Danke Patrick, das hat das Problem behoben ![]()
Beiträge von mc77de
Moin Dampf,
anbei das Log der homebridge:
Alles anzeigen[06/02/2022, 10:29:34] [HB Supervisor] Restarting Homebridge... [06/02/2022, 10:29:34] [HB Supervisor] Starting Homebridge with extra flags: -I [06/02/2022, 10:29:35] [HB Supervisor] Started Homebridge v1.4.0 with PID: 8571 [06/02/2022, 10:29:37] Loaded config.json with 0 accessories and 4 platforms. [06/02/2022, 10:29:37] Loaded 5 cached accessories from cachedAccessories. [06/02/2022, 10:29:37] --- [06/02/2022, 10:29:39] Loaded plugin: [email protected] [06/02/2022, 10:29:39] Registering platform 'homebridge-config-ui-x.config' [06/02/2022, 10:29:39] --- [06/02/2022, 10:29:39] Loaded plugin: [email protected] [06/02/2022, 10:29:42] Registering platform 'homebridge-fritz-platform.FritzPlatform' [06/02/2022, 10:29:42] --- [06/02/2022, 10:29:47] Loaded plugin: [email protected] [06/02/2022, 10:29:47] Registering platform 'homebridge-hue.Hue' [06/02/2022, 10:29:47] --- [06/02/2022, 10:29:47] Loaded plugin: @switchbot/[email protected] [06/02/2022, 10:29:47] Registering platform '@switchbot/homebridge-switchbot.SwitchBot' [06/02/2022, 10:29:47] --- [06/02/2022, 10:29:47] Loading 4 platforms... [06/02/2022, 10:29:47] [Config] Initializing config platform... [06/02/2022, 10:29:47] [Config] Running in Service Mode [06/02/2022, 10:29:47] [Fritzbox] Initializing FritzPlatform platform... [06/02/2022, 10:29:51] [Fritzbox] One of the ROUTER devices has no name configured. This device will be skipped. [06/02/2022, 10:29:51] [Fritzbox] One of the SMARTHOME devices has no name configured. This device will be skipped. [06/02/2022, 10:29:51] [SwitchBot] Initializing SwitchBot platform... [06/02/2022, 10:29:51] [Conbee] Initializing Hue platform... [06/02/2022, 10:29:52] [Conbee] homebridge-hue v0.13.36, node v16.13.2, homebridge v1.4.0 [06/02/2022, 10:29:52] [Fritzbox] Fritzbox: Configuring cached accessory... [06/02/2022, 10:29:52] [Fritzbox] Außenbeleuchtung: Configuring cached accessory... [06/02/2022, 10:29:52] [Fritzbox] Fritzbox: Setup accessory... [06/02/2022, 10:29:52] [Fritzbox] Außenbeleuchtung: Setup accessory... [06/02/2022, 10:29:52] [Conbee] Phoscon-GW: dresden elektronik deCONZ gateway v2.14.0, api v1.16.0 [06/02/2022, 10:29:52] [Conbee] Phoscon-GW: warning: not using recommended deCONZ gateway version 2.13.4 [06/02/2022, 10:29:52] [Conbee] Phoscon-GW: 1 accessories [06/02/2022, 10:29:52] [Conbee] Phoscon-GW: websocket connected to ws://127.0.0.1:4531 [06/02/2022, 10:29:52] [Conbee] masked debug info dumped to /var/lib/homebridge/homebridge-hue.json.gz [06/02/2022, 10:29:52] Initializing platform accessory 'Phoscon-GW'... [06/02/2022, 10:29:52] [Conbee] Phoscon-GW: 3 services Setup Payload: X-HM://0024YF1D899OJ Enter this code with your HomeKit app on your iOS device to pair with Homebridge: ┌────────────┐ │secret │ └────────────┘ [06/02/2022, 10:29:52] Homebridge v1.4.0 (HAP v0.10.0) (Homebridge B948) is running on port 51938. [06/02/2022, 10:29:52] [SwitchBot] Total SwitchBot Devices Found: 1 [06/02/2022, 10:29:52] [SwitchBot] Total IR Devices Found: 2 [06/02/2022, 10:29:52] [SwitchBot] Restoring existing accessory from cache: Licht DeviceID: 02-202201281737-77291340 [06/02/2022, 10:29:52] [SwitchBot] Restoring existing accessory from cache: Ventilator DeviceID: 02-202201281740-58236529 [06/02/2022, 10:29:55] [Conbee] heartbeat 2, drift 423Ich hab diverse Threads durchgearbeitet, ich bin mal so frei und poste die Links:
Phoscon mit Homebridge koppeln
Verzögerten Start hieraus übernommen
Für mich sieht es so aus, als würde der Schalter gar nicht in erst an die Homebridge durchgereicht werden. Da kommt imho nur der schnöde Daylight-Sensor an.
In der deconz Software habe ich den Schalter lediglich mittels UI gepaired. Mehr habe ich dort bislang nicht gemacht.
ich habe vor ein paar Tagen begonnen via Homebridge auf Rapsberry meine Geräte Homekit-fähig zu machen. Mittels IR-Blaster auch schon so einige Leuchten, Ventilatoren aber auch meine Fritz-Box eingebunden. Dieses Woche hab ich mir einen Conbee II USB-Stick geholt und einen Hue Dimmer Switch gekauft. Mit dem Dimmer Switch wollte ich eine Leuchte und den Ventilator steuern. Leider bekomm ich den Hue Dimmer Switch aber nicht in Homekit eingebunden.
Meine Homebridge-Konfiguration:
Alles anzeigen{ "bridge": { "name": "Homebridge B948", "username": "secret", "port": 51938, "pin": "secret" }, "accessories": [], "platforms": [ { "name": "Config", "port": 8581, "platform": "config" }, { "name": "Fritzbox", "warn": true, "error": true, "extendedError": true, "devices": [ { "active": true, "name": "Fritzbox", "host": "192.168.178.1", "username": "secret", "password": "secret", "ssl": true, "tr064": true, "igd": false, "wifiUnits": 2, "master": true, "connection": "cable" }, { "active": true, "ssl": true, "tr064": true, "igd": false, "wifiUnits": 2, "connection": "cable" } ], "smarthome": [ { "active": true, "name": "Außenbeleuchtung", "ain": "secret", "group": false, "accType": "switch" }, { "active": true } ], "options": { "polling": { "timer": 15 } }, "platform": "FritzPlatform" }, { "name": "SwitchBot", "credentials": { "openToken": "secret", "notice": "Keep your token a secret!" }, "platform": "SwitchBot" }, { "name": "Conbee", "anyOn": true, "effects": true, "hosts": [ "127.0.0.1:4530" ], "lights": true, "linkButton": true, "nativeHomeKitLights": true, "nativeHomeKitSensors": false, // war true,nach Anleitung auf false gesetzt, kein Effekt. "resource": true, "excludeSensorTypes": [], "platform": "Hue", "users": { "secret": "secret" } } ] }Hat von euch jemand eine Idee, was ich als nächstes probieren könnte?
Anbei noch ein paar Screenshots:
