ich benötige mal Unterstützung.
Ich habe das Problem, dass ich das Plugin "homebridge-zp" (Sonos) deinstalliert habe, die Geräte aber nicht verschwinden.
Auch eine manuelle Deinstallation über die Konsole brachte keinen Erfolg.
Die config.json ist natürlich auch angepasst.
Jemand eine Idee?
Ach ja, und wenn ich das Plugin neu installieren will kommt das:
USER: homebridge
DIR: /usr/local/lib
CMD: sudo -E -n npm --no-update-notifier install --unsafe-perm homebridge-zp@latest
/usr/local/bin/zp -> /usr/local/lib/node_modules/homebridge-zp/cli/zp.js
npm ERR! code EEXIST
npm ERR! syscall symlink
npm ERR! path ../lib/node_modules/homebridge-zp/cli/hap.js
npm ERR! dest /usr/local/bin/hap
npm ERR! errno -17
npm ERR! EEXIST: file already exists, symlink '../lib/node_modules/homebridge-zp/cli/hap.js' -> '/usr/local/bin/hap'
npm ERR! File exists: /usr/local/bin/hap
npm ERR! Remove the existing file and try again, or run npm
npm ERR! with --force to overwrite files recklessly.
npm ERR! /home/homebridge/.npm/_logs/2019-12-19T15_43_55_613Z-debug.log
Command failed. Please review log for details.
ec 19 15:55:01 raspberrypi CRON[3065]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 19 15:57:50 raspberrypi systemd[1]: session-c1.scope: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[1]: Stopping User Manager for UID 1000...
Dec 19 15:58:00 raspberrypi systemd[833]: Stopped target Default.
Dec 19 15:58:00 raspberrypi systemd[833]: Stopped target Basic System.
Dec 19 15:58:00 raspberrypi systemd[833]: Stopped target Paths.
Dec 19 15:58:00 raspberrypi systemd[833]: Stopped target Timers.
Dec 19 15:58:00 raspberrypi systemd[833]: Stopped target Sockets.
Dec 19 15:58:00 raspberrypi systemd[833]: gpg-agent-extra.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dec 19 15:58:00 raspberrypi systemd[833]: dirmngr.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed GnuPG network certificate management daemon.
Dec 19 15:58:00 raspberrypi systemd[833]: gpg-agent.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed GnuPG cryptographic agent and passphrase cache.
Dec 19 15:58:00 raspberrypi systemd[833]: gpg-agent-ssh.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dec 19 15:58:00 raspberrypi systemd[833]: gpg-agent-browser.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 19 15:58:00 raspberrypi systemd[833]: dbus.socket: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Closed D-Bus User Message Bus Socket.
Dec 19 15:58:00 raspberrypi systemd[833]: Reached target Shutdown.
Dec 19 15:58:00 raspberrypi systemd[833]: systemd-exit.service: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[833]: Started Exit the Session.
Dec 19 15:58:00 raspberrypi systemd[833]: Reached target Exit the Session.
Dec 19 15:58:00 raspberrypi systemd[1]: [email protected]: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[1]: Stopped User Manager for UID 1000.
Dec 19 15:58:00 raspberrypi systemd[1]: Stopping User Runtime Directory /run/user/1000...
Dec 19 15:58:00 raspberrypi systemd[1]: run-user-1000.mount: Succeeded.
Dec 19 15:58:00 raspberrypi systemd[1]: Stopped User Runtime Directory /run/user/1000.
Dec 19 15:58:00 raspberrypi systemd[1]: Removed slice User Slice of UID 1000.
Dec 19 15:58:12 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
Dec 19 15:58:12 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
Dec 19 15:58:12 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
Dec 19 15:58:12 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 19 15:58:12 raspberrypi systemd[3221]: Reached target Paths.
Dec 19 15:58:12 raspberrypi systemd[3221]: Reached target Timers.
Dec 19 15:58:12 raspberrypi systemd[3221]: Starting D-Bus User Message Bus Socket.
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on GnuPG network certificate management daemon.
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 19 15:58:12 raspberrypi systemd[3221]: Listening on D-Bus User Message Bus Socket.
Dec 19 15:58:12 raspberrypi systemd[3221]: Reached target Sockets.
Dec 19 15:58:12 raspberrypi systemd[3221]: Reached target Basic System.
Dec 19 15:58:12 raspberrypi systemd[3221]: Reached target Default.
Dec 19 15:58:12 raspberrypi systemd[3221]: Startup finished in 160ms.
Dec 19 15:58:12 raspberrypi systemd[1]: Started User Manager for UID 1000.
Dec 19 15:58:12 raspberrypi systemd[1]: Started Session c2 of user pi.
Dec 19 15:58:22 raspberrypi homebridge[2576]: [12/19/2019, 15:58:22] Got SIGTERM, shutting down Homebridge...
Dec 19 15:58:27 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Dec 19 15:58:27 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Dec 19 15:58:37 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Dec 19 15:58:37 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 16.
Dec 19 15:58:37 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Dec 19 15:58:37 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Dec 19 15:58:39 raspberrypi homebridge[3254]: [12/19/2019, 15:58:39] Loaded config.json with 7 accessories and 6 platforms.
Dec 19 15:58:39 raspberrypi homebridge[3254]: [12/19/2019, 15:58:39] ---
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Loaded plugin: homebridge-blinkcameras
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Registering accessory 'homebridge-blinkcameras.BlinkCameras'
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] ---
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Loaded plugin: homebridge-config-ui-x
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Registering platform 'homebridge-config-ui-x.config'
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Loaded plugin: homebridge-delay-switch
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Registering accessory 'homebridge-delay-switch.DelaySwitch'
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Loaded plugin: homebridge-dummy
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Registering accessory 'homebridge-dummy.DummySwitch'
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Plugin /usr/local/lib/node_modules/homebridge-fritz-platform requires Node version of ^10.15.3 which does not satisfy the current Node version of v12.13.1. You may need to upgrade your installation of Node.
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Loaded plugin: homebridge-fritz-platform
Dec 19 15:58:40 raspberrypi homebridge[3254]: [12/19/2019, 15:58:40] Registering platform 'homebridge-fritz-platform.FritzPlatform'
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Loaded plugin: homebridge-hue
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Registering platform 'homebridge-hue.Hue'
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] ---
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Loaded plugin: homebridge-ifttt
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Registering platform 'homebridge-ifttt.IFTTT'
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Loaded plugin: homebridge-notification
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Registering accessory 'homebridge-notifications.Notification'
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Loaded plugin: homebridge-shelly
Dec 19 15:58:43 raspberrypi homebridge[3254]: [12/19/2019, 15:58:43] Registering platform 'homebridge-shelly.Shelly'
Dec 19 15:58:44 raspberrypi homebridge[3254]: [12/19/2019, 15:58:44] Loaded plugin: homebridge-weather-plus
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] Registering platform 'homebridge-weather-plus.WeatherPlus'
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] ---
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] Loading 6 platforms...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Config] Initializing config platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Config] Spawning homebridge-config-ui-x with PID 3274
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] Initializing FritzPlatform platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] **************************************************************
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] FritzPlatform v4.1.0 by SeydX
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] GitHub: https://github.com/SeydX/homebridge-fritz-platform
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] Email: [email protected]
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] start success...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Shelly] Initializing Shelly platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [WeatherPlus] Initializing WeatherPlus platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [WeatherPlus] Adding station with weather service OpenWeatherMap named 'Wetter Oldenburg'
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [WeatherPlus] Initializing platform accessory 'Wetter Oldenburg'...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [WeatherPlus] Initializing platform accessory 'Vorhersage In 1 Day'...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [WeatherPlus] Initializing platform accessory 'Vorhersage In 2 Days'...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Hue-Bridge] Initializing Hue platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Hue-Bridge] config.json: warning: philipslights: ignoring unknown key
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Hue-Bridge] config.json: warning: linkbutton: ignoring unknown key
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Hue-Bridge] homebridge-hue v0.11.44, node v12.13.1, homebridge v0.4.50
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT] Initializing IFTTT platform...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT] Loading accessories...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT] Found: Alarm Garten
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT] Loading service: Motion Garten, subtype: NaN
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT] Initializing platform accessory 'Alarm Garten'...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] Loading 7 accessories...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [My Cameras] Initializing BlinkCameras accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Delay Bad 15] Initializing DelaySwitch accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Delay WC 15] Initializing DelaySwitch accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Delay Garten 15] Initializing DelaySwitch accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Badfenster] Initializing Notification accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Badfenster] ifttt api key bZ-t1GpFcZuhBJLfrCPIxS
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Badfenster] ifttt event homebridge_bad
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Badfenster] ifttt message Badfenster zu !!!
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Badfenster] ifttt mute notification interval in sec 60
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Fenster WC] Initializing Notification accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Fenster WC] ifttt api key bZ-t1GpFcZuhBJLfrCPIxS
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Fenster WC] ifttt event homebridge_wc
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Fenster WC] ifttt message Fenster WC schließen !!!
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [IFTTT Fenster WC] ifttt mute notification interval in sec 60
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Alarm Home] Initializing DummySwitch accessory...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Alarm Home] Setting switch to true
Dec 19 15:58:46 raspberrypi homebridge[3254]: Failed to find plugin to handle accessory Küche
Dec 19 15:58:46 raspberrypi homebridge[3254]: Failed to find plugin to handle accessory Dachgeschoss L
Dec 19 15:58:46 raspberrypi homebridge[3254]: Failed to find plugin to handle accessory Schlafzimmer
Dec 19 15:58:46 raspberrypi homebridge[3254]: Failed to find plugin to handle accessory Wohnzimmer
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] Auto Device Search is disabled, looking for devices in config.json..
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] Initializing config...
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Shelly] 1 accessory loaded from cache
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [Shelly] Admin server is running on port 8181
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] Auto config generator disabled.
Dec 19 15:58:46 raspberrypi homebridge[3254]: [12/19/2019, 15:58:46] [FritzPlatform] [INFO] Found 5 active devices...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Philips hue: Philips BSB002 bridge v1935144020, api v1.35.0
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Philips hue: 18 accessories
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Philips hue'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Philips hue: 2 services
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Flur oben 1'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Stehlampe'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'TV-Lampe'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Flur unten 3'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Flur unten 2'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Flur unten 1'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Eingang'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Flur oben 2'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Garten'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Schlafzimmer'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Badleuchte'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Wohnzimmer 2'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Wohnzimmer 3'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Wohnzimmer 1'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Esszimmer'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Osram Steckdose'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] [Hue-Bridge] Initializing platform accessory 'Motion Oben'...
Dec 19 15:58:47 raspberrypi homebridge[3254]: Setup Payload:
Dec 19 15:58:47 raspberrypi homebridge[3254]: X-HM://0023ISYWYD1NL
Dec 19 15:58:47 raspberrypi homebridge[3254]: [12/19/2019, 15:58:47] Homebridge is running on port 51826.
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: Casping
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: Anyone
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: Ninchen
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: fritz-unten
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] fritz-unten: Successfully logged in!
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: fritz-unten WifiGuest
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] fritz-unten WifiGuest: Initializing API
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: fritz-unten Wps
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] fritz-unten Wps: Initializing API
Dec 19 15:58:50 raspberrypi homebridge[3254]: [12/19/2019, 15:58:50] [FritzPlatform] [INFO] Configuring accessory from cache: NAS200
Dec 19 15:58:51 raspberrypi homebridge[3254]: #033[0;37m[12/19/2019, 15:58:51] #033[0m#033[0;36m[Config]#033[0m #033[0;33mHomebridge Config UI X v4.6.6 is listening on :: port 8080#033[0m
Dec 19 15:58:53 raspberrypi homebridge[3254]: [12/19/2019, 15:58:53] [FritzPlatform] [INFO] fritz-unten WifiGuest: Successfully logged in!
Dec 19 15:58:53 raspberrypi homebridge[3254]: [12/19/2019, 15:58:53] [FritzPlatform] [INFO] fritz-unten Wps: Successfully logged in!
Dec 19 16:01:48 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Dec 19 16:01:48 raspberrypi systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Dec 19 16:01:48 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
Dec 19 16:04:24 raspberrypi homebridge[3254]: [12/19/2019, 16:04:24] [Hue-Bridge] Hue temperature sensor 1: set homekit temperature from 18°C to 17.8°C
Dec 19 16:05:01 raspberrypi CRON[3692]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
