Ich bekomme das remote-outlet plugin nicht installiert. Habe Homebridge neu aufgesetzt mit Node 10.14.1 und nach dem config-ui plugin als erstes das remote-outllet installieren wollen. Nun bekomme ich folgende Fehlermeldung.
home/homebridge/.node-gyp/10.14.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
declarator __attribute__((deprecated(message)))
rcswitch.target.mk:103: recipe for target 'Release/obj.target/rcswitch/src/RCSwitchNode.o' failed
make: *** [Release/obj.target/rcswitch/src/RCSwitchNode.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/homebridge-remote-outlet/node_modules/rcswitch/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! stack at ChildProcess.emit (events.js:182:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
gyp ERR! System Linux 4.14.79-v7+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/homebridge-remote-outlet/node_modules/rcswitch
gyp ERR! node -v v10.14.1
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/homebridge/.npm/_logs/2018-12-05T17_52_46_001Z-debug.log
Command failed. Please review log for details
