ich habe eine bestehende und funktionierende Homebridge (Version 0.4.53). Mein Homematic Plugin hat die Version 0.0.219.
Jetzt habe ich meine erste Phillips Hue Lampe erhalten und würde diese gerne auch per HomeKit App steuern. Leider funktioniert es nicht die Lampe einzubinden. Kann mir jemand sagen was ich falsch mache? Es scheint alles zu laden aber die Lampe sehe ich nicht
"bridge": {
"name": "Homebridge",
"port": 51826,
"pin": "220-27-315"
"platforms": [
"platform": "HomeMatic",
"name": "HomeMatic",
"ccu_ip": "10.16.9.198",
"filter_device": [],
"filter_channel": [],
"outlets": [],
"doors": [],
"programs": [],
"accessories": [],
"subsection": "Homekit",
"enable_hmip": true,
"variables": []
"name": "Config",
"port": 7888,
"auth": "form",
"theme": "dark-mode",
"tempUnits": "c",
"sudo": true,
"log": {
"method": "systemd",
"service": "homebridge"
"platform": "config"
"name": "Hue",
"users": {
"xxx": "yyyy"
"anyOn": true,
"forceCt": true,
"hosts": [
"10.16.9.115"
"lights": true,
"nativeHomeKitLights": true,
"nativeHomeKitSensors": true,
"nupnp": true,
"resource": true,
"sensors": false,
"platform": "Hue"
"accessories": []
Im Logfile steht folgendes
[4/14/2020, 3:40:46 PM] [Config] Homebridge restart request received
[4/14/2020, 3:40:46 PM] [Config] Executing restart command: sudo -n systemctl restart homebridge
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl restart homebridge
pam_unix(sudo:session): session opened for user root by (uid=0)
Stopping Homebridge...
[4/14/2020, 3:40:46 PM] Got SIGTERM, shutting down Homebridge...
[4/14/2020, 3:40:46 PM] [HomeMatic] [RPC] Removing Event Server for Interface BidCos-RF.
[4/14/2020, 3:40:46 PM] [HomeMatic] [RPC] Removing Event Server for Interface HmIP-RF.
homebridge.service: Succeeded.
Stopped Homebridge.
homebridge.service: Found left-over process 12844 (homebridge-conf) in control group while starting unit. Ignoring.
This usually indicates unclean termination of a previous run, or service implementation deficiencies.
homebridge.service: Found left-over process 12998 (sh) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 12999 (sudo) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 13000 (systemctl) in control group while starting unit. Ignoring.
Started Homebridge.
pam_unix(sudo:session): session closed for user root
[4/14/2020, 3:40:47 PM] Loaded config.json with 0 accessories and 3 platforms.
[4/14/2020, 3:40:47 PM] ---
[4/14/2020, 3:40:47 PM] Loaded plugin: homebridge-config-ui-x
[4/14/2020, 3:40:47 PM] Registering platform 'homebridge-config-ui-x.config'
[4/14/2020, 3:40:47 PM] Loaded plugin: homebridge-homematic
[4/14/2020, 3:40:47 PM] Registering platform 'homebridge-homematic.HomeMatic'
[4/14/2020, 3:40:47 PM] Plugin /usr/lib/node_modules/homebridge-hue requires Node version of ^12.16.2 which does not satisfy the current Node version of v12.14.1. You may need to upgrade your installation of Node.
[4/14/2020, 3:40:48 PM] Loaded plugin: homebridge-hue
[4/14/2020, 3:40:48 PM] Registering platform 'homebridge-hue.Hue'
[4/14/2020, 3:40:48 PM] ---
[4/14/2020, 3:40:48 PM] Loading 3 platforms...
[4/14/2020, 3:40:48 PM] [HomeMatic] Initializing HomeMatic platform...
[4/14/2020, 3:40:48 PM] [HomeMatic] [Core] merging configurations
[4/14/2020, 3:40:48 PM] [HomeMatic] Homematic Plugin Version 0.0.219
[4/14/2020, 3:40:48 PM] [HomeMatic] Plugin by thkl https://github.com/thkl
[4/14/2020, 3:40:48 PM] [HomeMatic] Homematic is a registered trademark of the EQ-3 AG
[4/14/2020, 3:40:48 PM] [HomeMatic] Please report any issues to https://github.com/thkl/homebridge-homematic/issues
[4/14/2020, 3:40:48 PM] [HomeMatic] running in production mode
[4/14/2020, 3:40:48 PM] [HomeMatic] will connect to your ccu at 10.16.9.198
[4/14/2020, 3:40:48 PM] [HomeMatic] IMPORTANT !! Starting this version, your homematic custom configuration is located in /var/lib/homebridge/homematic_config.json
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] using xmprpc for communication with BidCos-RF
[4/14/2020, 3:40:48 PM] [HomeMatic] init RPC for BidCos-RF.
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] local ip used : 10.16.9.195. you may change that with local_ip parameter in config
[4/14/2020, 3:40:48 PM] [HomeMatic] init RPC for VirtualDevices.
[4/14/2020, 3:40:48 PM] [HomeMatic] init RPC for HmIP-RF.
[4/14/2020, 3:40:48 PM] [Config] Initializing config platform...
[4/14/2020, 3:40:48 PM] [Config] Spawning homebridge-config-ui-x with PID 13021
[4/14/2020, 3:40:48 PM] [Hue] Initializing Hue platform...
[4/14/2020, 3:40:48 PM] [Hue] homebridge-hue v0.11.62, node v12.14.1, homebridge v0.4.53
[4/14/2020, 3:40:48 PM] [Hue] warning: not using recommended node version v12.16.2 LTS
[4/14/2020, 3:40:48 PM] Loading 0 accessories...
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] server for interface BidCos-RF. is listening on port 9090.
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] Creating Local HTTP Client for CCU RPC Events
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] server for interface VirtualDevices. is listening on port 9093.
[4/14/2020, 3:40:48 PM] [HomeMatic] [RPC] server for interface HmIP-RF. is listening on port 9092.
[4/14/2020, 3:40:48 PM] [HomeMatic] if PONG is PONG CCU is alive
[4/14/2020, 3:40:49 PM] [Hue] Philips hue: Philips BSB002 bridge v1937113020, api v1.37.0
[4/14/2020, 3:40:50 PM] [Hue] Philips hue: 1 accessories
[4/14/2020, 3:40:50 PM] [Hue] masked debug info dumped to /var/lib/homebridge/homebridge-hue.json.gz
[4/14/2020, 3:40:50 PM] [Hue] Initializing platform accessory 'Philips hue'...
[4/14/2020, 3:40:50 PM] [Hue] Philips hue: 2 services
[4/14/2020, 3:40:50 PM] [Config] Homebridge Config UI X v4.15.1 is listening on :: port 7888
homebridge : TTY=pts/0 ; PWD=/var/lib/homebridge ; USER=root ; COMMAND=/usr/bin/journalctl -o cat -n 500 -f -u homebridge
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Aussenthermostat'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'BM Eingang'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'BM Küche'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'BM Wohnzimmer'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Heizung OG Bad'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Heizung Büro 1'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Heizung GaesteWC INT0000010 1'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Heizung Kinderzimmer 1'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Heizung Küche'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'LS Keller'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'LS Küche'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'LS Waschkeller'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'LS WZ1'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'MK DG 1'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS EG Fenster'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS EG GaesteWC'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS EG Küche'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS EG Terrasse'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS OG Bad'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS OG Balkon'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'OS OG Büro'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL Kueche'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL OG Balkon'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL OG Fenster Links'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL OG Fenster Rechts'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL WZ Fenster Links'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL WZ Fenster Rechts 4'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'RL WZ Terrasse'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'SD Latterne'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'SD Treppenaufgang'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'SD WZ Stehlampe'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'UP Eingang'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'UP Pool'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'UP Trockenkeller'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'WT DG Schlafzimmer 2'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'WT EG Wohnraum 2'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'WT KG Gästezimmer 2'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'WT KG Hauswirtschaft 2'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Rasen'...
[4/14/2020, 3:40:59 PM] [HomeMatic] Initializing platform accessory 'Hecke'...
Danke für Eure Hilfe.
Gruß
ABC
