Es ist die Originaldatei gepostet, habe es nochmal wie folgt ausgeführt:
pi@RaspberryPi:~ $ cp /home/pi/hbridge_install/files/config.json /var/homebridge/
pi@RaspberryPi:~ $ sudo systemctl restart homebridge
pi@RaspberryPi:~ $ sudo systemctl status homebridge
? homebridge.service - Node.js HomeKit Server
Loaded: loaded (/etc/systemd/system/homebridge.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Mi 2017-06-21 21:35:06 CEST; 5s ago
Process: 20784 ExecStart=/usr/local/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
Main PID: 20784 (code=exited, status=1/FAILURE)
CGroup: /system.slice/homebridge.service
Jun 21 21:35:06 RaspberryPi systemd[1]: Unit homebridge.service entered fail....
Hint: Some lines were ellipsized, use -l to show in full.
Scheint ein anders Problem zu sein, welches hier beschrieben wird:
pi@RaspberryPi:~ $ homebridge
[2017-6-21 21:48:46] Homebridge is running on port 51826.
Loading custom types: Got an parser error: SyntaxError: Unexpected end of JSON input
at JSON.parse (<anonymous>)
at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-knx/lib/customtypes/knxthermostat.js:53:29)
at emitNone (events.js:91:20)
at IncomingMessage.emit (events.js:188:7)
at endReadableNT (_stream_readable.js:975:12)
at _combinedTickCallback (internal/process/next_tick.js:80:11)
at process._tickCallback (internal/process/next_tick.js:104:9)
Don't care, continue...
Post #261
