Bekomme Fehler Meldungen.
Jun 14 10:07:49 raspberrypi3 homebridge[23980]: [2019-6-14 10:07:49] [CameraUI] [ERROR] Haustür (FTP): An error occured with FTP Server!
Jun 14 10:07:49 raspberrypi3 homebridge[23980]: [2019-6-14 10:07:49] [CameraUI] [ERROR] Terrasse (FTP): An error occured with FTP Server!
Jun 14 10:08:01 raspberrypi3 homebridge[23980]: [2019-6-14 10:08:01] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:08:01 raspberrypi3 homebridge[23980]: [2019-6-14 10:08:01] [CameraUI] [ERROR] Eingang (FTP): An error occured with FTP Server!
Jun 14 10:08:12 raspberrypi3 homebridge[23980]: [2019-6-14 10:08:12] [CameraUI] [ERROR] Haustür (FTP): An error occured with FTP Server!
Im Debug Modus:
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: [2019-6-14 10:35:54] [CameraUI] [ERROR] Eingang (FTP): An error occured with FTP Server!
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:35:54.758Z CameraUI FTPError: 421 Unauthorized client limit reached. Try again later.
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at FTPContext.onControlSocketData (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:237:39)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at Socket.socket.on.data (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:110:44)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at Socket.emit (events.js:189:13)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at addChunk (_stream_readable.js:284:12)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at readableAddChunk (_stream_readable.js:261:13)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at Socket.Readable.push (_stream_readable.js:220:10)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: [2019-6-14 10:35:54] [CameraUI] [ERROR] Terrasse (FTP): An error occured with FTP Server!
Jun 14 10:35:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:35:54.770Z CameraUI FTPError: 421 Unauthorized client limit reached. Try again later.
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: 2019-06-14T08:35:55.381Z CameraUI Haustür: Init movement detection
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: [2019-6-14 10:35:55] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: 2019-06-14T08:35:55.666Z CameraUI Error: self signed certificate
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: at TLSSocket.onConnectSecure (_tls_wrap.js:1051:34)
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: at TLSSocket.emit (events.js:189:13)
Jun 14 10:35:55 raspberrypi3 homebridge[24425]: at TLSSocket._finishInit (_tls_wrap.js:633:8)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:05] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:05.721Z CameraUI FTPError: 421 Unauthorized client limit reached. Try again later.
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at FTPContext.onControlSocketData (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:237:39)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at Socket.socket.on.data (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:110:44)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at Socket.emit (events.js:189:13)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at addChunk (_stream_readable.js:284:12)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at readableAddChunk (_stream_readable.js:261:13)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at Socket.Readable.push (_stream_readable.js:220:10)
Jun 14 10:36:05 raspberrypi3 homebridge[24425]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
Jun 14 10:36:06 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:06.040Z CameraUI Terrasse: Init movement detection
Jun 14 10:36:06 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:06.054Z CameraUI Eingang: Init movement detection
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:11] [CameraUI] [ERROR] Haustür (FTP): An error occured with FTP Server!
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:11.171Z CameraUI FTPError: 421 Unauthorized client limit reached. Try again later.
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at FTPContext.onControlSocketData (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:237:39)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at Socket.socket.on.data (/usr/local/lib/node_modules/homebridge-camera-ui/node_modules/basic-ftp/dist/FtpContext.js:110:44)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at Socket.emit (events.js:189:13)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at addChunk (_stream_readable.js:284:12)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at readableAddChunk (_stream_readable.js:261:13)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at Socket.Readable.push (_stream_readable.js:220:10)
Jun 14 10:36:11 raspberrypi3 homebridge[24425]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
Jun 14 10:36:17 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:17] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:36:17 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:17.080Z CameraUI Error: self signed certificate
Jun 14 10:36:17 raspberrypi3 homebridge[24425]: at TLSSocket.onConnectSecure (_tls_wrap.js:1051:34)
Jun 14 10:36:17 raspberrypi3 homebridge[24425]: at TLSSocket.emit (events.js:189:13)
Jun 14 10:36:17 raspberrypi3 homebridge[24425]: at TLSSocket._finishInit (_tls_wrap.js:633:8)
Jun 14 10:36:27 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:27] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:36:27 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:27.995Z CameraUI Error: self signed certificate
Jun 14 10:36:27 raspberrypi3 homebridge[24425]: at TLSSocket.onConnectSecure (_tls_wrap.js:1051:34)
Jun 14 10:36:27 raspberrypi3 homebridge[24425]: at TLSSocket.emit (events.js:189:13)
Jun 14 10:36:27 raspberrypi3 homebridge[24425]: at TLSSocket._finishInit (_tls_wrap.js:633:8)
Jun 14 10:36:38 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:38] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:36:38 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:38.831Z CameraUI Error: self signed certificate
Jun 14 10:36:38 raspberrypi3 homebridge[24425]: at TLSSocket.onConnectSecure (_tls_wrap.js:1051:34)
Jun 14 10:36:38 raspberrypi3 homebridge[24425]: at TLSSocket.emit (events.js:189:13)
Jun 14 10:36:38 raspberrypi3 homebridge[24425]: at TLSSocket._finishInit (_tls_wrap.js:633:8)
Jun 14 10:36:49 raspberrypi3 homebridge[24425]: [2019-6-14 10:36:49] [CameraUI] [ERROR] Garten_Dome (FTP): An error occured with FTP Server!
Jun 14 10:36:49 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:49.683Z CameraUI Error: self signed certificate
Jun 14 10:36:49 raspberrypi3 homebridge[24425]: at TLSSocket.onConnectSecure (_tls_wrap.js:1051:34)
Jun 14 10:36:49 raspberrypi3 homebridge[24425]: at TLSSocket.emit (events.js:189:13)
Jun 14 10:36:49 raspberrypi3 homebridge[24425]: at TLSSocket._finishInit (_tls_wrap.js:633:8)
Jun 14 10:36:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:54.436Z CameraUI Garten_Dome: Adding new entry to avoid gaps - Entry: 1
Jun 14 10:36:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:54.471Z CameraUI Haustür: Adding new entry to avoid gaps - Entry: 0
Jun 14 10:36:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:54.490Z CameraUI Eingang: Adding new entry to avoid gaps - Entry: 0
Jun 14 10:36:54 raspberrypi3 homebridge[24425]: 2019-06-14T08:36:54.509Z CameraUI Terrasse: Adding new entry to avoid gaps - Entry: 0
Config dazu:
