OK, hier ist die config.json:
"name": "Hue",
"anyOn": true,
"hosts": [
"192.168.178.20:8080"
"lights": true,
"nativeHomeKitLights": true,
"nativeHomeKitSensors": true,
"nupnp": true,
"resource": true,
"sensors": true,
"platform": "Hue"
...und hier das Protokoll:
[6/9/2020, 17:33:27] [Config] Homebridge restart request received
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/kill -9 2576
pam_unix(sudo:session): session opened for user root by (uid=0)
pam_unix(sudo:session): session closed for user root
[6/9/2020, 17:33:28] [Config] Executing restart command: sudo -n systemctl restart homebridge
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart homebridge
Stopping Node.js HomeKit Server...
[6/9/2020, 17:33:28] Got SIGTERM, shutting down Homebridge...
[6/9/2020, 17:33:28] [Sonos] closed http://192.168.178.186:45013/notify
[6/9/2020, 17:33:33] [Sonos] goodbye
homebridge.service: Main process exited, code=exited, status=143/n/a
homebridge.service: Failed with result 'exit-code'.
Stopped Node.js HomeKit Server.
homebridge.service: Found left-over process 2214 (node) in control group while starting unit. Ignoring.
This usually indicates unclean termination of a previous run, or service implementation deficiencies.
homebridge.service: Found left-over process 2663 (sh) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 2664 (sudo) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 2669 (systemctl) in control group while starting unit. Ignoring.
Started Node.js HomeKit Server.
[6/9/2020, 17:33:33] Loaded config.json with 1 accessories and 5 platforms.
[6/9/2020, 17:33:33] ---
[6/9/2020, 17:33:34] Loaded plugin: [email protected]
[6/9/2020, 17:33:34] Registering platform 'homebridge-config-ui-x.config'
[6/9/2020, 17:33:34] ---
[6/9/2020, 17:33:34] Registering accessory 'homebridge-fakebulb.FakeBulb'
[6/9/2020, 17:33:36] Loaded plugin: [email protected]
[6/9/2020, 17:33:36] Registering platform 'homebridge-hue.Hue'
[6/9/2020, 17:33:36] ---
[6/9/2020, 17:33:36] Registering platform 'homebridge-landroid.Landroid'
[6/9/2020, 17:33:37] Loaded plugin: [email protected]
[6/9/2020, 17:33:38] Registering platform 'homebridge-weather-plus.WeatherPlus'
[6/9/2020, 17:33:38] ---
[6/9/2020, 17:33:38] Loaded plugin: [email protected]
[6/9/2020, 17:33:38] Registering platform 'homebridge-zp.Lib'
[6/9/2020, 17:33:38] Registering platform 'homebridge-zp.ZP'
[6/9/2020, 17:33:38] [Hue] Initializing Hue platform...
[6/9/2020, 17:33:38] [Hue] homebridge-hue v0.11.69, node v12.18.0, homebridge v1.1.0
[6/9/2020, 17:33:38] [Hue] warning: not using recommended node version v12.17.0 LTS
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/kill -9 2731
Ich habe die Einträge der anderen Plugin raus genommen. Die Info: "not using recommended node version v12.17.0 LTS" Habe ich bei allen Plugin.
