Das habe ich ausgeführt und folgenden Log. Schlau werde ich aus dem leider nicht.
-- Logs begin at Thu 2016-11-03 18:16:42 CET. --
Jul 03 15:10:40 raspberrypi homebridge[1106]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jul 03 15:10:40 raspberrypi homebridge[1106]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
Jul 03 15:10:40 raspberrypi homebridge[1106]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
Jul 03 15:10:40 raspberrypi homebridge[1106]: at Module.load (internal/modules/cjs/loader.js:986:32)
Jul 03 15:10:40 raspberrypi homebridge[1106]: [7/3/2020, 15:10:40] Got SIGTERM, shutting down Homebridge...
Jul 03 15:10:45 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jul 03 15:10:45 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jul 03 15:10:45 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Jul 03 15:10:45 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jul 03 15:10:45 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jul 03 15:10:47 raspberrypi homebridge[1155]: [7/3/2020, 15:10:47] Loaded config.json with 1 accessories and 4 platforms.
Jul 03 15:10:47 raspberrypi homebridge[1155]: [7/3/2020, 15:10:47] ---
Jul 03 15:10:48 raspberrypi homebridge[1155]: [7/3/2020, 15:10:48] The plugin "homebridge-camera-ui" requires a Homebridge version of ^0.4.49 which does not satisfy the current Homebridge version of 1.1.1. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
Jul 03 15:10:48 raspberrypi homebridge[1155]: [7/3/2020, 15:10:48] The plugin "homebridge-camera-ui" requires Node version of ^8.9.1 which does not satisfy the current Node version of v12.18.2. You may need to upgrade your installation of Node.
Jul 03 15:10:48 raspberrypi homebridge[1155]: [7/3/2020, 15:10:48] Loaded plugin: [email protected]
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] Registering platform 'homebridge-camera-ui.CameraUI'
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] ---
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] Loaded plugin: [email protected]
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] Registering platform 'homebridge-config-ui-x.config'
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] Registering accessory 'homebridge-fakebulb1.FakeBulb1'
Jul 03 15:10:49 raspberrypi homebridge[1155]: [7/3/2020, 15:10:49] Registering accessory 'homebridge-raspberrypi-temperature.RaspberryPiTemperature'
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Loaded plugin: [email protected]
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Registering platform 'homebridge-samsung-tizen.SamsungTizen'
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] ---
Jul 03 15:10:50 raspberrypi homebridge[1155]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:10:50 raspberrypi homebridge[1155]: *** WARNING *** Please fix your application to use the native API of Avahi!
Jul 03 15:10:50 raspberrypi homebridge[1155]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Jul 03 15:10:50 raspberrypi homebridge[1155]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:10:50 raspberrypi homebridge[1155]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
Jul 03 15:10:50 raspberrypi node[1155]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:10:50 raspberrypi node[1155]: *** WARNING *** Please fix your application to use the native API of Avahi!
Jul 03 15:10:50 raspberrypi node[1155]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Jul 03 15:10:50 raspberrypi node[1155]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:10:50 raspberrypi node[1155]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] ====================
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] ERROR LOADING PLUGIN homebridge-soundtouch:
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Error: The module '/usr/local/lib/node_modules/homebridge-soundtouch/node_modules/node-expat/build/Release/node_expat.node'
Jul 03 15:10:50 raspberrypi homebridge[1155]: was compiled against a different Node.js version using
Jul 03 15:10:50 raspberrypi homebridge[1155]: NODE_MODULE_VERSION 64. This version of Node.js requires
Jul 03 15:10:50 raspberrypi homebridge[1155]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
Jul 03 15:10:50 raspberrypi homebridge[1155]: the module (for instance, using `npm rebuild` or `npm install`).
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1188:18)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Module.load (internal/modules/cjs/loader.js:986:32)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Module.require (internal/modules/cjs/loader.js:1026:19)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at require (internal/modules/cjs/helpers.js:72:18)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at bindings (/usr/local/lib/node_modules/homebridge-soundtouch/node_modules/node-expat/node_modules/bindings/bindings.js:112:48)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-soundtouch/node_modules/node-expat/lib/node-expat.js:4:32)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Loading 4 platforms...
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [SamsungTizen] Initializing SamsungTizen platform...
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] Initializing CameraUI platform...
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] **************************************************************
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] CameraUI v2.1.9 by SeydX
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] GitHub: https://github.com/SeydX/homebridge-camera-mqtt
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] Email: [email protected]
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [CameraUI] start success...
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [Config] Initializing config platform...
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] [Config] Spawning homebridge-config-ui-x with PID 1184
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Error loading platform requested in your config.json at position 4
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Error: The requested platform 'DelayedSwitches' was not registered by any plugin.
Jul 03 15:10:50 raspberrypi homebridge[1155]: at PluginManager.getPluginForPlatform (/usr/local/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at /usr/local/lib/node_modules/homebridge/src/server.ts:387:37
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Array.forEach (<anonymous>)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:374:27)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:153:29)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:80:10)
Jul 03 15:10:50 raspberrypi homebridge[1155]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jul 03 15:10:50 raspberrypi homebridge[1155]: [7/3/2020, 15:10:50] Got SIGTERM, shutting down Homebridge...
Jul 03 15:10:55 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jul 03 15:10:55 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Jul 03 15:10:55 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jul 03 15:11:05 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Jul 03 15:11:05 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jul 03 15:11:05 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jul 03 15:11:06 raspberrypi homebridge[1209]: [7/3/2020, 15:11:06] Loaded config.json with 1 accessories and 4 platforms.
Jul 03 15:11:06 raspberrypi homebridge[1209]: [7/3/2020, 15:11:06] ---
Jul 03 15:11:07 raspberrypi homebridge[1209]: [7/3/2020, 15:11:07] The plugin "homebridge-camera-ui" requires a Homebridge version of ^0.4.49 which does not satisfy the current Homebridge version of 1.1.1. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
Jul 03 15:11:07 raspberrypi homebridge[1209]: [7/3/2020, 15:11:07] The plugin "homebridge-camera-ui" requires Node version of ^8.9.1 which does not satisfy the current Node version of v12.18.2. You may need to upgrade your installation of Node.
Jul 03 15:11:07 raspberrypi homebridge[1209]: [7/3/2020, 15:11:07] Loaded plugin: [email protected]
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] Registering platform 'homebridge-camera-ui.CameraUI'
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] ---
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] Loaded plugin: [email protected]
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] Registering platform 'homebridge-config-ui-x.config'
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] Registering accessory 'homebridge-fakebulb1.FakeBulb1'
Jul 03 15:11:08 raspberrypi homebridge[1209]: [7/3/2020, 15:11:08] Registering accessory 'homebridge-raspberrypi-temperature.RaspberryPiTemperature'
Jul 03 15:11:09 raspberrypi homebridge[1209]: [7/3/2020, 15:11:09] Loaded plugin: [email protected]
Jul 03 15:11:09 raspberrypi homebridge[1209]: [7/3/2020, 15:11:09] Registering platform 'homebridge-samsung-tizen.SamsungTizen'
Jul 03 15:11:09 raspberrypi homebridge[1209]: [7/3/2020, 15:11:09] ---
Jul 03 15:11:09 raspberrypi homebridge[1209]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:11:09 raspberrypi homebridge[1209]: *** WARNING *** Please fix your application to use the native API of Avahi!
Jul 03 15:11:09 raspberrypi homebridge[1209]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Jul 03 15:11:09 raspberrypi homebridge[1209]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:11:09 raspberrypi homebridge[1209]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
Jul 03 15:11:09 raspberrypi node[1209]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:11:09 raspberrypi node[1209]: *** WARNING *** Please fix your application to use the native API of Avahi!
Jul 03 15:11:09 raspberrypi node[1209]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Jul 03 15:11:09 raspberrypi node[1209]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Jul 03 15:11:09 raspberrypi node[1209]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
