Hallo;
folgendes Problem. Ich möchte mein RaspBeeII mit meiner Homebridge verbinden.
Plugin installiert und das ist mein Log:
Loaded config.json with 1 accessories and 3 platforms.
[01/11/2020, 21:47:04] ---
[01/11/2020, 21:47:06] Loaded plugin: [email protected]
[01/11/2020, 21:47:06] Registering platform 'homebridge-alexa.Alexa'
[01/11/2020, 21:47:06] ---
[01/11/2020, 21:47:06] Registering platform 'homebridge-config-ui-x.config'
[01/11/2020, 21:47:06] The plugin "homebridge-hue" requires Node version of ^12.19.0 which does not satisfy the current Node version of v14.15.0. You may need to upgrade your installation of Node.
[01/11/2020, 21:47:08] Loaded plugin: [email protected]
[01/11/2020, 21:47:08] Registering platform 'homebridge-hue.Hue'
[01/11/2020, 21:47:08] ---
[01/11/2020, 21:47:08] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
[01/11/2020, 21:47:08] Loading 3 platforms...
[01/11/2020, 21:47:08] [Hue] Initializing Hue platform...
[01/11/2020, 21:47:08] [Hue] homebridge-hue v0.11.77, node v14.15.0, homebridge v1.1.6
[01/11/2020, 21:47:08] [Hue] warning: not using recommended node version v12.19.0 LTS
[01/11/2020, 21:47:08] [Config] Initializing config platform...
[01/11/2020, 21:47:08] [Config] Spawning homebridge-config-ui-x with PID 22575
[01/11/2020, 21:47:08] [Alexa] Initializing Alexa platform...
[01/11/2020, 21:47:08] [Alexa] homebridge-alexa v0.5.16, node v14.15.0, homebridge v1.1.6
[01/11/2020, 21:47:08] Initializing platform accessory 'Alexa'...
[01/11/2020, 21:47:08] Loading 1 accessories...
[01/11/2020, 21:47:08] [R2D2] Initializing XiaomiRoborockVacuum accessory...
HAP Warning: Characteristic 000000AC-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000040-0000-1000-8000-0026BB765291. Adding anyway.
HAP Warning: Characteristic 000000AB-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000040-0000-1000-8000-0026BB765291. Adding anyway.
[01/11/2020, 21:47:09] [R2D2] STA getDevice | Connected to: 192.168.178.22
[01/11/2020, 21:47:09] [R2D2] STA getDevice | Model: roborock.vacuum.s5
[01/11/2020, 21:47:09] [R2D2] STA getDevice | State: charging
[01/11/2020, 21:47:09] [R2D2] STA getDevice | FanSpeed: 102
[01/11/2020, 21:47:09] [R2D2] STA getDevice | BatteryLevel: 100
[01/11/2020, 21:47:09] [R2D2] INF getSerialNumber | roborock.vacuum.s5 | Serial Number is R0018S92431855
[01/11/2020, 21:47:09] [R2D2] STA getDevice | Serialnumber: R0018S92431855
[01/11/2020, 21:47:09] [R2D2] INF getFirmware | roborock.vacuum.s5 | Firmwareversion is 3.5.7_002008
[01/11/2020, 21:47:09] [R2D2] STA getDevice | Firmwareversion: 3.5.7_002008
[01/11/2020, 21:47:09] [R2D2] INF changedCleaning | roborock.vacuum.s5 | Cleaning is OFF.
[01/11/2020, 21:47:09] [R2D2] MON changedCharging | roborock.vacuum.s5 | ChargingState is now true
[01/11/2020, 21:47:09] [R2D2] INF changedCharging | roborock.vacuum.s5 | Charging is active
[01/11/2020, 21:47:09] [R2D2] INF changedCharging | roborock.vacuum.s5 | Robot was docked.
[01/11/2020, 21:47:09] [R2D2] MON changedSpeed | roborock.vacuum.s5 | FanSpeed is now 102%
[01/11/2020, 21:47:09] [R2D2] INF changedSpeed | roborock.vacuum.s5 | Speed was changed to 102% (Balanced), for HomeKit 60%
[01/11/2020, 21:47:09] [R2D2] INF changedPause | roborock.vacuum.s5 | Paused not possible, no cleaning
[01/11/2020, 21:47:09] [Hue] searching bridges and gateways
[01/11/2020, 21:47:12] [Homebridge UI] Homebridge Config UI X v4.31.0 is listening on :: port 8080
[01/11/2020, 21:47:14] [Hue] Phoscon-GW: dresden elektronik deCONZ gateway v2.5.85, api v1.16.0
[01/11/2020, 21:47:14] [Hue] Phoscon-GW: warning: not using recommended deCONZ gateway version 2.5.84
[01/11/2020, 21:47:14] [Hue] Phoscon-GW: 1 accessories
[01/11/2020, 21:47:17] [Hue] 192.***.***.32: 192.168.178.32:80: cannot connect: EHOSTUNREACH - retrying in 15s
[01/11/2020, 21:47:28] [Alexa] ERROR: HAP Discovery failed, please review config
[01/11/2020, 21:47:35] [Hue] 192.***.***.32: 192.168.178.32:80: cannot connect: EHOSTUNREACH - retrying in 15s
Die IP .32 war mal mein iPhone. aber aktuell nicht und ich habe die IP bereits aus der Fritzbox gelöscht.
Das ist meine Konfig:
"bridge": {
"name": "Homebridge",
"username": "XXXXXXXXXXXXX",
"manufacturer": "homebridge.io",
"model": "homebridge",
"port": 51826,
"pin": "XXXXXX"
"platforms": [
"platform": "Hue",
"users": {
"00212EFFFF062033": "86AD25352F"
"lights": true
"platform": "config",
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "red",
"sudo": true,
"log": {
"method": "custom",
Woher kommt dieser Fehler? Muss ich irgendetwas updaten? Eigentlich ist alles up to date.
Vielen Dank.
Ich möchte erstmal nur einen Aqara Sensor anlernen und dann mit Ikea Lampen weiter machen. Nur erstmal muss alles Laufen. Lerne Homebridge gerade erst kennen
