Okt 17 22:34:05 hyu homebridge[24299]: [10/17/2020, 10:34:05 PM] [Config] Changes to config.json saved.
Okt 17 22:34:07 hyu homebridge[24299]: [10/17/2020, 10:34:07 PM] [Config] Homebridge restart request received
Okt 17 22:34:08 hyu homebridge[24299]: [10/17/2020, 10:34:08 PM] [Config] Executing restart command: sudo -n systemctl restart homebridge
Okt 17 22:34:08 hyu sudo[24524]: homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl restart homebridge
Okt 17 22:34:08 hyu sudo[24524]: pam_unix(sudo:session): session opened for user root by (uid=0)
Okt 17 22:34:08 hyu systemd[1]: Stopping Node.js HomeKit Server...
Okt 17 22:34:08 hyu homebridge[24278]: [10/17/2020, 10:34:08 PM] Got SIGTERM, shutting down Homebridge...
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Failed with result 'exit-code'.
Okt 17 22:34:13 hyu systemd[1]: Stopped Node.js HomeKit Server.
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Found left-over process 24299 (node) in control group while starting unit. Ignoring.
Okt 17 22:34:13 hyu systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Found left-over process 24523 (sh) in control group while starting unit. Ignoring.
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Found left-over process 24524 (sudo) in control group while starting unit. Ignoring.
Okt 17 22:34:13 hyu systemd[1]: homebridge.service: Found left-over process 24525 (systemctl) in control group while starting unit. Ignoring.
Okt 17 22:34:13 hyu systemd[1]: Started Node.js HomeKit Server.
Okt 17 22:34:13 hyu sudo[24524]: pam_unix(sudo:session): session closed for user root
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Loaded config.json with 1 accessories and 2 platforms.
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] ---
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Loaded plugin: [email protected]
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Registering platform 'homebridge-config-ui-x.config'
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Registering accessory 'homebridge-fakebulb1.FakeBulb1'
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Registering platform 'homebridge-hue.Hue'
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Loading 2 platforms...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Config] Initializing config platform...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Config] Spawning homebridge-config-ui-x with PID 24561
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Phillips Hue] Initializing Hue platform...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Phillips Hue] homebridge-hue v0.11.77, node v12.19.0, homebridge v1.1.6
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] Loading 1 accessories...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Test] Initializing FakeBulb1 accessory...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Test] Starting a fake bulb(1) device with name 'Test'...
Okt 17 22:34:13 hyu homebridge[24541]: [10/17/2020, 10:34:13 PM] [Phillips Hue] searching bridges and gateways
Okt 17 22:34:14 hyu homebridge[24561]: [10/17/2020, 10:34:14 PM] [Config] Homebridge Config UI X v4.29.0 is listening on :: port 8080
Okt 17 22:34:18 hyu homebridge[24541]: [10/17/2020, 10:34:18 PM] [Phillips Hue] Philips hue: Philips BSB002 bridge v1941056000, api v1.41.0
Okt 17 22:34:19 hyu homebridge[24541]: [10/17/2020, 10:34:19 PM] [Phillips Hue] Philips hue: 16 accessories
Okt 17 22:36:29 hyu homebridge[24541]: [10/17/2020, 10:36:29 PM] [Phillips Hue] 192.***.***.101: 192.168.0.101:80: cannot connect: ETIMEDOUT - retrying in 15s
Okt 17 22:38:54 hyu homebridge[24541]: [10/17/2020, 10:38:54 PM] [Phillips Hue] 192.***.***.101: 192.168.0.101:80: cannot connect: ETIMEDOUT - retrying in 15s
Okt 17 22:41:19 hyu homebridge[24541]: [10/17/2020, 10:41:19 PM] [Phillips Hue] 192.***.***.101: 192.168.0.101:80: cannot connect: ETIMEDOUT - retrying in 15s
