Module.load (internal/modules/cjs/loader.js:653:32)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] Loading 2 platforms...
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] [Config] Initializing config platform...
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] [Config] Spawning homebridge-config-ui-x with PID 2669
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] Error: The requested platform 'Hue' was not registered by any plugin.
Jun 25 07:04:43 raspberrypi homebridge[2649]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:134:13)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:327:45)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jun 25 07:04:43 raspberrypi homebridge[2649]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jun 25 07:04:43 raspberrypi homebridge[2649]: [6/25/2019, 7:04:43 AM] Got SIGTERM, shutting down Homebridge...
Jun 25 07:04:47 raspberrypi homebridge[2649]: [6/25/2019, 7:04:47 AM] [Config] Console v4.5.1 is listening on :: port 8080
So langsam bin ich mit meinem Latein am Ende.
Ich habe auch mal homebridge-huejay v1.4.5 getestet
das lässt sich Installieren da kommt auch keine Fehlermeldung aber da kommen keine Geräte zum Vorschein.
Ich hoffe mir kann hier jemand helfen.
Gruß Jürgen
