Beiträge von doctorgremlin
    leider bekomme ich seit dem letzten Update folgende Fehlermeldung:
    pi@raspberrypi:~ $ homebridge
    [2.12.2020, 19:58:49] Loaded config.json with 1 accessories and 4 platforms.
    [2.12.2020, 19:58:49] ---
    [2.12.2020, 19:58:51] Loaded plugin: [email protected]
    [2.12.2020, 19:58:51] Registering platform 'homebridge-config-ui-x.config'
    [2.12.2020, 19:58:51] ---
    [2.12.2020, 19:58:53] Registering platform 'homebridge-fritz-platform.FritzPlatform'
    [2.12.2020, 19:58:53] ---
    [2.12.2020, 19:58:53] Loaded plugin: [email protected]
    [2.12.2020, 19:58:53] Registering platform 'homebridge-homematic.HomeMatic'
    [2.12.2020, 19:58:56] Registering platform 'homebridge-weather-plus.WeatherPlus'
    [2.12.2020, 19:58:56] ---
    [2.12.2020, 19:58:57] Loaded plugin: [email protected]
    [2.12.2020, 19:58:57] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
    [2.12.2020, 19:58:57] ---
    [2.12.2020, 19:58:57] Loading 4 platforms...
    [2.12.2020, 19:58:57] [Config] Initializing config platform...
    [2.12.2020, 19:58:57] [Config] Spawning homebridge-config-ui-x with PID 26690
    [2.12.2020, 19:58:57] [HomeMatic CCU] Initializing HomeMatic platform...
    [2.12.2020, 19:58:57] [HomeMatic CCU] [Core] merging configurations
    [2.12.2020, 19:58:57] [HomeMatic CCU] Homematic Plugin Version 0.1.231
    [2.12.2020, 19:58:57] [HomeMatic CCU] Plugin by thkl https://github.com/thkl
    [2.12.2020, 19:58:57] [HomeMatic CCU] Homematic is a registered trademark of the EQ-3 AG
    [2.12.2020, 19:58:57] [HomeMatic CCU] Please report any issues to https://github.com/thkl/homebridge-homematic/issues
    [2.12.2020, 19:58:57] [HomeMatic CCU] running in production mode
    [2.12.2020, 19:58:57] [HomeMatic CCU] will connect to your ccu at 192.168.0.17
    [2.12.2020, 19:58:57] [HomeMatic CCU] IMPORTANT !! Starting this version, your homematic custom configuration is located in /home/pi/.homebridge/homematic_config.json
    [2.12.2020, 19:58:57] [HomeMatic CCU] [RPC] using xmprpc for communication with BidCos-RF
    [2.12.2020, 19:58:57] [HomeMatic CCU] init RPC for BidCos-RF.
    [2.12.2020, 19:58:57] [HomeMatic CCU] [RPC] local ip used : 192.168.0.5. you may change that with local_ip parameter in config
    [2.12.2020, 19:58:57] [HomeMatic CCU] init RPC for VirtualDevices.
    [2.12.2020, 19:58:57] [HomeMatic CCU] [RPC] using xmprpc for communication with BidCos-Wired
    [2.12.2020, 19:58:57] [HomeMatic CCU] init RPC for BidCos-Wired.
    [2.12.2020, 19:58:57] [HomeMatic CCU] init RPC for HmIP-RF.
    [2.12.2020, 19:58:57] [FritzPlatform] Initializing FritzPlatform platform...
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] server for interface BidCos-RF. is listening on port 9090.
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] Creating Local HTTP Client for CCU RPC Events
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] server for interface VirtualDevices. is listening on port 9093.
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] server for interface BidCos-Wired. is listening on port 9091.
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] server for interface HmIP-RF. is listening on port 9092.
    [2.12.2020, 19:59:00] TypeError: this.config.devices.map is not a function
    at new FritzPlatform (/usr/lib/node_modules/homebridge-fritz-platform/src/platform.js:82:25)
    at /usr/lib/node_modules/homebridge/src/server.ts:395:40
    at Array.forEach (<anonymous>)
    at Server.loadPlatforms (/usr/lib/node_modules/homebridge/src/server.ts:372:27)
    at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:151:29)
    at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (internal/modules/cjs/loader.js:1063:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
    at Module.load (internal/modules/cjs/loader.js:928:32)
    [2.12.2020, 19:59:00] Got SIGTERM, shutting down Homebridge...
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] Removing Event Server for Interface BidCos-RF.
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] Removing Event Server for Interface BidCos-Wired.
    [2.12.2020, 19:59:00] [HomeMatic CCU] [RPC] Removing Event Server for Interface HmIP-RF.
    Hat jemand eine Idee für mich, wie ich das wieder zum Laufen bringe?
    Ich vermute, es hat mit dem Update von Nodejs via hb-service auf 14.15.1 zu tun, aber wie kann ich wieder auf Version 12 downgraden (die war vorher installiert)?
    Gruß,
    Doc
    Ja, ist mit drin:
    pi@raspberrypi:~ $ echo $PATH
    /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin
    Interessanterweise habe ich das setup jetzt nochmal durchlaufen lassen, diesmal scheint es geklappt zu haben:
    Verstehe ich zwar nicht, warum es jetzt geklappt hat, aber immerhin bin ich jetzt mal einen Schritt weiter.
    Ja, es kommen wirklich zwei Meldungen, wenn ich /usr/bin/gcc bzw. /usr/bin/g++ angebe:
    pi@raspberrypi:~ $ which g++
    /usr/bin/g++
    pi@raspberrypi:~ $ which g++ /usr/bin/g++
    /usr/bin/g++
    /usr/bin/g++
    pi@raspberrypi:~ $ which gcc
    /usr/bin/gcc
    pi@raspberrypi:~ $ which gcc /usr/bin/gcc
    /usr/bin/gcc
    /usr/bin/gcc
    Das System ist ansonsten auf dem neuesten Stand:
    Hallo Det,
    hier mal die entsprechenden Ausgaben:
    pi@raspberrypi:~ $ sudo find / -name 'g++'
    /usr/share/bash-completion/completions/g++
    /usr/share/lintian/overrides/g++
    /usr/share/doc/g++
    pi@raspberrypi:~ $ which g++ /bin/g++
    /usr/bin/g++
    /usr/bin/gcc
    /usr/bin/gcc
    Vielleicht liegt es an deiner Version von Node. Habe gesehen es läuft die 12.16.1
    Kann sein, dass das Plugin dafür noch nicht ausgelegt ist.
    Geh mal runter auf die 10.20.1 - die läuft aktuell auch bei mir und funzt
    Leider nicht, das Ergebnis ist das gleiche:
    pi@raspberrypi:~ $ sudo su -
    root@raspberrypi:~# npm install -g homebridge-xiaomi-roborock-vacuum@latest --unsafe-perm
    > [email protected] install /usr/local/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync
    > node ./build.js
    make: Verzeichnis „/usr/local/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync/build“ wird betreten
    CXX(target) Release/obj.target/deasync/src/deasync.o
    make: g++: Kommando nicht gefunden
    deasync.target.mk:99: die Regel für Ziel „Release/obj.target/deasync/src/deasync.o“ scheiterte
    make: *** [Release/obj.target/deasync/src/deasync.o] Fehler 127
    make: Verzeichnis „/usr/local/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
    gyp ERR! stack at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.66-v7+
    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /usr/local/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync
    gyp ERR! node -v v10.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Build failed
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! [email protected] install: `node ./build.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the [email protected] install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! /root/.npm/_logs/2020-04-19T18_18_18_822Z-debug.log
    ich versuche auf meinem Raspberry auch gerade das Plugin zum Laufen zu bekommen, scheitere aber an der Installation. Folgende Fehlermeldung bekomme ich angezeigt:
    [email protected] install /usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync
    node ./build.js
    make: Verzeichnis „/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync/build“ wird betreten
    deasync.target.mk:107: die Regel für Ziel „Release/obj.target/deasync/src/deasync.o“ scheiterte
    make: Verzeichnis „/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync/build“ wird verlassen
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack at ChildProcess.emit (events.js:311:20)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/node_modules/deasync
    gyp ERR! node -v v12.16.1
    gyp ERR! node-gyp -v v5.0.5
    gyp ERR! not ok
    Build failed
    npm ERR! errno 1
    npm ERR! [email protected] install: node ./build.js
    npm ERR!
    npm ERR! /root/.npm/_logs/2020-04-15T16_46_17_998Z-debug.log
    Build-Essential ist in aktuellster Version installiert, und das System ist generell auf aktuellem Stand.
    Hat jemand eine Idee für mich?
    Super, den hatte ich wohl übersehen. Damit bekomme ich das Programm nun richtig angezeigt.
    Probieren kann ich es leider erst im Sommer wieder, Gartenbewässerung macht bei den Temperaturen wenig bis keinen Sinn ;)
    Vielen Dank für die Antwort.
    ich habe mich in den letzten Tagen auch ein wenig mit Homebridge beschäftigt, und bislang auch meine komplette Homematic und meinen Xiaomi Vac erfolgreich eingefügt. Das einzige, dass mir bislang noch nicht gelungen ist, sind die in Homematic gepflegten Programme in Homekit benutzbar zu machen.
    Ich habe zwar laut Anleitung in der config.json der Platform Homematic über "programs":["Bewässerung"], den entsprechenden Eintrag mitgegeben, und bekomme ihn auch in Homekit angezeigt, aber als Status steht dort "nicht unterstützt".
    Gruß,
    Thomas
