Kann jemand helfen. Ich hänge in einer Neustartschleife fest.
homebridge@raspberrypi:~ $ homebridge -I -U /var/homebridge
Initializing HAP-NodeJS v0.9.1...
[20/02/2021, 12:56:43] Loaded config.json with 1 accessories and 11 platforms.
[20/02/2021, 12:56:44] Loaded 5 cached accessories from cachedAccessories.
[20/02/2021, 12:56:44] ---
[20/02/2021, 12:56:46] Loaded plugin: [email protected]
[20/02/2021, 12:56:46] Registering platform 'homebridge-alexa.Alexa'
[20/02/2021, 12:56:46] ---
[20/02/2021, 12:56:46] Registering platform 'homebridge-apple-tv-remote.AppleTvPlatform'
[20/02/2021, 12:56:46] Registering platform 'homebridge-automation-switches.AutomationSwitches'
[20/02/2021, 12:56:47] Loaded plugin: [email protected]
[20/02/2021, 12:56:47] Registering platform 'homebridge-config-ui-x.config'
[20/02/2021, 12:56:47] ---
[20/02/2021, 12:56:47] Registering platform 'homebridge-dreambox.Dreambox'
[20/02/2021, 12:56:47] Registering platform 'homebridge-harmony.HarmonyHubWebSocket'
[20/02/2021, 12:56:47] Registering accessory 'homebridge-pihole.Pihole'
[20/02/2021, 12:56:47] Loading 11 platforms...
[20/02/2021, 12:56:47] [Config] Initializing config platform...
[20/02/2021, 12:56:47] [Config] Spawning homebridge-config-ui-x with PID 12617
[20/02/2021, 12:56:47] [Alexa] Initializing Alexa platform...
[20/02/2021, 12:56:47] [Alexa] homebridge-alexa v0.5.26, node v14.15.5, homebridge v1.3.0
[20/02/2021, 12:56:47] Initializing platform accessory 'Alexa'...
[20/02/2021, 12:56:47] [AutomationSwitches] Initializing AutomationSwitches platform...
[20/02/2021, 12:56:47] [AutomationSwitches] AutomationSwitchesPlatform Plugin Loaded - Version 3.2.1
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Alarmanlage"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Alarmanlage is stored in file switch.CA90F3030C1A.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Alarmanlage'...
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Alle Fenster"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Alle Fenster is stored in file switch.BF2E1A9391FF.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Alle Fenster'...
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Flutlicht"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Flutlicht is stored in file switch.19E963DE5CA3.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Flutlicht'...
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Schrankwandbeleuchtung"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Schrankwandbeleuchtung is stored in file switch.81306167FD22.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Schrankwandbeleuchtung'...
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Terassenheizung"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Terassenheizung is stored in file switch.C4815CA11A5E.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Terassenheizung'...
[20/02/2021, 12:56:47] [AutomationSwitches] Found automation switch in config: "Harmony Gästezimmer"
[20/02/2021, 12:56:47] [AutomationSwitches] Switch Harmony Gästezimmer is stored in file switch.7499189655B4.json
[20/02/2021, 12:56:47] Initializing platform accessory 'Harmony Gästezimmer'...
[20/02/2021, 12:56:47] [Dreambox] Initializing Dreambox platform...
[20/02/2021, 12:56:47] [Apple TV Platform] Initializing AppleTvPlatform platform...
[20/02/2021, 12:56:47] [Harmony Wohnzimmer] Initializing HarmonyHubWebSocket platform...
[20/02/2021, 12:56:47] [Harmony Wohnzimmer] HarmonyPlatform Init
[20/02/2021, 12:56:47] Loading 1 accessories...
[20/02/2021, 12:56:47] [Pihole] Initializing Pihole accessory...
[20/02/2021, 12:56:47] [Apple TV Platform] Initialing platform...
[20/02/2021, 12:56:47] [Apple TV Platform] [Apple TV] Initializing...
[20/02/2021, 12:56:47] [Apple TV Platform] [Apple TV] Adding on/off switch
[20/02/2021, 12:56:47] [Apple TV Platform] [Apple TV] Adding play/pause switch
[20/02/2021, 12:56:47] [Harmony Wohnzimmer] DidFinishLaunching
[20/02/2021, 12:56:47] [Harmony Wohnzimmer] (Harmony Wohnzimmer)INFO - Loading activities...
[20/02/2021, 12:56:47] [Harmony Wohnzimmer] (Harmony Gaestezimmer)INFO - Loading activities...
Preparing Advertiser for 'Homebridge 4DF0' using bonjour-hap backend!
Setup Payload:
X-HM://00248YCK533DE
Scan this code with your HomeKit app on your iOS device to pair with Homebridge.
│ XXX-XX-XXX
Starting to advertise 'Homebridge 4DF0' using bonjour-hap backend!
[20/02/2021, 12:56:47] Homebridge v1.3.0 (Homebridge) is running on port 51826.
[20/02/2021, 12:56:48] [Dreambox] Device: 192.168.123.24, configured 157 channel(s)
Error: Cannot add more than 100 services to a single accessory!
at Accessory.addService (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:452:13)
at Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:1106:22)
at BridgeService.handlePublishExternalAccessories (/usr/local/lib/node_modules/homebridge/src/bridgeService.ts:428:20)
at processTicksAndRejections (internal/process/task_queues.js:93:5)
[20/02/2021, 12:56:48] Got SIGTERM, shutting down Homebridge...
[20/02/2021, 12:56:48] [Apple TV Platform] Shutting down Apple TV clients...
[20/02/2021, 12:56:48] [Harmony Wohnzimmer] INFO - shutdown
[20/02/2021, 12:56:49] [Harmony Wohnzimmer] (Harmony Gaestezimmer)Error - Error retrieving info from hub : WebSocket closed with reason: Normal connection closure (1000).-(1)
[20/02/2021, 12:56:50] [Harmony Wohnzimmer] (Harmony Wohnzimmer)Error - Error retrieving info from hub : WebSocket closed with reason: Normal connection closure (1000).-(1)
[20/02/2021, 12:56:50] [Apple TV Platform] [Apple TV] Connected
[20/02/2021, 12:56:52] [Homebridge UI] Homebridge Config UI X v4.39.0 is listening on :: port 8080
