8.5.2020, 09:34:24 - Loaded plugin "homebridge-fritz-platform".
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] **************************************************************
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] FritzPlatform v4.1.0 by SeydX
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] GitHub: https://github.com/SeydX/homebridge-fritz-platform
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] Email: [email protected]
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] start success...
8.5.2020, 09:34:24 - [FritzPlatform] [INFO] Auto Device Search is enabled, searching for devices in network...
8.5.2020, 09:34:25 - Bridge is running on port 51826.
8.5.2020, 09:34:29 - 2020-05-08T07:34:29.997Z FritzPlatform Found following devices:
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.015Z FritzPlatform [
8.5.2020, 09:34:30 - {
8.5.2020, 09:34:30 - name: 'FRITZ!Box 7490',
8.5.2020, 09:34:30 - address: '192.168.2.1',
8.5.2020, 09:34:30 - port: '49000',
8.5.2020, 09:34:30 - location: 'http://192.168.2.1:49000/tr64desc.xml',
8.5.2020, 09:34:30 - serial: 'FB-19216821'
8.5.2020, 09:34:30 - }
8.5.2020, 09:34:30 - ]
8.5.2020, 09:34:30 - [FritzPlatform] [INFO] Initializing config...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.028Z FritzPlatform Initializing extra accessories...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.031Z FritzPlatform Initializing extras...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.033Z FritzPlatform Initializing telegram...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.034Z FritzPlatform Initializing callmonitor...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.035Z FritzPlatform Generating config...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.066Z FritzPlatform Config.json loaded!
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.067Z FritzPlatform Writing new parameter into config.json...
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.078Z FritzPlatform Config.json refreshed!
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.079Z FritzPlatform {
8.5.2020, 09:34:30 - "platform": "FritzPlatform",
8.5.2020, 09:34:30 - "devices": {
8.5.2020, 09:34:30 - "FRITZ!Box 7490": {
8.5.2020, 09:34:30 - "active": true,
8.5.2020, 09:34:30 - "host": "fritz.box",
8.5.2020, 09:34:30 - "port": 49000,
8.5.2020, 09:34:30 - "username": "pi_home",
8.5.2020, 09:34:30 - "password": "irgendwas",
8.5.2020, 09:34:30 - "type": "dsl",
8.5.2020, 09:34:30 - "master": true,
8.5.2020, 09:34:30 - "mesh": true,
8.5.2020, 09:34:30 - "readOnly": false,
8.5.2020, 09:34:30 - "options": {
8.5.2020, 09:34:30 - "reconnect": true,
8.5.2020, 09:34:30 - "wifi2": [
8.5.2020, 09:34:30 - true,
8.5.2020, 09:34:30 - false
8.5.2020, 09:34:30 - ],
8.5.2020, 09:34:30 - "wifi5": [
8.5.2020, 09:34:30 - "wifiGuest": [
8.5.2020, 09:34:30 - "wps": [
8.5.2020, 09:34:30 - "aw": [
8.5.2020, 09:34:30 - "deflection": [
8.5.2020, 09:34:30 - "led": [
8.5.2020, 09:34:30 - "lock": [
8.5.2020, 09:34:30 - },
8.5.2020, 09:34:30 - "smarthome": {
8.5.2020, 09:34:30 - "Zahnbürste": {
8.5.2020, 09:34:30 - "ain": "087610430665",
8.5.2020, 09:34:30 - "tempSensor": true,
8.5.2020, 09:34:30 - "devType": "switch"
8.5.2020, 09:34:30 - "polling": 10,
8.5.2020, 09:34:30 - "timeout": 10,
8.5.2020, 09:34:30 - "clearCache": false,
8.5.2020, 09:34:30 - "debug": true,
8.5.2020, 09:34:30 - "disableAutoSearch": false,
8.5.2020, 09:34:30 - "plugin_map": {
8.5.2020, 09:34:30 - "plugin_name": "homebridge-fritz-platform"
8.5.2020, 09:34:30 - "callmonitor": {
8.5.2020, 09:34:30 - "active": false,
8.5.2020, 09:34:30 - "ip": "0.0.0.0",
8.5.2020, 09:34:30 - "port": 1012,
8.5.2020, 09:34:30 - "country": "",
8.5.2020, 09:34:30 - "incomingTo": [],
8.5.2020, 09:34:30 - "outgoingFrom": []
8.5.2020, 09:34:30 - "presence": {
8.5.2020, 09:34:30 - "user": [
8.5.2020, 09:34:30 - "name": "Test User",
8.5.2020, 09:34:30 - "address": "0.0.0.0"
8.5.2020, 09:34:30 - "anyone": false,
8.5.2020, 09:34:30 - "offDelay": 90,
8.5.2020, 09:34:30 - "onDelay": 15,
8.5.2020, 09:34:30 - "ping": false
8.5.2020, 09:34:30 - "wol": [
8.5.2020, 09:34:30 - "name": "Test Device",
8.5.2020, 09:34:30 - "address": "00:00:00:00:00:00"
8.5.2020, 09:34:30 - "phoneBook": {
8.5.2020, 09:34:30 - "blacklists": []
8.5.2020, 09:34:30 - "alarm": {
8.5.2020, 09:34:30 - "telNr": "",
8.5.2020, 09:34:30 - "duration": 30
8.5.2020, 09:34:30 - "wakeup": {
8.5.2020, 09:34:30 - "internNr": "",
8.5.2020, 09:34:30 - "ringlock": {
8.5.2020, 09:34:30 - "DECTphones": 1,
8.5.2020, 09:34:30 - "start": "11:00",
8.5.2020, 09:34:30 - "end": "22:00"
8.5.2020, 09:34:30 - "broadband": {
8.5.2020, 09:34:30 - "measureTime": 5
8.5.2020, 09:34:30 - "extReboot": {
8.5.2020, 09:34:30 - "cmdOn": "",
8.5.2020, 09:34:30 - "cmdOff": ""
8.5.2020, 09:34:30 - "telegram": {
8.5.2020, 09:34:30 - "token": "",
8.5.2020, 09:34:30 - "chatID": "",
8.5.2020, 09:34:30 - "in": "",
8.5.2020, 09:34:30 - "out": "",
8.5.2020, 09:34:30 - "anyoneIn": "",
8.5.2020, 09:34:30 - "anyoneOut": ""
8.5.2020, 09:34:30 - "incoming": "",
8.5.2020, 09:34:30 - "disconnected": ""
8.5.2020, 09:34:30 - "activated": "",
8.5.2020, 09:34:30 - "deactivated": ""
8.5.2020, 09:34:30 - "start": "",
8.5.2020, 09:34:30 - "finish": ""
8.5.2020, 09:34:30 - "disableAutoConfig": false
8.5.2020, 09:34:30 - 2020-05-08T07:34:30.080Z FritzPlatform Checking master device...
8.5.2020, 09:34:30 - [FritzPlatform] [INFO] Found 3 active devices...
8.5.2020, 09:34:31 - 2020-05-08T07:34:31.409Z FritzPlatformTR064 [TR064 Debug] FRITZ!Box 7490 api request 1: get /upnp/control/deviceinfo
8.5.2020, 09:34:31 - 2020-05-08T07:34:31.431Z FritzPlatformTR064 [TR064 Debug] FRITZ!Box 7490 api request 1: Ok (authenticated)
8.5.2020, 09:34:31 - 2020-05-08T07:34:31.433Z FritzPlatform Master device successfully confirmed
8.5.2020, 09:34:31 - 2020-05-08T07:34:31.434Z FritzPlatform Initializing smarthome list
8.5.2020, 09:34:31 - 2020-05-08T07:34:31.437Z FritzPlatformTR064 [TR064 Debug] FRITZ!Box 7490 api request 1: get /upnp/control/deviceconfig
8.5.2020, 09:34:32 - 2020-05-08T07:34:32.440Z FritzPlatform Device initialization finished
8.5.2020, 09:34:32 - [FritzPlatform] [INFO] Configuring accessory from cache: FRITZ!Box 7490
8.5.2020, 09:34:32 - [FritzPlatform] [INFO] FRITZ!Box 7490: Successfully logged in!
8.5.2020, 09:34:32 - 2020-05-08T07:34:32.971Z FritzPlatformTR064 [TR064 Debug] FRITZ!Box 7490 api request 1: get /upnp/control/userif
8.5.2020, 09:34:32 - [FritzPlatform] [INFO] Configuring accessory from cache: Zahnbürste
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.854Z FritzPlatform Zahnbürste: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.856Z FritzPlatform Zahnbürste: Following devices are currently registered:
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.857Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:34:34 - [FritzPlatform] [INFO] Configuring accessory from cache: Zahnbürste Temperature
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.866Z FritzPlatform Zahnbürste Temperature: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.868Z FritzPlatform Zahnbürste Temperature: Following devices are currently registered:
8.5.2020, 09:34:34 - 2020-05-08T07:34:34.869Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.859Z FritzPlatform Zahnbürste: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.862Z FritzPlatform Zahnbürste: Following devices are currently registered:
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.863Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.871Z FritzPlatform Zahnbürste Temperature: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.873Z FritzPlatform Zahnbürste Temperature: Following devices are currently registered:
8.5.2020, 09:34:44 - 2020-05-08T07:34:44.874Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.867Z FritzPlatform Zahnbürste: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.869Z FritzPlatform Zahnbürste: Following devices are currently registered:
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.871Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.877Z FritzPlatform Zahnbürste Temperature: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.877Z FritzPlatform Zahnbürste Temperature: Following devices are currently registered:
8.5.2020, 09:34:54 - 2020-05-08T07:34:54.878Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.872Z FritzPlatform Zahnbürste: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.874Z FritzPlatform Zahnbürste: Following devices are currently registered:
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.876Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.878Z FritzPlatform Zahnbürste Temperature: No device with AIN: 087610430665 found or not intialized yet!
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.880Z FritzPlatform Zahnbürste Temperature: Following devices are currently registered:
8.5.2020, 09:35:04 - 2020-05-08T07:35:04.880Z FritzPlatform No Smarthome devices registered!
8.5.2020, 09:35:11 - Got SIGINT, shutting down Bridge...
