Nov 03 10:44:04 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Nov 03 10:44:04 raspberrypi homebridge[5675]: [2019-11-3 10:44:04] Got SIGTERM, shutting down Homebridge...
Nov 03 10:44:05 raspberrypi homebridge[5675]: [2019-11-3 10:44:05] [My FritzBox] Updating guest WLAN
Nov 03 10:44:05 raspberrypi homebridge[5675]: [2019-11-3 10:44:05] [My FritzBox] Getting guest WLAN state
Nov 03 10:44:10 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=143/n/a
Nov 03 10:44:10 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
Nov 03 10:44:10 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
Nov 03 10:44:10 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Nov 03 10:44:12 raspberrypi homebridge[8928]: [2019-11-3 10:44:12] Loaded config.json with 0 accessories and 6 platforms.
Nov 03 10:44:12 raspberrypi homebridge[8928]: [2019-11-3 10:44:12] ---
Nov 03 10:44:14 raspberrypi homebridge[8928]: [2019-11-3 10:44:14] Loaded plugin: homebridge-alexa
Nov 03 10:44:14 raspberrypi homebridge[8928]: [2019-11-3 10:44:14] Registering platform 'homebridge-alexa.Alexa'
Nov 03 10:44:14 raspberrypi homebridge[8928]: [2019-11-3 10:44:14] ---
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] Loaded plugin: homebridge-automower
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] Registering platform 'homebridge-automower.HomebridgeAutomower'
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] ---
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] Loaded plugin: homebridge-config-ui-x
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] Registering platform 'homebridge-config-ui-x.config'
Nov 03 10:44:15 raspberrypi homebridge[8928]: [2019-11-3 10:44:15] Loaded plugin: homebridge-fritz
Nov 03 10:44:16 raspberrypi homebridge[8928]: [2019-11-3 10:44:16] Registering platform 'homebridge-fritz.Fritz!Box'
Nov 03 10:44:16 raspberrypi homebridge[8928]: [2019-11-3 10:44:16] ---
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Loaded plugin: homebridge-hydrawise
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Registering platform 'homebridge-hydrawise.Hydrawise'
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] ---
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Loaded plugin: homebridge-platform-wemo
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Registering platform 'homebridge-platform-wemo.BelkinWeMo'
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Loading 6 platforms...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Config] Initializing config platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Config] Spawning homebridge-config-ui-x with PID 8956
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [WeMo Platform] Initializing BelkinWeMo platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [My FritzBox] Initializing Fritz!Box platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [My FritzBox] Deprecated `hide` setting is ignored. Use `devices` instead
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Hydrawise] Initializing Hydrawise platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Alexa] Initializing Alexa platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Alexa] homebridge-alexa v0.4.39, node v11.3.0, homebridge v0.4.50
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] [Kevin] Initializing HomebridgeAutomower platform...
Nov 03 10:44:17 raspberrypi homebridge[8928]: [2019-11-3 10:44:17] Loading 0 accessories...
Nov 03 10:44:18 raspberrypi homebridge[8928]: [2019-11-3 10:44:18] [WeMo Platform] Online: Wohnzimmer [B4750E72C5A8]
Nov 03 10:44:18 raspberrypi homebridge[8928]: [2019-11-3 10:44:18] [WeMo Platform] Online: Treppe [B4750E72CC04]
Nov 03 10:44:18 raspberrypi homebridge[8928]: [2019-11-3 10:44:18] [WeMo Platform] Online: Antenne [B4750E722FBC]
Nov 03 10:44:18 raspberrypi homebridge[8928]: [2019-11-3 10:44:18] [WeMo Platform] Online: Panik innen [B4750E722D44]
Nov 03 10:44:21 raspberrypi homebridge[8928]: [2019-11-3 10:44:20] [Hydrawise] { StatusCodeError: 404 - "Hydrawise API has moved. Please update your settings to point to https://app.hydrawise.com/api/v1/..."
Nov 03 10:44:21 raspberrypi homebridge[8928]: at new StatusCodeError (/usr/local/lib/node_modules/homebridge-hydrawise/node_modules/request-promise/lib/errors.js:32:15)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at Request.RP$callback [as _callback] (/usr/local/lib/node_modules/homebridge-hydrawise/node_modules/request-promise/lib/rp.js:77:29)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at Request.self.callback (/usr/local/lib/node_modules/homebridge-hydrawise/node_modules/request/request.js:185:22)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at Request.emit (events.js:182:13)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-hydrawise/node_modules/request/request.js:1161:10)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-hydrawise/node_modules/request/request.js:1083:12)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at Object.onceWrapper (events.js:273:13)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at IncomingMessage.emit (events.js:187:15)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at endReadableNT (_stream_readable.js:1098:12)
Nov 03 10:44:21 raspberrypi homebridge[8928]: at process.internalTickCallback (internal/process/next_tick.js:72:19)
Nov 03 10:44:21 raspberrypi homebridge[8928]: name: 'StatusCodeError',
Nov 03 10:44:21 raspberrypi homebridge[8928]: statusCode: 404,
Nov 03 10:44:21 raspberrypi homebridge[8928]: message:
Nov 03 10:44:21 raspberrypi homebridge[8928]: '404 - "Hydrawise API has moved. Please update your settings to point to https://app.hydrawise.com/api/v1/..."',
Nov 03 10:44:21 raspberrypi homebridge[8928]: error:
Nov 03 10:44:21 raspberrypi homebridge[8928]: 'Hydrawise API has moved. Please update your settings to point to https://app.hydrawise.com/api/v1/...',
Nov 03 10:44:21 raspberrypi homebridge[8928]: options:
Nov 03 10:44:21 raspberrypi homebridge[8928]: { method: 'GET',
Nov 03 10:44:21 raspberrypi homebridge[8928]: uri: 'https://hydrawise.com/api/v1/statusschedule.php',
Nov 03 10:44:21 raspberrypi homebridge[8928]: json: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: qs: { tag: '', hours: '168', api_key: '09F7-2345-2345-36FA' },
Nov 03 10:44:21 raspberrypi homebridge[8928]: callback: undefined,
Nov 03 10:44:21 raspberrypi homebridge[8928]: transform: undefined,
Nov 03 10:44:21 raspberrypi homebridge[8928]: simple: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: resolveWithFullResponse: false },
Nov 03 10:44:21 raspberrypi homebridge[8928]: response:
Nov 03 10:44:21 raspberrypi homebridge[8928]: IncomingMessage {
Nov 03 10:44:21 raspberrypi homebridge[8928]: _readableState:
Nov 03 10:44:21 raspberrypi homebridge[8928]: ReadableState {
Nov 03 10:44:21 raspberrypi homebridge[8928]: objectMode: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: highWaterMark: 16384,
Nov 03 10:44:21 raspberrypi homebridge[8928]: buffer: BufferList { head: null, tail: null, length: 0 },
Nov 03 10:44:21 raspberrypi homebridge[8928]: length: 0,
Nov 03 10:44:21 raspberrypi homebridge[8928]: pipes: null,
Nov 03 10:44:21 raspberrypi homebridge[8928]: pipesCount: 0,
Nov 03 10:44:21 raspberrypi homebridge[8928]: flowing: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: ended: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: endEmitted: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: reading: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: sync: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: needReadable: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: emittedReadable: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: readableListening: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: resumeScheduled: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: emitClose: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: autoDestroy: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: destroyed: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: defaultEncoding: 'utf8',
Nov 03 10:44:21 raspberrypi homebridge[8928]: awaitDrain: 0,
Nov 03 10:44:21 raspberrypi homebridge[8928]: readingMore: true,
Nov 03 10:44:21 raspberrypi homebridge[8928]: decoder: null,
Nov 03 10:44:21 raspberrypi homebridge[8928]: encoding: null },
Nov 03 10:44:21 raspberrypi homebridge[8928]: readable: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: _events:
Nov 03 10:44:21 raspberrypi homebridge[8928]: [Object: null prototype] {
Nov 03 10:44:21 raspberrypi homebridge[8928]: end: [ [Function: responseOnEnd], [Function] ],
Nov 03 10:44:21 raspberrypi homebridge[8928]: close: [ [Function], [Function] ],
Nov 03 10:44:21 raspberrypi homebridge[8928]: data: [Function],
Nov 03 10:44:21 raspberrypi homebridge[8928]: error: [Function] },
Nov 03 10:44:21 raspberrypi homebridge[8928]: _eventsCount: 4,
Nov 03 10:44:21 raspberrypi homebridge[8928]: _maxListeners: undefined,
Nov 03 10:44:21 raspberrypi homebridge[8928]: socket:
Nov 03 10:44:21 raspberrypi homebridge[8928]: TLSSocket {
Nov 03 10:44:21 raspberrypi homebridge[8928]: _tlsOptions:
Nov 03 10:44:21 raspberrypi homebridge[8928]: { pipe: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: secureContext: SecureContext { context: SecureContext {}, singleUse: true },
Nov 03 10:44:21 raspberrypi homebridge[8928]: isServer: false,
Nov 03 10:44:21 raspberrypi homebridge[8928]: requestCert: true,
