Mach doch mal ein Update: sudo apt-get update und versuch's noch mal.
Ist die gleiche Fehlermeldung:
makesmart@makesmart-server:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Fetched 15.0 kB in 1s (15.4 kB/s)
Reading package lists... Done
makesmart@makesmart-server:~ $ sudo apt-get install samba
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
samba : Depends: python-samba but it is not going to be installed
Depends: samba-common-bin (= 2:4.5.16+dfsg-1+deb9u4) but it is not going to be installed
Depends: libpython2.7 (>= 2.7) but it is not going to be installed
Depends: libwbclient0 (= 2:4.5.16+dfsg-1+deb9u4) but 2:4.9.5+dfsg-5+deb10u1+rpi1 is to be installed
Depends: samba-libs (= 2:4.5.16+dfsg-1+deb9u4) but it is not going to be installed
Recommends: attr but it is not going to be installed
Recommends: samba-dsdb-modules but it is not going to be installed
Recommends: samba-vfs-modules but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
