ohhh
jetzt startet die Homebridge nicht mehr ![]()
hier der Befehl: sudo systemctl restart homebridge; sudo journalctl -fau homebridge
-- Logs begin at Tue 2020-04-14 09:24:21 CEST. --
Apr 14 18:34:35 phoscon systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 14 18:34:36 phoscon systemd[1]: homebridge.service: Service RestartSec=100ms expired, scheduling restart.
Apr 14 18:34:36 phoscon systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 3.
Apr 14 18:34:36 phoscon systemd[1]: Stopped Node.js HomeKit Server.
Apr 14 18:34:36 phoscon systemd[1]: Started Node.js HomeKit Server.
Apr 14 18:34:36 phoscon systemd[1]: Stopping Node.js HomeKit Server...
Apr 14 18:34:36 phoscon systemd[1]: homebridge.service: Main process exited, code=killed, status=15/TERM
Apr 14 18:34:36 phoscon systemd[1]: homebridge.service: Succeeded.
Apr 14 18:34:44 phoscon systemd[1]: Started Node.js HomeKit Server.
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Loaded config.json with 0 accessories and 2 platforms.
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] ---
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Loaded plugin: homebridge-config-ui-x
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Registering platform 'homebridge-config-ui-x.config'
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Loaded plugin: homebridge-fakebulb
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Registering accessory 'homebridge-fakebulb.FakeBulb'
Apr 14 18:34:45 phoscon homebridge[24569]: [2020-4-14 18:34:45] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^12.16.2 which does not satisfy the current Node version of v12.16.1. You may need to upgrade your installation of Node.
Apr 14 18:34:47 phoscon homebridge[24569]: [2020-4-14 18:34:47] Loaded plugin: homebridge-hue
Apr 14 18:34:47 phoscon homebridge[24569]: [2020-4-14 18:34:47] Registering platform 'homebridge-hue.Hue'
Apr 14 18:34:47 phoscon homebridge[24569]: [2020-4-14 18:34:47] ---
Apr 14 18:34:47 phoscon homebridge[24569]: [2020-4-14 18:34:47] Loaded plugin: homebridge-mqtt
Apr 14 18:34:47 phoscon homebridge[24569]: homebridge API version: 2.4
Apr 14 18:34:47 phoscon homebridge[24569]: [2020-4-14 18:34:47] Registering platform 'homebridge-mqtt.mqtt'
Apr 14 18:34:48 phoscon homebridge[24569]: [2020-4-14 18:34:48] Loaded plugin: homebridge-mqttthing
Apr 14 18:34:48 phoscon homebridge[24569]: [2020-4-14 18:34:48] Registering accessory 'homebridge-mqttthing.mqttthing'
Apr 14 18:34:48 phoscon homebridge[24569]: [2020-4-14 18:34:48] ---
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Loaded plugin: homebridge-roborock
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Registering accessory 'homebridge-roborock.RoborockVacuum'
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] ---
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Loaded plugin: homebridge-simple-mqtt
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Registering accessory 'homebridge-simple-mqtt.simple-mqtt'
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Loading 2 platforms...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Config] Initializing config platform...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Config] Spawning homebridge-config-ui-x with PID 24636
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing Hue platform...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] homebridge-hue v0.11.62, node v12.16.1, homebridge v0.4.53
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] warning: not using recommended node version v12.16.2 LTS
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] Loading 0 accessories...
Apr 14 18:34:49 phoscon homebridge[24569]: Load homebridge-mqtt.mqtt
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [homebridge-mqtt.mqtt] config undefined in '/var/homebridge', irrelevant by multiple homebridge instances.
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Phoscon-GW: dresden elektronik deCONZ gateway v2.5.73, api v1.16.0
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Phoscon-GW: warning: not using recommended deCONZ gateway version 2.5.75
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Phoscon-GW: 7 accessories
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Phoscon-GW'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Phoscon-GW: 2 services
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Licht Couch'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Gaube'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Fernseher'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Stehlampe'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Spielekonsole'...
Apr 14 18:34:49 phoscon homebridge[24569]: [2020-4-14 18:34:49] [Hue] Initializing platform accessory 'Steckdose 3'...
Apr 14 18:34:49 phoscon homebridge[24569]: Setup Payload:
Apr 14 18:34:49 phoscon homebridge[24569]: X-HM://0023ISYWY04EK
Apr 14 18:34:49 phoscon homebridge[24569]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Apr 14 18:34:49 phoscon homebridge[24569]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Apr 14 18:34:49 phoscon homebridge[24569]: ┌────────────┐
Apr 14 18:34:49 phoscon homebridge[24569]: │ 031-45-154 │
Apr 14 18:35:00 phoscon homebridge[24765]: [2020-4-14 18:35:00] Error: listen EADDRINUSE: address already in use :::51826
Apr 14 18:35:00 phoscon homebridge[24765]: at Server.setupListenHandle [as _listen2] (net.js:1309:16)
Apr 14 18:35:00 phoscon homebridge[24765]: at listenInCluster (net.js:1357:12)
Apr 14 18:35:00 phoscon homebridge[24765]: at Server.listen (net.js:1445:7)
Apr 14 18:35:00 phoscon homebridge[24765]: at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
Apr 14 18:35:00 phoscon homebridge[24765]: at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
Apr 14 18:35:00 phoscon homebridge[24765]: at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:616:16)
Apr 14 18:35:00 phoscon homebridge[24765]: at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:132:16)
Apr 14 18:35:00 phoscon homebridge[24765]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:421:14)
Apr 14 18:35:00 phoscon homebridge[24765]: at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:16:19
Apr 14 18:35:00 phoscon homebridge[24765]: at HuePlatform.accessories (/usr/local/lib/node_modules/homebridge-hue/lib/HuePlatform.js:334:5)
Apr 14 18:35:00 phoscon homebridge[24765]: [2020-4-14 18:35:00] Got SIGTERM, shutting down Homebridge...
Apr 14 18:35:02 phoscon homebridge[24765]: [2020-4-14 18:35:02] [Config] Homebridge Config UI X v4.14.0 is listening on :: port 8080
hmm ich hba ebeide Vorschläge gemacht und nachdem ich den RM Befehl gemacht habe startet Sie glaub ich nciht mehr korrekt durch.
