Hallo Verzeihung das mit den log.
Jan 30 23:10:43 raspberrypi homebridge[2121]: [1/30/2020, 23:10:43] [Config] Homebridge Config UI X v4.9.0 is listening on :: port 8080
Jan 30 23:10:46 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Jan 30 23:10:46 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Jan 30 23:10:56 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Jan 30 23:10:56 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 2.
Jan 30 23:10:56 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Jan 30 23:10:56 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Loaded config.json with 1 accessories and 2 platforms.
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] ---
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] ====================
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] ERROR LOADING PLUGIN homebridge-broadlink-rm:
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Error: Cannot find module 'hap-nodejs'
Jan 30 23:10:57 raspberrypi homebridge[2165]: Require stack:
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/dist/accessory.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/dist/index.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge-broadlink-rm/platform.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge-broadlink-rm/index.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge/lib/plugin.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge/lib/server.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge/lib/cli.js
Jan 30 23:10:57 raspberrypi homebridge[2165]: - /usr/local/lib/node_modules/homebridge/bin/homebridge
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:793:17)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Function.Module._load (internal/modules/cjs/loader.js:686:27)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Module.require (internal/modules/cjs/loader.js:848:19)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at require (internal/modules/cjs/helpers.js:74:18)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/dist/accessory.js:13:22)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Module._compile (internal/modules/cjs/loader.js:955:30)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Module.load (internal/modules/cjs/loader.js:811:32)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Loaded plugin: homebridgefconfig-ui-x
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Registering platform 'homebridge-config-ui-x.config'
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Loading 2 platforms...
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] [Config] Initializing config platform...
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] [Config] Spawning homebridge-config-ui-x with PID 2185
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Error: The requested platform 'BroadlinkRM' was not registered by any plugin.
Jan 30 23:10:57 raspberrypi homebridge[2165]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:134:13)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:327:45)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Jan 30 23:10:57 raspberrypi homebridge[2165]: at Function.Module.runMain (internal/modules/cjs/loader.js:1043:10)
Jan 30 23:10:57 raspberrypi homebridge[2165]: [1/30/2020, 23:10:57] Got SIGTERM, shutting down Homebridge...
Ich lese da etwas von "ERROR LOADING PLUGIN homebridge-broadlink-rm" , "Error: Cannot find module 'hap-nodejs" und "Error: The requested platform 'BroadlinkRM' was not registered by any plugin" nur sagt mir das als Anfänger leider noch nichts.
