Beiträge von Beckumer24
    Leider haben die Befehle
    Hallo scschuste,
    leider haben die Befehle bei mir das Problem nicht lösen können.Kannst du mir helfen ?
    USER: pi
    DIR: /usr/local
    CMD: sudo -E -n npm install -g [email protected]
    TypeError: Class extends value undefined is not a constructor or null
    at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/agent.js:114:44)
    at Module._compile (node:internal/modules/cjs/loader:1101:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    at Module.load (node:internal/modules/cjs/loader:981:32)
    at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    at Module.require (node:internal/modules/cjs/loader:1005:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:5:33)
    at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:161:25)
    Command failed. Please review log for details.
    Aus dem Protokoll
    [11/20/2021, 9:04:57 PM] [Homebridge UI] Running Command: sudo -E -n npm install -g [email protected]
    [11/20/2021, 9:05:01 PM] [Homebridge UI] Command failed. Please review log for details.
